Old 01-14-2016, 08:39 PM   #726
Kim57
Kim57's Avatar
Re: Dutch '59 Fleetside Longbed
Nice lights.
More sound deaden-er can't be a bad thing.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-15-2016, 12:21 AM   #727
oldman3
oldman3's Avatar
I agree with Kim, never hurts to cover everything...Jim
oldman3 is offline   Reply With Quote
Old 01-15-2016, 04:33 PM   #728
RockinKees
RockinKees's Avatar
Yeah, that's what I thought too...
Thanks!
Maybe this is a better pic, it goes all the way up, till under the "dashcover".
Also put in the switches and gauges, because I wanted to see how it looked
I think it's not too bad..
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 01-15-2016, 07:15 PM   #729
ptc
ptc's Avatar
Nice!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 01-15-2016, 07:37 PM   #730
Kim57
Kim57's Avatar
Very nice.
Kim
My build thread
Old 01-16-2016, 08:21 PM   #731
RockinKees
RockinKees's Avatar
Well, grill is ready
Cheers!! Kees.
Kool Guyz CC
Old 01-17-2016, 12:09 AM   #732
oldman3
oldman3's Avatar
Looks good...Jim
Old 01-24-2016, 03:45 PM   #733
RockinKees
RockinKees's Avatar
Thanks Jim!!
Over the past week I was thinking about a new fusebox panel.
One that was a bit better than the first one I made.
I came up with this:
Made a template out of cardboard, testfitted it in the truck. It's going to be at the same place, drivers side, under the dash.
I had a piece of aluminum which I could use, so I made it flat and made the hole in it for the relays and drilled it for the fuseboxes.
Next I wired it as far as I could out of the the truck.
The plan is to use 22 circuits and 15 relays (!).
I have seperate lowbeam and highbeam and seperate left and rightsides, that alone are 4 relays...I always had trouble with my Chevy Van lights, I want to be ahead of that!
So maybe it's overkill, but it's much easier to locate failures in the future
I did this the same way with my old '67 Volvo at the time, and also do the same when I wire Harley's (not so much circuits thou )
I make partial diagrams of all circuits, that way I can always find it back, should I need it...
Cheers!! Kees.
Kool Guyz CC
Old 01-24-2016, 06:41 PM   #734
Kim57
Kim57's Avatar
That looks good.
Kim
My build thread
Old 01-24-2016, 07:15 PM   #735
Advanced Design
Advanced Design's Avatar
Well that is pretty trick! Intimidating and cool all at the same time.
Advanced Design is offline   Reply With Quote
Old 01-24-2016, 07:51 PM   #736
oldman3
oldman3's Avatar
Well done Kees, nice job...Jim
Old 01-25-2016, 12:16 AM   #737
lower50's
lower50's's Avatar
That should work nice.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-26-2016, 02:39 PM   #738
RockinKees
RockinKees's Avatar
Got a few hours at the truck today
Painted the doors black, that can dry until I put the red on, big steps for me
Sorry for the crappy pic...
Also bolted the new fusepanel in to see how it would work out...
Here you can see that the relays are somewhat bent, so that they're more horizontal:
If you look out of the driverseat, you can hardly see the fusebox (please don't mind the rest of the mess, there's work going on )
Cheers!! Kees.
Kool Guyz CC
Old 01-26-2016, 03:32 PM   #739
reaper71
reaper71's Avatar
Nice and clean..
reaper71 is offline   Reply With Quote
Old 01-26-2016, 05:00 PM   #740
Kim57
Kim57's Avatar
Very nice.
Kim
My build thread
Old 01-27-2016, 03:22 PM   #741
ptc
ptc's Avatar
Looking Good!!! ----- I hope you are going to move the "RED-LINE" on that tach up to about 6500 RPM.... FLOOR IT!!!!
Old 01-27-2016, 06:11 PM   #742
RockinKees
RockinKees's Avatar
In my mind I don't have a RED line....
But the engine might think otherwise
Cheers!! Kees.
Kool Guyz CC
Old 01-29-2016, 05:31 PM   #743
RockinKees
RockinKees's Avatar
Doors are ready for built-up, at least when the paint is dry
After the red was done:
There's going to be a small white pinstripe between the black and red, but just after the doors are hanged.
In the meantime I've been busy with the electrics:
This is how it looks when you do your own wiring
Don't worry, everything is gonna be just allright!!
Cheers!! Kees.
Kool Guyz CC
Old 01-30-2016, 12:03 AM   #744
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
Old 01-30-2016, 06:16 AM   #745
RockinKees
RockinKees's Avatar
Question:
When I bought the truck and looked at the wiring then, which was a mess, I noticed that the ground wire from the battery only went to the engineblock.
And from the block to the cab with a ground strap.
Is it not better to wire the ground wire to the block AND to the cab??
I don't know how it was originally?
Please explain?
Thanks!
Cheers!! Kees.
Kool Guyz CC
Old 01-30-2016, 06:43 AM   #746
Advanced Design
From the block to the cab with a good grounding strap of sufficient size and good connections will be fine. I would have a good ground to the frame as well.
Heaviest electrical load is when cranking the engine over, so the negative battery cable is on the block to handle the heavy amp load. Amp flow from everything in the cab isn't near as much so a heavy cable isn't needed.
I hope that helps answer your question.
Old 01-30-2016, 06:56 AM   #747
RockinKees
RockinKees's Avatar
Yes, that sure helps!
Thanks Doug!!
There wasn't a ground wire to the chassis as well. I never thought of that too, I must say.
I know my old Chevy Van had a big wire (35 square) to the engine and a small (6 gauge) to the cab from the battery.
And ofcourse a real ground strap from block to cab.
Thats why I asked.
Cheers!! Kees.
Kool Guyz CC
Old 01-30-2016, 10:42 AM   #748
reaper71
reaper71's Avatar
When me and Dad do wiring we always use a grounding block.
You run your main ground to it and it has multiple connections that you can now run all of your grounds to it rather than running grounds to the body etc.helps prevent a "bad ground" situation.
The 1st pic is of a ground stud (main ground mounted to frame)
the 2nd is the ground block or strap run the wire from this to the stud making it a ground and then simply run All grounds to the strip.
Mark...
Old 01-30-2016, 10:43 AM   #749
reaper71
reaper71's Avatar
Usually from Ron Francis wiring
Old 01-30-2016, 05:18 PM   #750
RockinKees
RockinKees's Avatar
Thanks for the tip Mark!
I do something similar, only I make studs on the sheetmetal inside the cab. First the paint has been removed, then a bold with those washers with teeth (don't know the word...) at both ends, then a nut.
The groundwires bolts then right on.
Cheers!! Kees.
Kool Guyz CC
