Old 03-02-2015, 12:49 AM   #726
sduckworth13
sduckworth13's Avatar
Re: Project: Shiro
I heard that their rockers fit poorly, but everything else is top notch.
Scott
sduckworth13 is offline   Reply With Quote
Old 03-02-2015, 10:17 AM   #727
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Project: Shiro
Originally Posted by sduckworth13 View Post
Here is a link to there website. https://tabcoparts.com
I couldn't get the online order to go through so I just called them. The online order system is new so it probably needs the kinks worked out.
Thanks for the link...
I have NOS rockers but the rest of the pieces are Tri-Plus. I'm certainly willing to buy a better fitting piece, thanks for the heads up.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 03-02-2015, 12:09 PM   #728
sduckworth13
Re: Project: Shiro
Buck, I don't know if your familiar with the "L" bracket behind the door pillar. Be careful not to cut into it. When you cut the door pillar try and stay about a 1/2 below the bottom bolt hole for the door hinge and you should be fine. Good luck.
Scott
Old 03-02-2015, 12:22 PM   #729
C10_ustacould
Re: Project: Shiro
Well, I have a problem. My initial assessment says my rust is goes up around this area. As I understand it there is a "cage" that holds the block that the hinge bolts thread into. That must be the "L" bracket you mentioned. Not sure what to do if working in this area will be an issue.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-02-2015, 08:27 PM   #730
sduckworth13
Re: Project: Shiro
Yes, that's what I'm referring to. You should be fine from the looks of where your rust is at.
Scott
Old 03-02-2015, 08:56 PM   #731
C10_ustacould
Re: Project: Shiro
I have pin holes as high as the center between the bolt holes.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-02-2015, 09:09 PM   #732
sduckworth13
Re: Project: Shiro
That sucks. It isn't impossible, just make a tape template transfer it too cardboard. Measure your angles and distances using reference points on the cab. It sounds easier than actually doing it I'm sure.
Scott
Old 03-05-2015, 10:46 AM   #733
C10_ustacould
Re: Project: Shiro
Sentiment of the day…
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-05-2015, 11:16 AM   #734
nlped
nlped's Avatar
Re: Project: Shiro
Uh oh...
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 03-05-2015, 11:22 AM   #735
smbrouss70
smbrouss70's Avatar
Re: Project: Shiro
That'll look good in the back of a white truck. Oh, wait...
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 03-05-2015, 11:49 AM   #736
C10_ustacould
Re: Project: Shiro
Originally Posted by nlped View Post
Uh oh...
I'm indifferent to the truck at the moment. Waiting on my ebfabman videos to arrive, maybe I'll come around after I watch/study them.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-05-2015, 01:01 PM   #737
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Project: Shiro
Buck, I understand where you are coming from. Once I started cutting out rot on Korbin's truck, I got down on it and did not work on it for a time. But, he needed it to get done since it was supposed to be ready for his 16th birthday. Once I got started, I got into a rythm and it went fairly smooth. This board had good reference pics and I knew I could do the work even though I had not ever replaced a rocker. I ended up doing both rockers, cab corners and a complete floor on his truck.
You can do it!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-06-2015, 11:45 PM   #738
C10_ustacould
Re: Project: Shiro
I've listened to a few of the C10Talk podcast and one thing is echoing in my ears, unfinished projects. Dino and Nate both mentioned it in their interviews the number of guys that blow apart their truck and they never come back together. I definitely don't want to be one of those guys. The problem for me is when things don't move quickly I lose interest... well, I don't so much lose interest as I let other things distract me. For instance, right now I am trying to go about the rust repair on this truck the correct way by collecting info and creating a strategy to ensure it turns out well. This has forced me to wait for some information, and waiting is not something I do very well. Blazers are like forbidden fruit for me, forbidden because I want a nice one and they are quite pricey, so I get to trolling the internet and the tire kicking dreamer in me drags me farther away from the intended path. My wife and kids are used to this and do pretty well at nudging me back into reality. Honestly the best thing I could do for my family today would be to sell all of my truck stuff and buy a "new to me" Camaro and ride it, and while I've come close recently I can't bring myself to do it. I just don't want to be one of the guys Dino and Nate talked about who's project never gets finished but right now I'm just fighting to stay on the path. Anyway, thanks for following along, I wear my emotions on my sleeve so to speak so my apologies if the build digresses at times and I ramble on. I appreciate your comments and hope I am able to provide some entertainment as well as some info or ideas that might help you in your C10 journey. Later...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-07-2015, 12:08 AM   #739
boonedogs72
boonedogs72's Avatar
Re: Project: Shiro
I'm right there with you. I always get my projects so close then lose interest and onto to next..... Which why I never finish any of them. Trying to stay off the project hunting path is like kicking cocaine for me. For me the best thing todo is to stay on the project in one way or another. If I'm away for to long than so long and onto the next. Stay at it and keep tinkering that's the best way I have found to keep motivated.
boonedogs72 is offline   Reply With Quote
Old 03-07-2015, 12:11 AM   #740
nlped
nlped's Avatar
Re: Project: Shiro
Keep working on it.
And like Boonedog says...keep on it. I bought out one of his projects
Carter
Old 03-07-2015, 12:19 AM   #741
boonedogs72
Re: Project: Shiro
Haha hope it's coming together ed
Old 03-07-2015, 01:08 AM   #742
Malamute
Malamute's Avatar
Re: Project: Shiro
Yeah, stick with it. I do understand the frustration of thinking you bought one thing and winding up with another but I think you and your son will really be glad that you finished this through.
Malamute is offline   Reply With Quote
Old 03-07-2015, 04:31 PM   #743
Rochlow
Re: Project: Shiro
So I guess I'm one of those guys that Nate and Dino were referring too. I bought a "rust free" truck like you, but found it was anything but. Just like you did.
With that being said Nate and Dino have a ton of support to finish these trucks in a short amount of time. Most home builders don't have those resources. So when it comes to figuring out brake lines, gas lines and pinion angles (some of the things that are rarely spoken about when you buy the products) the home builder struggles in these areas.
I think that Nate and Dino comparing their progress to that of the home builder is like comparing apples to oranges.
I've been working on a truck for three years, that I only thought would take six months. It's been a learning process the entire time. Like others have said, keep muscling through it and it will pay off..
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 03-07-2015, 05:08 PM   #744
Possmguts
Possmguts's Avatar
Re: Project: Shiro
Dont know about you man, but as much as I would like to have mine done in 6 months... its not gonna happen. Just gotta keep pluggin away at it and some day you will have something you can be proud of.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 03-07-2015, 06:22 PM   #745
C10_ustacould
Re: Project: Shiro
Just to clarify, neither Dino nor Nate ever made that comparison. They simply commented on the number of trucks that get blown apart and never get finished, at least not by the person who started the project.
I understand that it takes time to build a quality truck, I don't mind that at all. The problem for me is down time and staying on course when I have to wait. That's when the T.A.D.D. kicks in. The hidden rust issues have exacerbated this for me by adding some fear of the unknown and some down time preparing to fix it. I worked on some other stuff for a few hours today, that will help. Hopefully my ebfabman DVDs will be here soon and I can get the rust repair done and get the body parts to the painter. I'll feel a lot better at that point I'm sure. Thanks for the encouragement.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-07-2015, 06:43 PM   #746
Possmguts
Possmguts's Avatar
Re: Project: Shiro
I havnt even got to the body really yet other than striping the cab, doors and the one fender I plan on re-using. I think the doors are gonna have to go too. The PO replaced the outter rockers, but the inners are rough so the outters have to come back off. Corners have to be replaced and the bottom of the windshield channels are gonna be a *****... both lower corner areas have to be cut out and replaced... Thats the part I will have trouble with. Hell.. I dont even own a welder lol. The bed... thats another story.
Love those "Rust Free" projects.
Old 03-08-2015, 04:54 PM   #747
C10_ustacould
Re: Project: Shiro
Got this pig on the stand today, ready to get a good cleaning and some makeup.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-08-2015, 10:45 PM   #748
C10_ustacould
Re: Project: Shiro
Looking into changing up the induction. At the very least I have to buy a throttle body, but what is we go just a little farther with the efi? What is we go old school with dual 4 barrels? Decisions... Decisions
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 03-09-2015, 09:47 AM   #749
knomadd
knomadd's Avatar
Re: Project: Shiro
That's a tough one. Personally, given those three choices, I'd stick with the factory style intake. I say this only because I'd rather have EFI than carbs on an LS, and I'm not a big fan of that Holley intake. I'm not sure exactly why though. Good luck making your decision.
What about an 8-stack intake like the old Hilborn injection? Like this:
Again, good luck, and keep building!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-09-2015, 10:00 AM   #750
smbrouss70
smbrouss70's Avatar
Re: Project: Shiro
Personally, I think putting carbs on an LS is like putting a Power Glide in a new Z06.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
