#726 | ||
Lucky Teter at the wheel
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
I am moving in this direction, glad to hear ya'll agree. I was investigating sounds of the 2 trucks that I have with the stock setup. The 6.0 Denali vs. 5.3 is significant. The 6.0 definitely has a little burble and the 5.3 does not. A quick look underneath revealed the the 6.0 muffler is different - soooo, since I have a complete 6.0 exhaust system from a Yukon with the dual inlet muffler like I listened to - I'll be scrapping what I did last night. No biggie since I only spent an hour on it. I'll get that system loose this weekend and delete the cats on it again. The muffler is dual in - dual out, but on a Yukon it converges into 1 right after the exit. I wonder what it sounds like separate vs. merged?
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#727 |
Like your idea of 4 link in rear. I want to use a newer chassis for my suburban also and the wheelbase will be different no matter what I use (stock is 127"). That makes the change in wheelbase easier with the good ride.
![]() 2005 K2500 Duramax (hauls the junk home) 1967 Chev C10 (hauls a$$) 1970 Suburban (Yukon XL 4 door) 1968 GMC 3/4 ton (sheetmetal only, chassis gone) 2005 Malibu (wife's car, still a Chevy) Project Family Hauler New Home for Chevys (Moved in and working) |
#728 |
Exactly!
#729 |
On my 5.3L in LowBuk I have stock camaro manifolds with 2.5" duals out to a 3" merge right behind the trans then it goes from their the single pipe goes to the flow master in and out. It is mellow but you can tell their is something under the hood that is not stock.
With that being said I think with your build I would go with a stock set up you have around their and down the road you can swap out for a cat back set up that is made for your truck if you want a change. Kevin LFD Inc. |
#730 | |
No cats on yours? How does she run?? Does anyone know if you gain much by deleting the cats?
#731 |
And now for my next trick.
I am too cheap to buy an aftermarket air system since they are over $1000. I have 3 of these new style units left over, and it is factory engineered ready to plug into my harness. I'll have to make it fit somehow if it kills me.
#732 |
Get a shoe horn!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#733 |
Junk Yartist
I just watched despicable me and I think Gru had a tool you need
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#734 |
Yes, a shrink ray would be quite handy about now.
#735 |
VA72C10
![]() Join Date: Mar 2008
Have you looked at what they run on the used parts market? Maybe you can sell them and pick up a vintage air with the money?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#736 |
GEARHEAD
You've done some terrific work on this project, but I don't think that unit is going to fit under your dash.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#737 |
Yea. Until the unit re-expands after install and tears the truck apart.
I tend to over analize cartoons. It's a sickness. ![]()
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#738 | |
I think I can, I think I can, I think I can......
#739 |
67cheby
![]() Join Date: Sep 2008
i dont think you are trying to save money ....i think you just like the challenge of seeing if you can get it in there !!!!! YOU CAN DO IT !!! then you will have pass and driver climate control ...how cool is that
#740 |
[quote=67cheby;4529326] I don't think you are trying to save money ....I think you just like the challenge of seeing if you can get it in there !!!!! YOU CAN DO IT !!!
Hmmmmm, I think you may be right.
#741 |
Still plays with trucks
What about pulling the stock dash off the firewall, fit up the A/C unit then reinstall the stock dash over the top. You could then locate the stock metal dash panel a little farther off the firewall than it was stock to give you the room you need. Some metal filler panels on the dash top and sides will be needed but it can still look stock when you are done, just stretched a little.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#742 | |
#743 |
Local Redneck Authority
As long as the dash isn't in the middle of the doorway....
![]() Much talent in this build, thank you again for sharing!
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
#744 |
'67 C-10 LWB Driver
![]() Join Date: Dec 2010
lol, i think the back seats just got smaller!! JK ;-)
'67 C-10 LWB - My Build Thread ![]() '67 C-20 LWB - My Donor/ Parts truck - SOLD! '92 GMC SAFARI VAN - My Parts Go Getter '06 KIA SPORTAGE EX - My Commuter "All of this crap better make a truck!" - my wife Sue. Proud U.S.M.C. Dad! |
#745 |
Abracadabra
POOF
#746 |
wow that is awsome yes gru did have the tool you needed well i hope it works better than it looks.....that looks kinda ugly... but its ugly because it was kept inside anewer dash.....anyways drew great progress
#747 |
VA72C10
Nice job shoehorning that in
![]() It doesn't stick down that much lower than a stock A/C box actually...probably 3-4" or so more.... ...are you going to be able to integrate the controls somehow?
#748 |
![]() Join Date: Jul 2010
Nice...who needs a glove box anyway....lol
You running beanch or buckets... |
#749 |
'67 C-10 LWB Driver
that is some nice photoshoppin'!!
#750 |
