02-14-2017, 03:44 PM | #726 |
Re: 75 Dually build
Very cool truck and interesting build. While not my taste I respect the build quality. I like the vinyl wrap idea, although I don't imagine it is a first timer type job. Hopefully soon I will have a dually build as well, but it will not be lowered it just isn't my style. I have a question though can this truck still haul like a stock one other than the bed? You never know I could be swayed. I'm looking forward to the finished outcome. I love the color combo.
1967 Chevrolet Impala Sport Sedan Royal Plum Metallic (1967) My Dad ordered it. 33,xxx miles, parked since 1977. |
02-14-2017, 04:22 PM | #727 | |
Re: 75 Dually build
About the towing ability. If you boil down all the negativity about lowered trucks we are basically using a stock (for the most part) type of suspension. Airbags are not a limiting factor, in fact that is what most Semi trucks use everyday. Other than the bed you mentioned above the pulling ability of my truck is about the same as a stock truck. Mine has one advantage in that it has Accuride air suspension controller, which when an increased load is placed on the truck and the suspension squats down this system reacts instantly by increasing or decreasing the air pressure and keeping the truck at the preferred ride height. Bagged trucks tow all the time, and actually can ride, if setup correctly, better than a stock truck. I hope that helps. Build a slammed dually! Last edited by 75Dually; 02-14-2017 at 04:28 PM. |
02-14-2017, 04:40 PM | #728 | |
Re: 75 Dually build
02-14-2017, 06:08 PM | #729 |
I'm just glad to be here!
Re: 75 Dually build
Scoti, I don't think that Christmas Tree weighs 2000 pounds...LOL
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
02-15-2017, 12:28 AM | #730 |
Re: 75 Dually build
Boss don't make me sand no more!
The drivers side is done! One little spot on the lower part of the front fender. I laid down some filler, and I will wet sand it out tomorrow. You know you go over these panels hundreds of time, and you will still miss something! ARG! Oh well... Such is life... Tomorrow the wrapping begins! Most likely I am going to start with the roof and work my way down. Stay tuned! |
02-15-2017, 08:56 AM | #731 | |
Re: 75 Dually build
02-15-2017, 08:02 PM | #732 |
6>8 Plugless........
Re: 75 Dually build
Great work on it! When is LST?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-15-2017, 11:01 PM | #733 |
Re: 75 Dually build
02-15-2017, 11:13 PM | #734 |
Re: 75 Dually build
Now the wrapping starts, and I catch a cold! Crud!!
Oh well I'm going to see the doctor tomorrow and see what they can do for me... This roof section was actually not that bad. I'm glad I started off with the harder parts because I now know how to handle items like the roof ribs. I have the knifeless tape laid down on the very edges under the blue you see here (you can just see the light green tape if you look closely at the corners), so that when I lay down the side parts and they are in place I will make a butt joint and hopefully it will be very hard to see the seam. That's my plan at this point... Hopefully tomorrow I will feel better because I need everyday to get this thing done. 7 more days until we leave! |
02-16-2017, 09:39 AM | #735 |
Re: 75 Dually build
This is awesome! Very well done on the wrapping for never doing it before. When I finally find a dually I just may try this as well.
02-16-2017, 11:12 AM | #736 |
Re: 75 Dually build
Looking good Chris. That part I have for you will look good against that blue...
Looks like I headed down to LST the morning of the 24th. I just hope its with my '65...
02-16-2017, 01:21 PM | #737 |
Re: 75 Dually build
You have just made my whole week! Can't wait to see you and that mystery item. Dinner the 24th?
02-17-2017, 03:38 PM | #738 |
Re: 75 Dually build
Sounds good to me. I call you when I get down there...
02-17-2017, 08:01 PM | #739 |
Re: 75 Dually build
So here are some update pics. I really like the grey with the blue, in person it really pops!
Stay tuned! |
02-17-2017, 09:58 PM | #740 |
Re: 75 Dually build
It's looking very nice from here! Keep up the nice work.
02-18-2017, 12:30 AM | #741 |
Re: 75 Dually build
02-18-2017, 12:32 AM | #742 |
Re: 75 Dually build
A couple more pics for tonight. Got the passenger door done. Tomorrow it's the front end and the drivers side rear fender. So much to do! So little time!
Stay tuned! |
02-19-2017, 12:32 AM | #743 |
Re: 75 Dually build
So I thought I would show the hood being done tonight. It took me 1 1/2 hours from start to finish. It came out great. Now I'm tired again and it's off to bed!
Stay tuned... |
02-19-2017, 03:26 PM | #744 |
Re: 75 Dually build
Looking good. You make it look easy. You may have found your new calling in life. When should I drop off my K5? Take lots of pictures of LST for those of us further away than you are.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
02-19-2017, 10:47 PM | #745 |
Re: 75 Dually build
I will take a ton of pics to share with my fiends in the frozen north and other hinter lands still deep in winter! Um no on the other request! LOL!
02-19-2017, 10:51 PM | #746 |
Re: 75 Dually build
So more pics of the big super smurf! Got the front end done today, for the most part. Still have to do the lower front cross bar and the part under the cowl. Oh yeah speaking of the cowl... I still have to finish that too... Yeah!
At least I made some good progress today. Both front fenders, and the drivers door. Only 3 more days before we haul down south. Stay tuned! |
02-21-2017, 09:31 AM | #747 |
Re: 75 Dually build
I would seriously consider taking it part way done and telling everyone it is wrapped and see their reactions. Very cool stuff and nicely done! When I get one of my own I may consider trying this as well.
02-21-2017, 11:25 AM | #748 | |
Re: 75 Dually build
Just something to think about. Thanks for the above comments! |
02-24-2017, 01:58 AM | #749 |
Re: 75 Dually build
Well I'm bummed... Not going to be able to go to LST this year. The truck as you see was just about ready to roll except for some minor items to install. That show will be there next year and there are other shows I want to attend this year too. I hope all my friends have a blast there and are safe coming home.
Stay tuned... |
02-24-2017, 11:48 AM | #750 |
Re: 75 Dually build
Ruh roh....what happened?
94 ls swap silverado 65 Pontiac 78 c30 crew cab dually (parted and gone) 82 c30 crew cab dually ( now building ) 91 r30 crew cab dually (parted and gone) 69 swb-sold 71 lab sold all in progress......__ ..........._______ |__\__ ..........|__(O)______(O)] ........................ |
Tags |
air bags, alcoas, chevy, dually, lowered |
