Old 03-14-2014, 09:46 PM   #726
HzEmall
HzEmall's Avatar
Re: "The Ayatollah of Rusty Hole'a 1987 SWB 6.0 4L80E
Originally Posted by Gordonr1973 View Post
Gregg's Distributing made them for me to my lengths. I don't know the brand of the hose.
They are probably BrakeQuip
Tim Baillie
Installer/Designer/Fabricator
Trick Factory Customs
Company - www.trickfactory.com
Personal - www.hzemall.com
Instagram - @hzemall
HzEmall is offline   Reply With Quote
Old 03-19-2014, 12:32 AM   #727
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Wet sanded today and shot second high build coat:
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 04-05-2014, 01:58 PM   #728
Gordonr1973
Home Built '87
Base and pearl coat sprayed down this morning. Just clear coat left to do after lunch.
I forgot how hard it is to always watch your hose and not rub any panels with anything while spraying paint is!!
Gordon
Old 04-05-2014, 02:16 PM   #729
Greenlee
Greenlee's Avatar
Nice!
Greenlee is offline   Reply With Quote
Old 04-05-2014, 06:01 PM   #730
kikkegek
kikkegek's Avatar
Cool!
kikkegek is offline   Reply With Quote
Old 04-05-2014, 06:06 PM   #731
Gordonr1973
Home Built '87
Couple more pics with the clear sprayed down
Gordon
Old 04-05-2014, 06:18 PM   #732
mooseknuckles
mooseknuckles's Avatar
looks good!
mooseknuckles is offline   Reply With Quote
Old 04-05-2014, 06:45 PM   #733
y5mgisi
Second Chance Program
y5mgisi's Avatar
Do you think there has been a big difference in initial quality of the paint/clear with the better paint gun?
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 04-06-2014, 12:30 AM   #734
Gordonr1973
Home Built '87
I'm not the best painter so a bit better gun helped me I think.
I've tried cheap guns from China & ones that are entry level. I think today the clear just seemed to lay out a lot better.
Gordon
Old 04-06-2014, 08:32 PM   #735
y5mgisi
y5mgisi's Avatar
Seems its a razor thin line of laying it on thick enough to make it lay out right, but not so thick that it runs.
Old 04-07-2014, 10:49 PM   #736
Gordonr1973
Home Built '87
Couple more from tonight after cleaning the shop up a bit!
Seems like its going to be moving fast now
Gordon
Old 04-07-2014, 10:50 PM   #737
Gordonr1973
Home Built '87
Hood
Gordon
Old 04-13-2014, 03:56 PM   #738
Gordonr1973
Home Built '87
Sound deadener in.
Gordon
Old 04-13-2014, 07:37 PM   #739
Greenlee
Greenlee's Avatar
Looking good Gordon!
Old 04-18-2014, 05:13 PM   #740
Gordonr1973
Home Built '87
Seals - It grommet through the firewall for LS wiring harness.
Gordon
Old 04-18-2014, 05:36 PM   #741
y5mgisi
y5mgisi's Avatar
Love those grommets.
Old 04-18-2014, 08:30 PM   #742
jpnh
jpnh's Avatar
coming out good/nice job
jpnh is offline   Reply With Quote
Old 04-28-2014, 01:53 PM   #743
Jermdeane
I'm working on doing the same swap to my 87 right now. I'm currently working on the chassis, then it's on to brake and fuel lines. What type of lines did you run? If I remember correct from the pictures it looked like rubber instead of a hard line. Thanks in advance and I love the build so far, keep up the great work.
Jermdeane is offline   Reply With Quote
Old 04-29-2014, 07:46 AM   #744
Greenlee
Greenlee's Avatar
Gordon, where did you find those grommets? They look better than the factory ones. I have had trouble finding any grommets at all in the larger sizes. Thanks
Old 04-29-2014, 11:37 PM   #745
Gordonr1973
Home Built '87
Brake lines were made by a hydraulic shop. Tim id'd them a few posts ago.
The grommets are called "Seals-It". I got them at Summit Racing.
Been working on improving the rats nest of wiring.
Gordon
Old 05-06-2014, 11:46 PM   #746
Gordonr1973
Home Built '87
I'm wiring the "window relay mod" and figured this pic I found on the interwebs might help someone else out too.
Several threads on here that describe how to do it if you're interested.
Gordon
Old 05-07-2014, 12:25 AM   #747
Sodell
Sodell's Avatar
Gordon, Looks great, should be on the road in no time... what brand clear and activator are you using?
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 05-07-2014, 11:54 PM   #748
Gordonr1973
Home Built '87
Everything I used was PPG on this truck. But will be trying Valspar on my car next.
Gordon
Old 05-08-2014, 11:01 PM   #749
Gordonr1973
Home Built '87
Relays all wired in for the windows.
Gordon
Old 05-10-2014, 06:11 PM   #750
Lq9'ed 80 Sierra
I am not Gordon but I'll answer your question. Earls Performance.
Lq9'ed 80 Sierra is offline   Reply With Quote
