Old 01-31-2013, 10:54 PM   #751
Kim57
Kim57's Avatar
Re: My 57 Pro Street
Well I finally made a little progress on the frame.
Got started on the front suspension.
Upper and lower control arms and springs are in. Still need to decide on what shocks I will be using. The rubber hose is there until I get it on the ground with some weight on it so the upper arms wont hit the frame.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-31-2013, 10:56 PM   #752
Kim57
Kim57's Avatar
A couple more pics.
I also got the brake brackets mounted.
Kim
My build thread
Old 01-31-2013, 11:33 PM   #753
oldman3
oldman3's Avatar
Kim, that is looking so sweeeet...Jim
oldman3 is offline   Reply With Quote
Old 02-01-2013, 04:39 AM   #754
Daze57
Daze57's Avatar
lookin very very good !!!!
Daze57 is offline   Reply With Quote
Old 02-01-2013, 06:38 AM   #755
solidaxel
solidaxel's Avatar
WOW, a lot pieces coming together. and to think you are going to cover all this work up with the body ! Maybe another look at the saw horses and total weight !
I love this part of the build!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-01-2013, 11:59 AM   #756
Kim57
Kim57's Avatar
Thanks.
It will be coming off the tall horses before I add anymore parts to it.
They did make it a lot easier to work on it though.
Kim
My build thread
Old 02-01-2013, 12:39 PM   #757
Kabwe
Certified Car Nut
Kabwe's Avatar
Looking good Kim, looking really good. Good job buddy.
Kabwe is offline   Reply With Quote
Old 02-01-2013, 01:30 PM   #758
Task Force Era
Task Force Era's Avatar
Man this thing is gonna be soooooo sick!! I'm in on it!! Good luck man!!
Task Force Era is offline   Reply With Quote
Old 02-01-2013, 02:30 PM   #759
Kim57
Kim57's Avatar
Thanks Bam.
Thanks for looking.
Kim
My build thread
Old 02-01-2013, 06:09 PM   #760
hotrod1
56 - autocross
hotrod1's Avatar
Hey Kim:
Thought about fuel and brake lines? What are you going to use (aluminum, stainless, steel, etc.) and size?
hotrod1 is offline   Reply With Quote
Old 02-01-2013, 08:02 PM   #761
Kim57
Kim57's Avatar
Originally Posted by hotrod1 View Post
Hey Kim:
I'm using 3/8 steel lines for the fuel and 3/16 steel for the brakes.
I used braided steel from the tank into my pre-filter and pump and then hard lines from there to the front of the frame. I'll use braided steel from there to the engine fuel rail.
Kim
My build thread
Old 02-01-2013, 09:07 PM   #762
hotrod1
56 - autocross
hotrod1's Avatar
They look clean. Where did you get the steel lines? Were they straight or coiled when you got them? What did you use to bend, flare, and cut them? I have talked to a lot of people and get the gammot of "u should use stainless, aluminum, stainless cracks, aluminum is too soft.....etc. I am thinking that steel is the way to go. That is what they use in most cars.
Old 02-01-2013, 10:00 PM   #763
Dan in Pasadena
Dan in Pasadena's Avatar
So Kim, did you end up putting 2 or 3 coats on the frame? You mentioned earlier using a small roller. I did that on a small bench top project I did and even on that the paint starts to get tacky or kinda "thread-y" half way through the job. I'm wondering how it worked for you? I waited the full 7 days and put a second coat and that stuff gets pretty damn hard.
Dan in Pasadena is offline   Reply With Quote
Old 02-01-2013, 10:07 PM   #764
Kim57
Kim57's Avatar
It's the standard steel lines you can get at any auto parts store. I get the straight lines that already have the ends on them then I only have to worry about flaring the ends I cut off. You can get them in various lengths up to 5'. I didn't get the coiled ones because I didn't want to have to get a tool to straighten them.
I use tubing cutter and a flaring tool that will do double flares.
You should be able to get them at any auto parts store.
Hope this helps
Kim
My build thread
Old 02-02-2013, 12:27 PM   #765
_Ogre
_Ogre's Avatar
frame looks good kim.
i enjoyed the frame fab portion of my build.
not much block sanding on the frame
shop air compressor timer
Old 02-06-2013, 08:15 PM   #766
Kim57
Kim57's Avatar
Well I'm getting close to having the frame done so I'll have to get on the body.
Kim
My build thread
Old 02-06-2013, 08:19 PM   #767
Kim57
Kim57's Avatar
Just a little up-date.
Got the rear end all together. I used SS straps to hold the brake lines.
Hope to have it in the frame by the end of the week.
Here are a few pics.
Kim
My build thread
Old 02-06-2013, 08:58 PM   #768
Denee007
Denee007's Avatar
omg~ unbelieveable!
'72 Ford Bronco project(July 17 2021-?)
https://67-72chevytrucks.com/vboard/...d.php?t=828015
59 Apache (sold 6-25-2021)
67 Ford Mustang (re-restored after Harvey)
1968 Jeep Cj5 (2-8-2020 to present)
1992 Jeep Yj (8-17-20 to present) (Jurassic build)
www.Classiccarsandtools.com
Denee007 is offline   Reply With Quote
Old 02-06-2013, 09:00 PM   #769
northern 85
northern 85's Avatar
Nice work!!!!
northern 85 is offline   Reply With Quote
Old 02-06-2013, 11:44 PM   #770
oldman3
oldman3's Avatar
That is super nice...Jim
Old 02-07-2013, 01:41 AM   #771
Kim57
Kim57's Avatar
Originally Posted by Denee007 View Post
omg~ unbelieveable!
Originally Posted by northern 85 View Post
Nice work!!!!
Thanks guys. I appreciate the kudos.
Kim
My build thread
Old 02-07-2013, 06:58 PM   #772
Kim57
Kim57's Avatar
Well the rear is in.
Next will be the plumbing.
Kim
My build thread
Old 02-07-2013, 07:05 PM   #773
hotrod1
56 - autocross
hotrod1's Avatar
Hey Kim:
Where did all this energy come from all of a sudden? That looks GREAT!
Old 02-07-2013, 07:35 PM   #774
oldman3
oldman3's Avatar
That is so sweeeeeeet. Who's coil-overs are you running and spring weight??...Jim
Old 02-07-2013, 07:37 PM   #775
Kabwe
Certified Car Nut
Kabwe's Avatar
Look grrreat.lol Nice work buddy.
