Old 09-29-2012, 09:08 PM   #726
OrrieG
OrrieG's Avatar
Re: Lurker OrrieG Progress Pics
Have to check my photos.
OrrieG is offline   Reply With Quote
Old 10-01-2012, 03:06 PM   #727
OrrieG
OrrieG's Avatar
Just looked and I attached a spring from the stock tab on the pedal back to hook on the stock bracket.
Old 10-01-2012, 03:20 PM   #728
OrrieG
OrrieG's Avatar
Details on the gas door install. First I made a template of a section thru the bed side and floor. The door I got matches the curve. third photo is what a started with. I quickly decided that the inner piece needed to go. I fiddled with different filler tube (voyager and stock 59) but they are to large diameter to work. I cut the door down to the size I needed.
Old 10-01-2012, 03:31 PM   #729
OrrieG
OrrieG's Avatar
I then made a template of the door and got it in the right location. I had to move it toward the rear to miss the bed cross sill, you can see when I marked the location of the sill on the bed. I cut the hole using an air body saw, generates less heat than a cut off wheel. After I got the hole cut I needed to trim the inside top of the door housing to miss the bed floor. Also had to modify the hinge mount and cut off a piece of the hinge. Last photo is the door housing in it place ready to weld.
Note that the corners are rounded, that is a tip I picked up from someone here. With a square corner you have to weld twice in the same place, which generates twice as much heat and potential for distortion.
I need to get a smaller filler neck, a 60 gm auto tank neck that is 1.5" diameter will work (checked out the one on my Chevelle!) or I am going down to the harley shop to see about a tank bung. That would give me the added bonus of a pop out cap with a cable. Once I get that sorted out I will weld in the door housing.
Old 10-22-2012, 01:21 PM   #730
OrrieG
OrrieG's Avatar
Its been an interesting three weeks. Moved back inside and finished up the heat/ac. If you have installed a Vintage Air set up read to further. I had it in and out three times, it is a very tight fit. Was having fits trying to get the blind firewall bolt to align, so thought I could just replace the bolt with an inside stud in the case. Wrong! That little 3/8" projection was enough, at least on my truck, to keep it from going high enough. I did get the AC hoses ran, I was worried they might kink in the tight radius but they are ok. I got them thru the cowl and will deal with the other ends when I get the rest of the ac. I modifed the underdash unit, I did not like the plastic look. I cut back the projection, removed it from the box, turned it 180 degrees and made a new plate for the diffusers. I scrubbed off the "chrome" finish to black them out. The louver is 1" x 1/8" aluminum painted metallic black to match the steering wheel with the edges polished. I will adjust the louvers with a screw driver, based on my other cars they will stay in one position. Hooked up the power and the fan works and the relays click when various levers are pulled. I needed to make one longer, got a lawn mower cable and made my own, coiled the ends around a big nail.
Old 10-22-2012, 01:31 PM   #731
OrrieG
OrrieG's Avatar
Also got the steering wheel painted. Photos do not do it justice, the paint is a metallic black.
Old 10-22-2012, 02:14 PM   #732
Kim57
Kim57's Avatar
Looking good.
I like the louvers on the bottom of the dash.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-22-2012, 07:04 PM   #733
oldman3
oldman3's Avatar
Originally Posted by Kim57 View Post
Looking good.
Kim
I'm with Kim, the louvers look really good, nice job...Jim
oldman3 is offline   Reply With Quote
Old 10-22-2012, 11:14 PM   #734
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Nice work! The louvers have a really cool 50's look to them, I like that a lot!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 10-22-2012, 11:58 PM   #735
Green 1959
Green 1959's Avatar
I agree your work is always so impressive and imagitive!!
I pity the fool with only 2 headlights!
Green 1959 is offline   Reply With Quote
Old 10-23-2012, 11:43 AM   #736
OrrieG
OrrieG's Avatar
Thanks guys. On to the next task.
Old 10-23-2012, 04:41 PM   #737
_Ogre
_Ogre's Avatar
louvers look good orrieg
i didn't use the sure fit for that same reason.
gas door is looking good too.
the tf panel trucks had an indent in the bed that gm routed the filler thru
shop air compressor timer
Old 10-24-2012, 12:29 PM   #738
dug224
dug224's Avatar
OrrieG: Watching your gas door build closely. My filler neck from the Envoy tank is roughly where you are mounting your door. What will be your closure method on the inside of the bed?
After reading your progress yesterday I was inspired and went home and made some progress on my front cab mounts. This will be the first weekend I have had in months to do any work so hope to post some updates on Monday. Dug
dug224 is offline   Reply With Quote
Old 10-24-2012, 02:35 PM   #739
daverod
SSN 706
daverod's Avatar
go baby go
daverod is offline   Reply With Quote
Old 10-24-2012, 04:52 PM   #740
OrrieG
OrrieG's Avatar
Plan is just form a radiused piece of tin around what ever stick up to protect the fill pipe and not trap dirt or water. It does not look like it will be much.
Old 10-28-2012, 12:23 AM   #741
OrrieG
OrrieG's Avatar
Made a cover for the under dash ac hoses. Template, redneck brake, tin snips and it is ready for paint.
Old 10-28-2012, 12:27 AM   #742
Daze57
Daze57's Avatar
very nice job sir !
i like the ''redneck'' brake !
Daze57 is offline   Reply With Quote
Old 10-28-2012, 12:56 AM   #743
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
Old 10-28-2012, 09:20 AM   #744
oldman3
oldman3's Avatar
Nice job, looks great....Jim
Old 10-28-2012, 12:57 PM   #745
Rude Dude
Rude Dude's Avatar
Great fab work!
Rude Dude is offline   Reply With Quote
Old 10-28-2012, 03:30 PM   #746
sgtusmc
sgtusmc's Avatar
Nice!!!
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 11-22-2012, 06:09 PM   #747
OrrieG
OrrieG's Avatar
Break in the weather so I pulled the truck out and finished the fab and tacked the gas door in. I must have 12 hours in on this, had to fab the inside twice. Cut, bend, fit, repeat...a lot. Anyway here is how it fits. For reference the tank inlet in the same plane as the center of the bed cross sill. The fill neck is the top and bottom section of a stock cab fill welded to a piece of flat stock with the inside offset to the top. That give max. slope but keeps the cap almost centered in the door opening.
Old 11-22-2012, 10:47 PM   #748
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Looks great! If you want a stock looking piece to cover it, go to the yard and look for a 73-87 K5 blazer. They have a nice looking hump that covers the filler neck, it should be screwed in.
Here's a picture, you may only need a small part of it.
Tony
Old 11-23-2012, 01:49 AM   #749
OrrieG
OrrieG's Avatar
Thanks for the tip, I'll go look before I fab something. I was going to just get a short section of 3-4" exhaust pipe and modify it to fit after I got the wood bed installed.
Old 11-23-2012, 02:04 AM   #750
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
