10-19-2015, 06:20 PM | #726 |
Re: 48 Burb, bagged, 5.3, 20 year wait
No prob glad to help. Looks like a really cool show.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
10-20-2015, 09:42 AM | #727 |
Thank's for sharing Doug...would love to attend next year if we can swing it!
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
10-23-2015, 05:44 PM | #728 | ||
It is pretty cool. Arkansas isn't that far away. Maybe you can make it next year?
Coolest part is all the projects and hands on. Plus the good people! Thanks again for the lead on the tanks. One of these days I will install them! Mark, would be great if you and Jim could make it! |
10-24-2015, 12:03 AM | #729 |
Your right, didn't realize how close we are. Maybe 8 hours.......
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
11-05-2015, 04:55 PM | #730 |
Doug-
What gas tank are you using? Or is that TBD? I was planning on using a 65 mustang as that sounded like the logical choice for us AD guys, but after looking at the rear brace/body mount. I'm not sure it will fit like it does for the truck guys. I'm also thinking about reworking my stock LS wiring harness. I think that I read that your going with aftermarket...I'm not judging. I might end up going that route myself. Just curious what you figured out. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
11-05-2015, 06:20 PM | #731 | |
Right now I have a vague idea of using a Mustang or Camaro tank from the 60's in the rear and routing the fill over to the sidewall behind the tire then out to the rear fender. Hollister Road Company has some packages for the fill pipes that look promising. One of Crafty B's gas caps would be pretty cool to use. Here is an example https://instagram.com/p/9pQi2MLpa5/ Anyway I haven't puzzled it out too much yet for packaging needs. And I am pretty sure a rear fill will not work unless the tank is really low. I will need to remove or modify the rear crossmember like I did in the truck. And I have a truck frame under my Burb. I thought the rear crossmembers for the truck and Suburban were the same? For the LS harness I will likely use BP Automotive. A good friend who is very talented and does a lot of LS swaps, did modify one stock harness. It just takes so long to make it route and look good he said it was almost as easy to make one from scratch. Getting one from a supplier saves a lot of build time. He has used a number of them from different companies and is currently most impressed with BP. We have a giant "Honey Do" list of stuff for the yard this week end so I don't think I will make the shop....again. Unless it keeps raining! Marc, please throw up some pictures of yours to get me motivated and hungry again! |
11-05-2015, 08:27 PM | #732 |
I hope both of you guys have better luck with the LS swap then I did.
I pulled my 2nd harness and PCM out and starting over with a MSD efi system. This way I can tune this myself using a handheld that comes with it. Finding anyone who can tune these I have found out are either full of BS or are booked out 6 weeks. Everything was going great until I got to sea level on a day in the 40's. The tune that was in it didn't like that combo and would barley run....MSD should fix that. Have a something similar on my truck but it is a throttle body. No issues at all. |
11-05-2015, 08:42 PM | #733 |
Ephesians 2:8
Doug I need to come down some Saturday and help you out in the shop. We'll have to see what winter brings.
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
11-05-2015, 08:54 PM | #734 |
Iceburgh, that is too bad. Hopefully the MSD will work well. I don't remember, was your engine stock? I've had very few problems with the LS in my 56 though it is a stock 5.3.
Brad, that would be awesome! You are welcome anytime. I really need to piece my front radiator support together to see if my accessories will fit. Hopefully I don't need to slide the engine back more and want to verify. And then lift the body again to install the air tanks on the outside of the frame. And then...and then...etc infinity. |
11-05-2015, 10:46 PM | #735 | |
Funny you mentioned Crafy. I'm very familiar with him. His shop is 40 minutes north from my house. Every summer he has an open house and last yr I drove my 48 to it with some friends in there hot rods. It was very cool. Yes, I thought of selling my stock harness to put the money towards an aftermarket harness. I was surprised by how much they sell for. With aftermarket you can also have the length such that you can better hide the computer. I might have gotten a big parts delivery, but have been asked to hold off on pics for a bit. Shhhhhhhhhh. I'm very stoked by the quality. I will try to update with some pics of some of my progress. Marc
11-05-2015, 10:51 PM | #736 | |
As for tuning. My friends (Dutchboys Hotrods) who build high end grand touring cars with modern LS motors use a company close to Grand Rapids MI called Baker Engineering. They have a really good rep with that car scene. http://www.bakerengineeringinc.com/ Marc
11-05-2015, 11:00 PM | #737 |
Very cool Marc...Understood and looking forward to pic's. I actually Discovered Crafty through your build thread when you went to one of his gatherings.
11-05-2015, 11:19 PM | #738 | |
Something similar to this..... http://www.ebay.com/itm/Weld-In-Flus...-/201223023622 Marc
11-06-2015, 04:21 PM | #739 | |
These work great.
My Build: 57 Chevy Pro-Street |
11-07-2015, 10:45 AM | #740 |
Very cool looking gas fill solutions guys. Thanks for sharing. Here is one of Crafty B's caps.
Marc - what are the stock harnesses going for? I figured they weren't worth much. |
11-07-2015, 04:51 PM | #741 | |
I took my son Austin out in the camaro for some burn outs before I rip the motor out. I'm impressed with the power of a stock LS1. He enjoyed that. At one intersection we whipped it around and did 2 dounts. I also degreased the motor and washed The camaro to get some pics for listing it for sale after I pull what I need. Hey what exhaust manifolds work best with the stock frame? Marc
11-07-2015, 05:55 PM | #742 |
I am going to try Camaro manifolds to see if they fit. May need to angle mill them like Farmer Sid did, which will kick them in toward the block a little more.
Thanks for the bounce back on the harness. |
11-23-2015, 09:50 PM | #743 |
Wow that looks like a very cool class...... I want to thank you for that link I'm sure I can't do it so I'm going to a friends to night and see if he can do it. Your Burb is cool I need something in that body style ...
11-23-2015, 10:29 PM | #744 |
Have you tried the Camaro manifolds yet?
Posted via Mobile Device |
11-23-2015, 11:14 PM | #745 |
You are welcome blake. Hopefully it will work out for you. We like this body style burb and a few guys on here are building them. Actually, mine has been in super slow motion build for awhile.
11-23-2015, 11:22 PM | #746 | |
Anyway, they looked pretty close on yours after the angle mill, so I am thinking mine might not fit. I was in the shop getting some of this other stuff fixed and I was pretty sure the 48 Burb was kinda miffed.... |
11-24-2015, 12:07 AM | #747 |
dang your string of problems sounds like my whole life!!! its always something, always a fight. Hope you get back on it soon.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
11-24-2015, 12:20 AM | #748 |
Thanks 99, I call that being in the broke vortex, when everything around you breaks, consuming all your time, energy and money. It happens from time to time and is magnified by having so many vehicles. At least the house appliances are behaving... for now.
Oh yeah, the Grasshopper mower is burning oil and will be overhauled this winter. Should be good for a long time since it only has 1,350 hours on it. |
11-24-2015, 12:48 AM | #749 |
Doug, just be happy that you have the skills to repair all that stuff. Don't blame the 48 Burb for being miffed, get back to work...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
11-24-2015, 08:43 AM | #750 |
I will be getting my hooker headers tomorrow so I will post a picture to compare the two.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
