05-03-2023, 04:38 PM | #51 | |
Re: Does everything run off of one 12ga wire?
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
05-03-2023, 04:57 PM | #52 |
A 1971 Blazer -- That's some very nice work. Where will the battery be mounted?
I don't have a load center, but do have a budget distribution block.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
05-03-2023, 07:12 PM | #53 | |
05-04-2023, 07:19 AM | #54 | |
My battery will be in the stock location but I'm eliminating the distribution block on the passenger fender.... running a #8 with fusible link from the battery to the buss....#6 with fusible link from the alternator to either the starter or the buss (haven't decided yet).
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. Last edited by A1971Blazer; 05-04-2023 at 07:41 AM. |
05-04-2023, 07:26 AM | #55 | |
the harness I bought from PSI for the LS didn't have a provision for a TCC relay. At this point I can still add it in. As for the NSS I'm just using the factory one along with the factory starting circuit.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. Last edited by A1971Blazer; 05-04-2023 at 09:02 AM. |
05-04-2023, 10:17 AM | #56 | |
There are lots of discussions on the web about fuses vs. fusible links. I feel strongly both ways! I used one of the AAW kit's mega-fuse blocks in place of a fusible link. The kit uses a 175 amp fuse, which makes no sense at all. I've got a 100 amp fuse in there now because I had one laying around, but will probably go with 60 amps. BTW, for anyone wondering about the circuit breaker near the battery, it's for my 25-year old Vintage Air unit. AAW told me years ago that I can power the A/C through their fuse panels, but I'll keep things the way they are.
05-04-2023, 11:03 AM | #57 | |
It also has 4 additional #12 gauge feeds out of the panel for adding accessories (power windows...etc)
05-04-2023, 12:20 PM | #58 | |
Post Whore
More information in the link. https://www.mcmaster.com/products/slow-blow-fuses/
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-04-2023, 12:47 PM | #59 | |
Looks like the next size down is 40A.
05-04-2023, 01:02 PM | #60 |
I did an auxiliary battery and fuse panel in my side by side...
i used a resettable breaker similar to this.
05-04-2023, 01:14 PM | #61 | |
This is my 4th complete wiring job in the past 15 years or so, not including one installed by someone else that needed lots of fixes. I thought this would be the easiest of the bunch, but at my age everything's getting tougher. A lot of it is just getting off my butt and getting to work! In addition to over-thinking things, I've been the king of procrastinators on this project.
05-04-2023, 01:18 PM | #62 | |
05-04-2023, 01:34 PM | #63 | ||
The only breaker I'm using will be for the headlight relays...just one of the small 40A ones that I attached to my bracket. I made a copper buss for the 12V feed and the grounds so that I could use just one main feed wire into the box. most of the circuits in this box pertain to the LS swap wiring....I still have to complete all the chassis wiring....
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. Last edited by A1971Blazer; 05-04-2023 at 01:40 PM. |
