Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 11-13-2021, 05:18 PM   #751
kev2809
low n' slo
kev2809's Avatar
Re: Project 67 DRGNWGN - 67 Burban!!
well, was getting ready to mate to the trans and figured I would reseal the output shaft and the slip yoke tube inside since there was trans oil on the u joint when I pulled it from the donor. the tube I can't get local so had to order it off Amazon and won't be in until the week sometime. I did get the shaft seal in...pain in the ass.
if you guys have a rear main seal alignment donut, it fits perfectly over the rubber so you can evenly tap the seal in.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-13-2021, 11:51 PM   #752
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by kev2809 View Post
thanks my drill bit came in about 30 minutes ago so I drilled and tapped the head....this made me nervous lol
I'm not sure if the stock 67 sender will work though. when I get to the cluster, I will be modding it like ls1nova did with the s10 speedo. I will be adding a clock and camaro tach, and delete the circuit board and make a harness. so not sure if the idiot gauge temp sender is used or the 5 hole cluster temp sender. I believe they are 2 different ones?
Yes, they are different. First picture is for gauges and second picture is for light.
LockDoc
Leon
Old 11-14-2021, 05:46 PM   #753
kev2809
low n' slo
kev2809's Avatar
LockDoc
hmm well I ordered my rewire kit a while back but I believe it's universal. so do I just order the gauge temp sender and plug..and crimp the plug to this harness?
edit: I believe I have the right one?
-_--_--_ _________
Old 11-14-2021, 07:34 PM   #754
BigBird05
The terminal should fit the sender ok, but you will need the right connector for a gauge. The connectors look the same with the exception of the gauge connector has a half moon cutout to slide over the pin on the sender. I believe the correct connector is white, but if you don't care what color it is I think I have a black one.
BigBird05 is offline   Reply With Quote
Old 11-14-2021, 07:55 PM   #755
kev2809
low n' slo
kev2809's Avatar
ah ok. i checked my harness and didnt see this connector. i do have my old engine harness, but im getting together another order from rockauto and will throw it in there. im really debating on whether i should pull all the balljoints and tie rods out and replace them. i bought them all new about 11 years ago and they have zero miles, but i bought house brand stuff and a few of the boots are torn from sitting so long (althought i can buy the boots by themselves). its about 250 i could be saving and putting to something else.
waiting on my slip yoke seal for the trans, so in the meantime i will clean up and paint the front suspension stuff.
plan is once i get the motor and trans in, get the front suspension back together....i will start on the rear stuff. need to look into what tank and pump combo i will use, but im thinking the 87 blazer tank setup i seen some people use. but once thats in, i can work on the fuel lines. such a long to do list before i can even try to get this cranked up and move under its own power....
-_--_--_ _________
Old 11-14-2021, 08:53 PM   #756
LockDoc
LockDoc's Avatar
Yes, that is the correct one for gauges.
Here is a picture posted by member Ray Mcavoy.
LockDoc
Leon
Old 11-17-2021, 02:18 PM   #757
kev2809
low n' slo
kev2809's Avatar
thanks locdoc. I ordered one with rockauto.
getting a little ahead of myself but I ordered up the the fuel tank, sending unit, and in tank pump. I know most blazer tank swaps are done with the 31 gallon, but I went with the 25 gallon setup. hoping it's a more shallow tank for ground clearance.
-_--_--_ _________
Old 11-27-2021, 04:45 PM   #758
kev2809
low n' slo
kev2809's Avatar
working on getting the suspension cleaned up and painted. I was trying to get the pitman arm off the crosslink bar without my balljoint popper tool and I might have damaged the nut to thread back on. so I tried running the number casted on and it's coming up as 67-8 truck manual gearbox arm.
I have a power steering box, so should I swap this pitman arm out for a 72 power steering pitman arm? I don't believe I ever changed this arm but everything seemed to line up. casting # is 3952084A
-_--_--_ _________
Old 11-28-2021, 09:50 AM   #759
BigBird05
Why don't you just run a thread chaser on it?
Old 11-28-2021, 10:27 AM   #760
kev2809
low n' slo
kev2809's Avatar
I'm going to buy a new castle nut today and see if the threads are OK. if I can use it and the castle nut doesn't work, I will fix the threads. I just noticed after looking up the part number that it's listed for manual steering....im just not sure if I should use it or grab one for power steering. I don't even know what the differences would be.
-_--_--_ _________
Old 11-28-2021, 10:30 AM   #761
BigBird05
If you want an original nut, just send me the size and i'll get one out to you.
Old 11-28-2021, 11:04 AM   #762
kev2809
low n' slo
kev2809's Avatar
do you think the manual/steering makes a difference?
I can grab a new nut, have oreillys down the street, but thanks!
-_--_--_ _________
Old 11-29-2021, 08:34 PM   #763
BigBird05
I didn't know that you could buy castle nuts from anyone.
Old 11-29-2021, 09:46 PM   #764
kev2809
low n' slo
kev2809's Avatar
yup picked one up today and the new nut screwed right on. oreillys has them in the help isle. it's an assortment pack by Dorman. one of the 4 fit. now to figure out if I can use this pitman arm or I have to swap to a power steering one from a 72..
-_--_--_ _________
Old 12-02-2021, 10:11 PM   #765
kev2809
low n' slo
kev2809's Avatar
flying to Colorado for a little vacation this weekend. when I get back I will be dropping in the motor and trans and all the painted front end stuff
-_--_--_ _________
Old 12-03-2021, 12:02 PM   #766
BAD1916
That is going to look great. Did you ever figure out your pitman arm issue?
BAD1916 is offline   Reply With Quote
Old 12-04-2021, 10:00 AM   #767
kev2809
low n' slo
kev2809's Avatar
well I found the replacement castle nut and it thread on fine, so that's OK. I'm going to bolt everything together and at some point hopefully I can tell if the pitman arm will work or not. of not I will swap it out
-_--_--_ _________
Old 12-10-2021, 02:21 AM   #768
Average Joe
Average Joe's Avatar
Looking good. Nice progress!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 12-10-2021, 09:54 AM   #769
kev2809
low n' slo
kev2809's Avatar
thank you! read through build and it was a nice read. truck looks great!
weather permitting I'm hoping at least the suspension goes back in saturday....
-_--_--_ _________
Old 12-16-2021, 06:06 PM   #770
kev2809
low n' slo
kev2809's Avatar
trying to get some of this stuff back in. not sure if I'm having fitment issues now. putting the spindle back on and it doesn't seem to go ALL the way down on the lower ball joint. I'm not sure if this is normal or maybe with all the weight back on the front it will settle more? I hit it with my impact and that's as far as it goes....
-_--_--_ _________
Old 12-16-2021, 06:57 PM   #771
kev2809
low n' slo
kev2809's Avatar
passenger side did the same thing. I'm wondering if I get all the steering together and put the wheels on and get it on the ground if I could try and tighten it more?
-_--_--_ _________
Old 12-16-2021, 07:04 PM   #772
kev2809
low n' slo
kev2809's Avatar
and also I have these spindles backwards....
will have to pull them back off
-_--_--_ _________
Old 12-18-2021, 12:47 AM   #773
LockDoc
LockDoc's Avatar
That's a bummer you have to take them back apart. Is there any paint inside the holes that the tapered stud fits into? It doesn't take much to change the fit on them. I think you can buy a reamer with the correct taper to open the holes up a little.
LockDoc
Leon
Old 12-18-2021, 08:05 AM   #774
kev2809
low n' slo
kev2809's Avatar
ya well either way they had to come off. weren't seating and I'm an idiot and had them backwards lol
I'm picking up some 67-70 lower ball joints this morning and will press them in. this way I know for sure I have the right BJs
-_--_--_ _________
Old 12-19-2021, 12:04 AM   #775
LockDoc
LockDoc's Avatar
Sounds like a plan!
LockDoc
Leon
