Old 02-13-2011, 03:13 PM   #751
watahyahknow
watahyahknow's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
i was wondering if i was trown out of this topic for a while since it got so quet
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 02-13-2011, 06:51 PM   #752
cam.man67
cam.man67's Avatar
Wow, I just stumbled across this topic today, and let me say I am IMPRESSED! That thing is gonna go like the stink when finished. Kudos!
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 02-15-2011, 02:08 PM   #753
Frizzle Fry
Frizzle Fry's Avatar
Thanks for checkin in guys. I'm back from more travel. Been getting my butt-kicked by the lower/rear coilover bushings (not worth explaining). But I'll work through it. Hopefully make enough progress to justify new pics this weekend.
Frizzle Fry is offline   Reply With Quote
Old 02-21-2011, 12:45 AM   #754
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Weekend is over dude!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 02-21-2011, 12:58 AM   #755
dammitmitchell
the pollock
dammitmitchell's Avatar
AHEM frizzle...
it is hard to live vicariously through your productivity when there is none.
jeesh now i have to go out to the shop tomorrow and get some crap done.. thanks..! NOT hahaha
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 02-21-2011, 01:33 PM   #756
Frizzle Fry
Not for me
Originally Posted by dammitmitchell View Post
AHEM frizzle...
I have been making some slow progress on the rear suspension. My goal is to get it down off the jack stands and on her feet so I can check out that stance!
I dropped my "shop camera" and it went on strike, so have not been taking as many pics... But I'll post some tonight
Old 02-22-2011, 02:25 AM   #757
Frizzle Fry
Pics taken of rear susp work today. SD card reader isn't cooperating. Will try again tomorrow.
Old 02-22-2011, 04:29 PM   #758
Frizzle Fry
Here we go!
Where to start... Well, I calculated the optimal mounting angle for the coilovers at 7*. I considered several lower coilover mount designs and eventually landed on the simple approach of directly saddling the lower links.
With that lower position I had to do side-notch the "frame" for clearance in order to achieve the 7* mount angle.
Here's the driver's side notch and scab plates (don't mind the burn-through ...it will be closed up)
Passenger side notch (old shock mount not fully cleaned up yet)
Notches from below - DS:
PS (those are 1/8" plates bent on the press brake)
Coilover placement - The lower links to the axle housing will use Del-Sphere pivot joints so side-to-side axle articulation will not cause binding with this lateral lower coilover mount bushing:
What's left of the S2000 tower (removed w/ a 5" holesaw)
Beginning of template:
Old 02-22-2011, 04:50 PM   #759
VA72C10
VA72C10
VA72C10's Avatar
Looking good! So when are you going to be carving corners with this sleeper?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-22-2011, 05:19 PM   #760
Frizzle Fry
This summer!
Old 02-22-2011, 10:36 PM   #761
dammitmitchell
the pollock
wow... impressive again!.
way better then just dropping a tubechassis into it and tying into the sub frame..
once again super impressed... freaking show off hahaha
Army vet 02-08
Old 02-22-2011, 10:43 PM   #762
watahyahknow
in hindsight i think a space frame would've been easier still easier i he hid it inside the door jambs and pillars compared with Wat he did so far
pretty amazing stuff , I'm going to wonder if the flexing of the body will affect the ride in anyway , you might end up installing some stiffening plates after driving it for a while
Old 02-23-2011, 01:35 AM   #763
454_72_4X4
454_72_4X4's Avatar
Just wondering here.
Is your plan to attach the lower mount directly to the lower link?
I know you've probably thought it out and feel safe with it but my overkill nature says that's not a good idea. That will be putting the entire weight of the car, (plus any other vertical stresses), on that threaded link end?
I'd think it'd be a lot stronger to extend the "ears" of the link bracket, (welded to the rear end housing), forward to mount the lower part of the coilover? Looks like there's room to do that and still keep the mounting point really close to where you have it now, just mounted to the rearend housing instead of the lower link.
Forgive my butchery of your art. LOL I'm sure you can make it pretty in steel!
Ya know, I hate 4 doors, 4 cylinders, and ricers, but I love this car! Absolutely great work FF!
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 02-23-2011, 02:38 AM   #764
Frizzle Fry
I guess three wrongs make a right?
I hear what you are saying, but using lower links as lower spring or bag mounts is not a concept I can claim as my own. Here are a few examples:
It is a 3/4-16 thread with a good 1.5" threaded into the link. The lower links are 1.25" stainless with thick walls (don't have the exact wall thickness handy).
In sticking with my theme of using "bolt ons" from the S2000 and to overcome packaging limitations in doing so, this was the cleanest/simplest solution.
Since the mount is all the way to one end I see no need for reinforcement of the tube as I would if it were closer to the center.
[IMG]http://www.*****************/jason/images/c10sc55.jpg[/IMG]
[IMG]http://www.*****************/jason/images/c10sc58.jpg[/IMG]
Old 02-23-2011, 03:36 AM   #765
454_72_4X4
454_72_4X4's Avatar
Yea, I gues it does! Hahaha In this case anyway!
Yep, but on all those, (except the last one), the link is welded on the stress bearing end.
I'm not an engineer by any stretch, but spherical rod ends, (or any threaded end link style), are designed for push/pull strength. I know there's a word for this but I can't find it in my head....LOL)
Putting the stress 90 degrees to the direction of the threads, (insert another one of those technical words here), is a bolt's weakest point, (or link in this case).
Personal example;
I have a Yamaha 4 wheeler with aftermarket extended width a-arms on the front. The a-arms use Volkswagon tie rod ends for ball joints. Those tie rod end are just not designed to be stressed that way and I've broken 2. The second one broke at about 60-70 mph across a pasture. It really got my attention when the a-arm dropped and started plowing dirt! Luckily the pasture was good and hard or I might by typing this with my teeth from the comfort of a wheeled chair... Hahaha
I've since redrilled the a-arms to use bigger Ford courier tie rod ends....Still tie rod ends but at least bigger...
Don't mean to sound like the "safety police"... LOL Like I said, I just have a overkill fetish.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 02-23-2011, 03:55 AM   #766
Frizzle Fry
I appreciate it and welcome the feedback. I'll have to consult some "experts." Perhaps drill/tap and go to a bigger rod-end when I change over to pivot joints.
In cardstock:
Transfer to 1/8" plate via plasma:
Box welded up (inside and out) and set in place:
Buzzed in:
Supporting itself!
Under shot:
Old 02-23-2011, 04:00 AM   #767
VA72C10
VA72C10
VA72C10's Avatar
Awesomeness!!!
Old 02-23-2011, 11:30 AM   #768
Tagg33
Tagg33's Avatar
nicely done, great progress!
Ryan
84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s
My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328
Tagg33 is offline   Reply With Quote
Old 02-23-2011, 04:04 PM   #769
Frizzle Fry
Thanks guys. Feels good to make some real progress. Can't wait to see it back on all four. Here's the cliff's notes version of the tower fab:
Old 02-25-2011, 11:25 AM   #770
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
I guess it IS only metal...
Nice work again!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 02-28-2011, 04:05 PM   #771
thor
thor's Avatar
Here we go!
Any plans to reinforce the side-notch? I know you said you used 1/8" plate for the notch but the remainder of the frame looks a wee-bit thin. Then again, it all looks like unibody so perhaps it doesn't matter as much? Perhaps a strut tower brace will help? Just throwing out ideas.
BTW - I had no idea that stock S2000 coilovers came with resevoirs. In the aftermarket that is big money, or atleast twice the cost of coilovers without reservoirs. Very cool!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 02-28-2011, 04:58 PM   #772
dammitmitchell
the pollock
http://www.geekologie.com/2011/02/ch...s_own_scra.php
Army vet 02-08
Old 02-28-2011, 06:31 PM   #773
watahyahknow
hmmmm that would make a great yardornament , might even keep away salesmen and family in law if you can operate the turret remotely
(come on punk..... make my day )
Old 02-28-2011, 06:54 PM   #774
Frizzle Fry
Honda wasn't messin around when the built the S2000. High end stuff throughout. The car is a unibody as you pointed out. Those rails are still plenty strong for the purpose they serve.
Haha, don't give me another distraction...
Would be a sweet security system indeed!
Old 03-03-2011, 02:40 AM   #775
Frizzle Fry
Well, just three days short of the 24 month mark for this thread (the project is actually past that by a couple months already )...
It's down off the jack stands for the first time!
well kinda, but first...
The right rear tower - Got so excited to see it down on the floor I forgot to get finished shots ...but if you've seen the other side you've might be able to imagine what it looks like:
Lower coilover mount:
Tried to get tires mounted today but they were back ordered ...
No matter, I had to see the stance!
Could go a tad lower but that's far better than being too low to begin with. Spring rate feels a bit high so I'll likely get lighter coils which may bing it down some. I'll wait to see how she sits with everything back together, fluids, etc, and some break-in miles. But for now...
