Old 11-28-2021, 05:40 PM   #726
Vic1947
Vic1947's Avatar
Re: 57 Chevy Wagon - Californa Dreamin'
Got sidetracked a bit. A member of another forum suggested that it might be a good idea to add a heat shield around the cats to protect the transmission and floor pan from the high heat. Seemed like a really good idea, so I got to work.
I have the heat shield on one side complete and installed. Haven't started on the other side yet. Kathy asked me to assemble her new Christmas tree and fix a couple of her music boxes she sets out for the holidays. That takes precedence over car stuff this time of year.
I didn't have a piece of stainless sheet in my scrap bin big enough to make the shield in one pass, so I sandwiched two pieces together. It's .037" thick material so it will probably twist up like a pretzel when it gets good and hot, but it should be sufficient to serve as a barrier to the heat radiating from the cats.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 11-29-2021, 10:41 AM   #727
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks good Vic!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 11-29-2021, 07:53 PM   #728
Vic1947
Vic1947's Avatar
Originally Posted by Ol Blue K20 View Post
Looks good Vic!
Thanks, Dale. Driver side shield is now complete also. Time to let it down off the jack stands.
Victor
Old 11-30-2021, 12:06 AM   #729
Low Elco
Looks great, Vic!
Low Elco is offline   Reply With Quote
Old 12-04-2021, 11:57 AM   #730
Vic1947
Vic1947's Avatar
Originally Posted by Low Elco View Post
Looks great, Vic!
Thanks Chip, I'm making progress.
A buddy sent me this which explains a lot if you cut your teeth on a stick shift.
Victor
Old 12-04-2021, 01:53 PM   #731
mongocanfly
Post Whore
mongocanfly's Avatar
Haha...that's a good one..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-17-2021, 12:36 PM   #732
Vic1947
Vic1947's Avatar
So, a couple of weeks have passed during which I finished up the do-over on the EFI. The Terminator X Max controller just barely fit into the space where the other controllers sat in the past. I not only had to build stand-offs to position it further away from the firewall, but also had to machine some long hold downs to attach it. Couldn't get my fingers into the available space to start regular nuts. But after all that, it's in and wired up. I also spent some time revising the fuel lines. None of the lines fit after I modified them for the dual quads. The upside is that I repositioned the regulator and fuel pressure gauge for better access. I tested it for leaks and to my surprise, I didn't have a single one. Usually, there's at least one fitting that requires a bit more oomph to seal it up.
I had a local Holley expert, Andrew Borodin, over to the house last week to help me with the initial startup calibration. He also gave me a wiring diagram for the IAC kick and AC shutdown relays. The software will temporarily boost the idle when the AC is turned on and shut the AC off at a specified throttle position (like 75% WOT). He spent about an hour going over the fuel and spark tables explaining them and making some tweaks. My short-term memory is so shot that I don't remember a lot, but I was impressed with his knowledge. He'll be back when I'm ready to fire the engine the first time with this new setup. Said it will take another hour to tune the engine for best performance. It's turned cold so I'm planning to wait for the next warm day.
Meanwhile, I have a new project to keep me occupied. I decided to punch louvers in the side panels I made for the inner fenderwells. I'm thinking ahead to the summer and doing all that I can to help lower the under-hood temps. I did some research on commercially available dies and they're pretty proud of them. While online, I ran across a video showing a homemade set of dies and I'm going to give it a try. I only need to punch a couple of dozen louvers, so I don't need tool steel. I'll show you the results - good or bad.
Victor
Old 12-17-2021, 04:43 PM   #733
Ol Blue K20
That's a lot of wires, they make my brain swim looking at them! I can't wait to see the louvers.
Dale
Old 12-18-2021, 04:36 PM   #734
Vic1947
Vic1947's Avatar
What you see isn't even the half of it, Dale. Seems to take me forever to do wiring anymore - plus I need to lean on my brother-in-law and other knowledgeable folks for help. But the good news is that it's all done, and we'll find out soon whether it's hooked up correctly.
Victor
Old 12-18-2021, 10:50 PM   #735
sduckworth13
sduckworth13's Avatar
Looks awesome Vic, wiring job looks super clean!
Scott
sduckworth13 is offline   Reply With Quote
Old 12-21-2021, 01:36 PM   #736
Vic1947
Vic1947's Avatar
Thanks, Scott. I did have one wiring hiccup, but it was easy to fix. Andrew Borodin - Holley tuner extraordinaire - came to the house yesterday and got everything sorted out. We ran into a bad reading from the MAP sensor and when we traced the wires, it turned out that, despite all the research I'd done, the wiring wasn't correct. When I replaced the Gen 3 plug with a Gen 4, I picked the wrong info source for the pin locations. Such is the way of the internet. We used a de-pinning tool to swap the wires into the correct slots and just like magic, the engine cranked up.
After about two hours of shop/driving time Andrew had the engine running like a little sewing machine. The trans works great too. It's hard to tell if the cooling system issues are completely gone because the ambient temperature was much less than it was last summer. However, in the shop, fan 1 would come on briefly and then cycle off less than a minute later. So, the switch to the 11" Spal units seems to have been worth it. On the road, the temp stayed at 183 (180 degree thermostat) and the trans temp never got over 160. Tripling the size of the trans cooler was probably a good move too.
I have a few remaining minor things to do, and then we'll be ready for cruising. Back to my louver project...
Victor
Old 12-21-2021, 03:51 PM   #737
sduckworth13
That’s great too hear, sounds like it will be smooth sailing. You’ll definitely will be bringing home some hardware whichever show you go to with that beauty!
Scott
Old 12-22-2021, 05:28 PM   #738
Vic1947
Vic1947's Avatar
That’s great to hear, sounds like it will be smooth sailing. You’ll definitely will be bringing home some hardware whichever show you go to with that beauty!
Thanks, Scott. From what we've seen so far, people seem to like it - which is what matters most. It was lots of fun this summer talking to folks about the various mods. But most importantly, we have some long-distance road trips planned for this coming summer. Maybe by then, the bug will be in the rear-view mirror, and we can relax and have some fun rubbing elbows with other car nuts.
The louver project is halfway done. The dies are finished, and I tested them on a piece of scrap aluminum. I plan to use the homemade English wheel that I was given by good buddy, Jonathon Cornell. I think I can remove the wheels and locate the dies, so they punch thru the aluminum sheet consistently. I'll post photos of the setup when I've sorted it out.
Victor
Old 12-22-2021, 09:42 PM   #739
Low Elco
If nothing else, there's always A2 and the good 'ol redneck heat-treat. Got any used motor oil?
Heard you got with Andrew, glad it went well and the gorgeous wagon is gonna go down the road!
Old 12-23-2021, 12:29 AM   #740
Vic1947
Vic1947's Avatar
Thanks, Chip. Next up after a few more tweaks will be the World of Wheels in March. Talked to your pops this morning and it sounds like he's rounding up a posse of fellow trucksters to swarm Bartle Hall. Should be a fun get together.
I think the dies will work pretty well for the little dab of work I have planned. My test piece was a louver I cut from a leftover panel I used as a pattern and it's a little ragged around the edges. Below is a louver I actually punched out of a fresh piece of .063 aluminum with the dies I made.
Victor
Old 12-23-2021, 12:50 AM   #741
mongocanfly
Post Whore
That looks great Vic...nicely done
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-23-2021, 09:03 AM   #742
Ol Blue K20
Nice looking set of dies you made. The test louver looks good.
Dale
Old 12-26-2021, 03:05 PM   #743
Vic1947
Vic1947's Avatar
Thanks, guys. I finished my homemade louver press. The "English wheel" I used as the frame for it deflected too much, so I had to tack a piece of channel to the front of it make it solid. If I ever need to use the wheel, I can zip the channel off with a Dremel cutoff tool.
After getting the dies aligned, I punched a test panel. Looked pretty good, so I proceeded to the real thing. Both side panels are now louvered and ready to prep for self-etching primer and a coat of matte silver to match the fenderwells. The anodized finish was pretty close to the rest of the inner fender, but it was hard to keep clean. The painted surface is much more forgiving. Hopefully I can get a decent color match but regardless, it should be better than what I had.
I'm not sure how much the louvers will help, but I don't reckon they can hurt. I believe the best mod I made was the larger, more powerful fans, but summer will be the real test.
Victor
Old 12-26-2021, 06:10 PM   #744
mongocanfly
Post Whore
Very nice!!!!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 12-26-2021, 06:26 PM   #745
Ol Blue K20
I like the louvers a lot....
Dale
Old 12-27-2021, 02:12 PM   #746
Vic1947
Vic1947's Avatar
Thanks!
I put one of the panels in temporarily to see how it looked and I think it works pretty well. Today I'm prepping the panels for epoxy primer and matte silver paint. Weather is a bit cool, but I can spray outside then bring the panels back in to warm up. I have a heat gun setup to force dry them a bit. I'll post pics when I'm finished.
My buddy Chip called me this morning to let me know his dad, Vern, passed away yesterday evening sitting in his easy chair. Vern (or Boppa as many knew him on the forum) was a dyed in the wool truck guy. I talked to him just yesterday and we had plans to go for coffee and sandwiches after the first of the year. Ya never know what the day holds for you when you crawl out of bed. I realize it's a cliche, but we need to treat each day as a gift. I'm going to miss him.
Victor
Old 12-29-2021, 07:47 PM   #747
Vic1947
Vic1947's Avatar
Here are some photos of the finished panels installed. The matte clear I used was still too glossy to suit me, so I used a 2000 grit foam backed pad to knock them down a bit more.
Victor
Old 12-29-2021, 10:38 PM   #748
sduckworth13
Originally Posted by Vic1947 View Post
Thanks!
I’m going to miss him as well Vic.
Scott
Old 12-30-2021, 10:18 AM   #749
Ol Blue K20
Panels look great Vic. Condolences to all BOPPA's family and friends.
Dale
Old 01-18-2022, 01:31 AM   #750
Low Elco
Thanks!
Thanks, Vic. We miss him too. Talk to ya soon.
