04-08-2022, 10:11 PM | #726 |
Post Whore
Re: My Dusty 71 GMCe Electruck
and a while ago I scored this NONE Harbor Freight media blasting cabinet for FREE off of Craigslist from a local Honda dealership, and today I found out why? ha ha
04-08-2022, 10:15 PM | #727 |
Post Whore
first batch of degreased and decruded parts awaits their destiny with the Media Master Blaster aka the MMB
04-08-2022, 10:48 PM | #728 |
Post Whore
mandatory stare and compare, touch ups will be made
04-09-2022, 12:01 AM | #729 |
There’s a lot of videos on the YouTubes about making those cabinets a lot better.
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
04-09-2022, 08:11 AM | #730 |
Very nice! You are gonna love that!!!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
04-09-2022, 10:05 AM | #731 |
Post Whore
yup, thanks I saw one on something called a cyclone where you make one out of a Home Depot bucket and it sits between the media cabinet and a shop vac, so I may try that, but first I will pop the glass out and see how scratched and beat up it is as it's difficult to tell with it installed
04-09-2022, 03:20 PM | #732 | |
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
04-09-2022, 04:39 PM | #733 |
Post Whore
progress not perfection
04-09-2022, 04:42 PM | #734 |
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
04-09-2022, 04:44 PM | #735 |
Post Whore
yes sir, but the lower control arms are still kicking my....
04-09-2022, 04:55 PM | #736 |
Post Whore
and now a little distraction...
so I went to Big Al's house to pick up some random truck parts, I really didn't need nothin' but he's moving and cleaning house (or should I say side yard, ha ha) whilst there looking around I go hey Al, you got any transmission crossmembers by any chance? Big Al [a bit annoyed]: "do you see any, what do you think they grow in the ground!" |
04-09-2022, 04:57 PM | #737 |
Post Whore
you can't make this stuff up folks
04-09-2022, 05:00 PM | #738 |
Post Whore
the price was right [ FREE ] with the purchase of a hood, a Chevy grill, and core support
win/win/win |
04-09-2022, 05:03 PM | #739 |
Post Whore
I figured once I wire wheel all my suspension components, what the he11 am I gonna do with myself, so, I took on this little side project
here it is with the first pass of the wire wheel and... [wait for it] Top Tip: light coat of Phosphoric Acid called Prep & Etch from Home Depot, but please do not use this cheap and highly effective product [and the hidden key ingredient in all them highly marketed rust removers with them fancy labels and commercials], unless you want results Last edited by Gregski; 04-09-2022 at 05:15 PM. |
04-09-2022, 07:29 PM | #740 |
Thread stealing, To the alien, where do you get the self sticky plastic for the sand blast cabinet?
04-09-2022, 08:23 PM | #741 | |
https://www.tptools.com/Cabinet-Inne...rotectors.html
04-10-2022, 10:29 AM | #742 |
Post Whore
Me: no problem, love the participation
but also me: |
04-10-2022, 12:51 PM | #743 | |
04-10-2022, 05:35 PM | #744 |
I changed my gun on my HF blast cabinet to a more efficient and more volume gun. I also switched to a steel tip in replacement of the ceramic tip and it is much more effective and lasts much longer.
What is the secret ingredient in addition to the prep and etch?
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
04-10-2022, 08:50 PM | #745 |
Post Whore
so bad news, good news, sorta bad news
bad news: I recently learned (thanks to this forum: What was this clip on lower control arm for?) that my lower control arms be missin the steering bump stops good news: the greatest 67-72 truck parts suppliers this side of the Missiissiippiee aka Joe & Marie hooked me up with the driver side lower control arm in good nick bad news: it is covered in 14 pounds or road grime, so I gots to clean yet another lower control arm, yay me! on a semi serious note, although I only bought one arm it is enuff for me to use it at a template to perhaps place a make shift bump stop and welder it on (now has anyone seen my 1 1/2" square tubbin' I just tripped over it yesterday!) |
04-11-2022, 12:24 AM | #746 |
Post Whore
can we get back to the electrification process please
that's an inverter (silver box) and a 30 volt bench power supply (white box) |
04-11-2022, 12:28 AM | #747 |
Post Whore
we are using a 30 volt 10 amp bench power supply to safely simulate a high voltage (what eventually will be a 360 volt battery pack) for our first test wheel spin (with the vehicle off the ground)
the silver box aka the inverter has two components inside of it, the top half is a DC to DC boost converter in the actual Lexus it was there to take the 280 volts from the battery pack and boost it to 650 volts (I know very impressive) when you do an EV Conversion using this Lexus transmission/inverter combo you need to bypass this DC to DC boost converter and wire in your 360 volt battery pack right below it directly into the high voltage bus bars like so |
04-11-2022, 12:30 AM | #748 |
Post Whore
in this video I go over how to wire up the minimal electric components needed to get the rear wheels to spin
GMCe EV Conversion First Wheel Spin Part II of II |
04-11-2022, 07:12 AM | #749 |
It's alive!
04-11-2022, 02:04 PM | #750 | |
Post Whore
