Old 01-14-2013, 10:46 PM   #751
shortbed70
shortbed70's Avatar
Re: MY build thread...
Originally Posted by baggedbigblock View Post
Troy, what paint did you use for the flat black? how is it holding up in the sun/rain/elements? was it sprayed at once and uniform? Thanks.
BTW Truck is sounding good!
Thanks. The black is eastwood's rat rod black SS and it was sprayed in several pieces. Fenders, hood, cab and doors, bed last. It seams to be holding up well a few scratches from people's kids running around it but not bad... Doesn't sit outside much only at shows! The paint is pretty easy to lay when in good lighting but easy to stripe if in bad lighting.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 01-17-2013, 09:05 PM   #752
shortbed70
shortbed70's Avatar
Well took a short drive tonight and other than a small powersterring fitting leak no problems engine wise BUT I have an issue with my dash lights and blinkers! My dash lights are always on when key is on and my blinkers light up but don't blink! Ideas on where to start?
Troy
Big Red Dog build
Old 01-17-2013, 11:43 PM   #753
McMurphy
McMurphy's Avatar
Check to see if you dont have one of your wires grounded that shouldnt be. If you are running stock guage cluster, they should be frame grounded at the socket.
I had to correct a similar issue with my dome light because I thought one wire was a ground and it wasnt. The two wires going to my dome are orange=constant hot....white=controled hot thru the headlight control switch.
Your turn signals are either a ground issue, or a bulb issue. Sometimes but not always it will be a socket issue. On these old rigs, one bad bulb or socket will muck up the entire blinker system.
Hope that helps, if not I hope you post what the solution was ....... always game to learn a new trouble shooting trick on these builds !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 01-18-2013, 09:02 AM   #754
shortbed70
shortbed70's Avatar
Thanks man. I'm going to do some huntin on this thing saterday after cleaning my shop. New wiring harness you would think would be good but guess not.. Oh well I can still drive it just have to manually blink the turn signals..
Troy
Big Red Dog build
Old 01-18-2013, 02:52 PM   #755
McMurphy
McMurphy's Avatar
Oh and on that note:
You know your blinker relay can go bad too yes?
Again, if you are running stock electrical set up, it should be the round silver unit plugged into your fuse box.
Glad you mentioned clicking the turn signals by hand, that is what reminded me of the bad relay !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 01-18-2013, 04:52 PM   #756
coulter
coulter's Avatar
Woooohoooo!!!!gettin closer.... Few more things to do!
dude that looks sick i like the color combo
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 01-19-2013, 08:37 AM   #757
shortbed70
shortbed70's Avatar
It's a brand new harness and relays but I'm not going to rule out relay.
Troy
Big Red Dog build
Old 01-19-2013, 08:38 AM   #758
shortbed70
shortbed70's Avatar
Thanks!
Troy
Big Red Dog build
Old 02-17-2013, 09:49 PM   #759
shortbed70
shortbed70's Avatar
Well took my dad out for a quick spin in the truck today! He loved it... Hammered on it a bit and not real happy with the convertor but it will be fine for a driver. Still have a small leak up front between timing cover and oil pan with the one piece gasket. Don't know what I can do but deal with it. It's so minor I'm not going to worry bout it. Hope someone gets control of gas prices though, $3.89 gal premium sucks!!!
Troy
Big Red Dog build
Old 03-05-2013, 10:30 PM   #760
shortbed70
shortbed70's Avatar
In Kansas City today and on the way home wife said lets go by LMC and we left with a new paintable bumper.... Love my baby's!!! Tomarrow I go and see if I can get some tubing bent for my exhaust pipes...
Troy
Big Red Dog build
Old 03-06-2013, 10:39 PM   #761
McMurphy
McMurphy's Avatar
Did you ever get your turn signal issue chased down?
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 03-07-2013, 12:11 AM   #762
shortbed70
shortbed70's Avatar
I think my front sockets are the issue. I just manually do it for now lol
Troy
Big Red Dog build
Old 03-28-2013, 11:34 PM   #763
shortbed70
shortbed70's Avatar
My new project!!! 5.3 woohoo...
Troy
Big Red Dog build
Old 05-24-2013, 11:25 PM   #764
shortbed70
shortbed70's Avatar
Been just enjoying project karma an well today it came back to bite me... Broke the nose cone on the starter almost clear off and wouldn't start... Oh we'll new starter and we are good to go...
Troy
Big Red Dog build
Old 05-25-2013, 12:06 AM   #765
72_ChevyMan
Truck looks awesome man. Sorry to hear bout the nose cone. What are plans for the 5.3?
72_ChevyMan is offline   Reply With Quote
Old 05-25-2013, 12:20 AM   #766
shortbed70
shortbed70's Avatar
Thanks. I knew when I first fired this motor the timing was off an it kicked back a few times and that's not good on them and since have it dialed in. The 5.3 was going to go into this truck with a small turbo on it but have since sidelined that motor for a later project yet to be determined.. I am still deciding if I'm going to take karma out and flog it on the 1/8th mile tomorrow or not. Guess I will see what saterday brings..
Troy
Big Red Dog build
Old 05-25-2013, 12:27 AM   #767
72_ChevyMan
Turbo on that 5.3 would be sick in your truck. Honestly contemplated puttin one in mine but decided against it. Imma need all extra money for rest of truck haha and all my other plans. Hows other truck comin along
Old 05-25-2013, 12:31 AM   #768
shortbed70
shortbed70's Avatar
Those 5.3's put down some nasty numbers with 8-10 lbs of boost but this motor in my truck runs to well to yank it but maybe next year ill have the 5.3 built and a 400 trans laying around or maybe a 4l80. Other trucks coming along good. Big Red Dog is the build. Check it out. Haven't posted pics of the door yet but one is done the other maybe next week.
Troy
Big Red Dog build
Old 05-25-2013, 02:46 AM   #769
65 wonton
Having met and talked to Troy in person, I see some fatal flaws in this logic. See, a lot of us think we are putting an LSx in our builds to get better gas mileage, but it won't work. You may have noticed he mentioned 3 buck plus gas a couple of posts ago. But he also mentioned something about 1/8 mile. IIRC, that is drag racing.
I can tell you from personal experience that an unmolested LS1 ('98 T/A, red even) can make the fuel gauge needle move before your very eyes. All you gotta do is touch the gas pedal.
So I could buy other reasons of switching to an LSx, but fuel economy ain't one.
BTW Troy, I forgot to tell you. The old school hot rodder guy I told you I sent the rear end to was bragging with a dyno sheet for a 427 (LS) he built. Over 700 HP rear wheels.
Dave, owner of The Big Red Dog.
65 wonton is offline   Reply With Quote
Old 05-25-2013, 10:00 AM   #770
shortbed70
shortbed70's Avatar
That would be a fun thing to have under my foot! I'm still unsure if I'm racing or not... I think I'll just go watch today even though I would like to know what that ol motor has in it.
Troy
Big Red Dog build
Old 05-26-2013, 12:44 PM   #771
Jmorales3181
Jmorales3181's Avatar
Truck looks great man!
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 05-26-2013, 01:24 PM   #772
shortbed70
shortbed70's Avatar
Thanks... I'm hoping to have more done to it this summer unless I stay buisy with side jobs and in that case Ill take the money instead of spending it...
Troy
Big Red Dog build
Old 06-28-2013, 10:12 PM   #773
baggedout81
Hey!!
baggedout81 is offline   Reply With Quote
Old 06-28-2013, 11:39 PM   #774
shortbed70
shortbed70's Avatar
What's up brotha? Your online again huh? I've got to go finish cleaning karma for the show tomorrow...
Troy
Big Red Dog build
Old 06-29-2013, 12:18 AM   #775
baggedout81
Yrp,just havent been on here in forever!!
