11-07-2023, 10:35 AM | #51 |
Re: Ol' Blue
Nicely done welding. I'll throw my opinion in, for what it's worth. I would keep the original cross member if you could. As Dennis pointed out, for the radiator support, but also for support across the front of the frame in general.
11-07-2023, 01:47 PM | #52 | |
Re: Ol' Blue
I've even seen them weld the tube as a new front crossmember, THEN use that tube to hold one of those 3 piece splined sway bars!
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
11-07-2023, 01:57 PM | #53 |
Re: Ol' Blue
Thanks guys. I am going to add a new 3/8" tube across the front where the front shackles used to be, some kits even come with that. I was thinking about welding it in, but I think I might bolt it in, just have to give it some more thought.
I have had the dickens of a time with keeping everything level. It seems that just sitting there, things will move. I know there is a small difference in the two sides front to rear, but the new crossmember itself will be level in the middle, but higher on one side than the other. then I'll check the rake, trying to hold 2 degrees fall to the front and I swear where I put the electric level will change the rake. I pulled a string line from front to rear to see if the rails were warped, but I can't find it. Ok, enough complaining for one day.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
11-09-2023, 06:41 PM | #54 |
Re: Ol' Blue
Ok, after a LOT of checking level, here is what I have:
IMG_1514 by Robert Moorman, on Flickr TCI Engineering crossmember tacked in place. The truck frame rails are 2 degrees down rear to front on the driver's side, and 3 degrees down on the rider's side. The frame is level side to side at the radiator support, the old crossmember and at the rear. If you look at the crossmember you can see the lower A-arms in place, upside down, as the instructions said to do it. The pipe the bolt goes through at the end of the crossmember is 0 degrees on both sides, and the middle of the crossmember is at 0 degrees front to rear as instructed and the new crossmember is 0 degrees side to side. So, after reading the instructions over and over, and watching the one YouTube video over and over again, I think that is right. Then I put a plumb bob in the back of the truck, centered and measured from the grease fitting that is on the top side right now since the A-arms are upside down as instructed, and the measurement from each to the plumb bob is within 1/16"! I'm going to weld it in place next time I fire up the welder. If you look to the front of the frame, you may make out the brace I'm building to go there. It is in front of the old crossmember, and just about 2" in front of the front rivet on the radiator mount. I found some old brackets from one of the frames and it had the right bend, so I drilled 4 holes in them and mounted them to the old front shackle holes. I am using the old spare tire crossmember for the front, then welding a piece of 1/4 x 1 x 2 square tubing to that spare tire carrier, then I'm welding a piece of 3/8 x 1 tubing to the top of the first tube. I think the idea is to keep the frame from spreading and I think that should do it, since the brackets going to be bolted to the frame are the same thickness as the frame. Anyway, feels good to get that crossmember leveled like the instruction say, now to weld it!
11-09-2023, 07:11 PM | #55 |
Re: Ol' Blue
thats a load off, eh?
remember to do short welds so the frame doesn't heat up and bend on you. one other thing to think about, once that job is done, is how you will make the trans cross member. since the old rear engine cross member is gone the frame will have a little more give to it in the area where the cab mounts are. this can cause the cab mounts to spread or narrow and that will give you a big headache and can cause cracking of the cab metal if it happens and goes unchecked |
11-10-2023, 08:47 AM | #56 |
Re: Ol' Blue
Thanks Raven, and yes, it is.
One problem at a time. I have a tranny cross member from TCI that bolts in. I think I'm going to check widths and then drill holes for the tranny support. That will be after I get an engine/tranny to test fit.
01-11-2024, 07:30 PM | #57 |
Re: Ol' Blue
Good news/bad news. The wife wanted a Cameo, and after looking into it, it was going to be a daunting task to get all the parts to change the 57 into a Cameo, especially with all the new parts for the step side that wouldn't be used, like the entire step side bed.
Then my luck changed, and last week a guy about an hour from me was selling the Cameo that his father-in-law had bought from his brother who had bought it new in 1955! Yes, a 2-owner truck. The truck was driven to a shop to be painted 3 years ago. Unfortunately, Dad passed away and no one in the family wanted to finish the truck. Since the truck has sat for so long, some parts mysteriously disappeared, most importantly the entire tailgate. My buddy just bought the entire assembly, so I know it's available. However, there are NO rust holes, and only moderate surface rust on the underside, and the odometer shows 7,642 miles, which I know can't be right, but the truck is really solid. So as of today, wish me well selling the 54 and the 57 while I concentrate on the 55 Cameo. IMG_E1573 by Robert Moorman, on Flickr SISV1591 by Robert Moorman, on Flickr TNSX7217 by Robert Moorman, on Flickr The cowl vent was gone as was the hood latch, one hood hinge, and the piece that goes over the grill. Other than that, it's all there! I started working on the center bumper piece tonight, trying to get that hinge to loosen up a little. I'm not sure how the two studs on it secure it, but I'm sure someone on here does and will share a picture.
01-12-2024, 08:29 AM | #58 |
Re: Ol' Blue
nice!
01-12-2024, 09:19 AM | #59 |
Re: Ol' Blue
Thanks, and yes it did.
01-12-2024, 09:42 AM | #60 |
Re: Ol' Blue
and, even a hood ornament! they are usually gone long ago.
01-12-2024, 09:48 AM | #61 |
Re: Ol' Blue
Yep, just wish they hadn't lost the tailgate.
01-12-2024, 09:57 AM | #62 |
Re: Ol' Blue
Nice find!! It looks like it is working out for you. Enjoy it. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
01-12-2024, 10:01 AM | #63 |
Re: Ol' Blue
well, worst case scenario you can always fab a custom gate with the latch style you like etc.
there is one in this link that I like, it looks more angled than a stock one, but then again I haven't seen a stock one in years, but it is a personal preference thing. the rer truck. https://www.motortrend.com/features/...-pickup-truck/ |
01-12-2024, 10:05 AM | #64 |
Re: Ol' Blue
I think the cameo is based on a stock bed with fiberglass sides instead of step side fenders. possibly a stock step side tailgate will fit and could be re-sheeted with flat sheet that has a design rolled in to your preference.
you know you can do it. |
01-12-2024, 10:10 AM | #65 |
Re: Ol' Blue
if you have the tailgate from your 57 you could test fit that to see if it fits the cameo.
01-12-2024, 10:51 AM | #66 |
Re: Ol' Blue
Raven, that is one cool tailgate!
I have found a couple of places that sell new tailgate components, the outer skin, the steel inner and the latches, hinges, etc. One is made here in the USA, and I have a buddy who just ordered one for his truck, so I'll get to see it before I buy it. So, I think I'm good on the tailgate, just wish it was all original. Although, I admit I do like that one in the magazine article.
01-21-2024, 05:26 PM | #67 |
Re: Ol' Blue
IMG_1656 by Robert Moorman, on Flickr
Started taking the Cameo apart. All the bolts are rusted, as to be expected. I spent all day getting the remaining bed wood out, leaving the side rails bolted to the crossmembers. HOW do you get those bolts out without damaging the sides? The side rails are straight and not rusted through and so I'd like to keep them. However, I can't drill the bolts out, they are too rusted to get the nut to come off, but not rusted enough to just break them, and that brings me to grinding them, but even the small air grinder with a cut off wheel is a little too close to the side. Ideas? IMG_1659 - Copy by Robert Moorman, on Flickr Also, there are two things on each side, front and back, they look like an L shaped U channel that is flush with the top of the frame. If you look close at the picture, just behind the crossmember, and I think you can make it out. There is one on each side, and one more on each side at the next crossmember. What are they for and do I need them? Thanks.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 Last edited by 8man; 01-21-2024 at 05:52 PM. Reason: More details |
01-21-2024, 05:37 PM | #68 |
Re: Ol' Blue
you best take some better pics of the mysterios brackets.
have you looked in the factory assembly manual? free download from the trifive site. lots of info on how stuff was assembled. |
01-23-2024, 09:05 AM | #69 |
Re: Ol' Blue
lots of penetrating lube, continued application over a few days ... vice grips on the bolt head, or best bet to grinder in a flat-head screw driver slot. 2 person job, one with an impact driver on the nut ... one with a huge screw driver with a box wrench on it for added holding. person on the screw driver should be LEANING on it then let the impact rip!
01-23-2024, 10:33 AM | #70 |
Re: Ol' Blue
those frame brackets are usually associated with overload springs. on this style there is a set of leafs added above the regular springs. they don't attach to spring hangers but simply sit there above the regular spring stack. when a load is applied heavy enough to lower the truck enough, that stack of overload leaves will bottom against the frame brackets and start to take some weight
these sites has a pic if you scroll down just a little https://www.torklift.com/rv/stableload https://mrtrailer.com/psrsuspension.htm |
01-23-2024, 10:38 AM | #71 |
Re: Ol' Blue
you're not likely gonna need the brackets or the extra leaf.
the way a normal leaf spring works is they may have a super thick lower leaf that doesn't touch the rest really unless there is a big load applied and then that becomes an overload leaf and helps hold the extra weight by not allowing the lighter leaves above it to bend so much. the other method uses a stack of leaves added above the original stack with either frame brackets to rub against when needed or else the ends of those overload springs are tied to the lower set of springs to aid in carrying the load. you could check the factory assembly manual and see the whole set up if you wanted. |
01-23-2024, 11:36 AM | #72 |
Re: Ol' Blue
Thanks Raven, those links helped me understand how they work.
I will not be using them.
01-23-2024, 12:36 PM | #73 |
Re: Ol' Blue
the assembly manual shows the overload springs and the frame brackets in section 5 sheet 4, however it is for a larger truck. you get the idea though.
the factory assembly manual, lots of guys call it the FOM, also has sheets on how the cameo bed and tailgate got together, if you're looking. |
01-23-2024, 12:41 PM | #74 |
Re: Ol' Blue
yeah, thats what I thought, not needed for what you will be usingthe truck for. as a side note, if the spring pins and bushings are worn out, and considering the springs are pretty old and may fail when getting used again, there are builds on here that use spring hangers and springs from newer trucks that have rubber bushings in the spring eyelets. new frame brackets are available from Dormer and springs can be had at any local parts supplier. since the rear axle will likely be geared pretty low lots of builds replace the whole set up. will you be going with a lowered truck and air bags, leaf springs, coils, any plans?
01-23-2024, 12:52 PM | #75 |
Re: Ol' Blue
I installed the TCI front end kit with coil overs and on back I went with their leaf spring kit which replaced everything and dropped the rear a little. I saw a picture of that set up and liked the way the truck looked. I had the frame and was already working on it when we got the Cameo, so now I have a completely stock 55 frame, with stock 6, 3 speed on the column, etc.
I still have the 57 with a C10 frame under it that has been bagged, so I may put the 55 frame under it. I don't know yet. You are correct in that the Cameo certainly won't need the overloads!
