01-14-2021, 01:10 PM | #726 |
Re: 1971 Stepside LS Build
Now we've got a fully assembled truck! Can't wait to see some pictures outside and see the complete interior.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
01-14-2021, 02:57 PM | #727 |
Your floor is too dirty for that pretty truck.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
01-14-2021, 03:38 PM | #728 | |
Almost Satisfied
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
01-14-2021, 04:35 PM | #729 |
Almost Satisfied
Went home to meet the guy that sprayed the finish on my bed wood. The sun was out, so I backed the truck out and tried to get a couple pics.
01-14-2021, 05:01 PM | #730 |
Hard to say anything other than "wow!" That looks amazing man. Really really phenomenal build!
01-14-2021, 05:06 PM | #731 |
Wow! Just a beautiful truck. Congrats!
01-14-2021, 09:41 PM | #732 |
Shoooo-wee that's purdy! Congrats, you're gonna have a great summer!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
01-15-2021, 02:10 AM | #733 |
Wow that looks amazing! Your buddy’s shop did a great job on the paint. It’s going to get a lot of rubbernecking from other drivers for sure!
01-15-2021, 10:57 AM | #734 |
looking good in the sun! Good to see it coming all together.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
01-15-2021, 01:19 PM | #735 | |||||
Almost Satisfied
01-17-2021, 02:04 PM | #736 |
Looks great, hope to see it out and about.
01-17-2021, 04:53 PM | #737 |
I'm trying....
Fantastic. Looks great. Well done. Congrats on an outstanding result.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
01-19-2021, 11:28 AM | #738 |
Almost Satisfied
I wanted to hide the bed bolts that bolt the bed to the frame so I had made provisions in the wood to allow space for the heads of the bolts, but hadn't really decided the best approach on how to keep them from turning when I tried to tighten them. I opted to use carriage bolts as they sat a little lower. I squared the bed up and put the bolts in and tried to tighten one without the bed wood in place to see what I would get. Every single one of them tightened without turning! I then studied the thing and decided that I could probably put the bed wood in with the bed on the truck knowing that the bolts over the Boyd tank would be the hardest. I figured if I worked the two center boards first I could get my had under there to get the nuts on. I'm going to now tell you that I need Jesus more because I lost my twice and ended up dropping the tank down to finish them up. Of course the tank then fought me to go back in place, so again I went postal at 10:30 p.m.
The next day I was sore and bruised up, but I won! Put the remaining bolts in the bed and decided that I would never do that again.
01-19-2021, 11:34 AM | #739 |
Almost Satisfied
I also tackled the cowl over the weekend. It wasn't too bad. The wife is becoming a regular truck builder as she helped me set it on the truck. I really like the screens, but I am pretty disappointed with the fit of the cowl to the door on the drivers side. I'm probably going to end up pulling it off and make the shop re work it. It looks worse from the drivers door looking forward.
01-19-2021, 12:36 PM | #740 |
Haha I feel your pain on the bedwood. It seems like no matter what your bed floor is (wood or steel), it is a struggle with the tank in place. I decided on our current truck that we need to make the tank easy (a relative term) to drop because it's so difficult to get to the bed bolts and bumper bracket bolts with it in place.
I'm sure you have one, but what's on your to do list to get to 100% completion?
01-19-2021, 01:08 PM | #741 | |
Almost Satisfied
Horn working Wipers Installed AC line o-rings installed AC charged AC vent hoses ran under dash Radio antenna installed Rear lights wired Drill holes for additional seat bolts (Snowden only hits 4 of the 8 original spots) Program Dakota Digital Carpet and final upholstery work (scheduled) Final install on steering wheel Alignment Final Tune I have a power drain in the right side door jamb switch that needs to be fixed and several other small tweaks, but it is getting pretty close.
01-19-2021, 01:37 PM | #742 |
I have a suggestion for you - make sure you have your wiper transmission installed right (for the correct wiper rotation and parking) before you put on the blades. I had mine on wrong the first time and had to pull the wiper arms back off (which is not easy if you don't have the tool) and scratched my cowl in the process.
01-19-2021, 01:46 PM | #743 | |
Almost Satisfied
01-19-2021, 05:23 PM | #744 |
Looking great. Hiding those bolts is a really good clean look. Surprised the body shop missed that bad of alignment on the cowl...
01-19-2021, 05:43 PM | #745 | |
Almost Satisfied
01-21-2021, 11:46 AM | #746 |
Almost Satisfied
Hinges finally came in. They look to be built really nice with a lot of adjustment. Now to get the hood back off and get them installed.
01-21-2021, 09:53 PM | #747 |
Ooh, those are slick! What Brand? Can't wait to see this thing. Are you going to the Shindig?
01-22-2021, 11:19 AM | #748 |
Roto Reuter thats the name...
Looks great! Has to be a good feeling to be at the point you're at.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
01-22-2021, 03:41 PM | #749 | ||
Almost Satisfied
01-22-2021, 06:42 PM | #750 |
Hey great story and great work on the truck, I bet you are really glad to have it to this point. Can you post the website for the hood hinges?
Thanks. Wally |
