Old 05-12-2014, 05:13 PM   #751
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: "The Ayatollah of Rusty Hole'a 1987 SWB 6.0 4L80E
Just working more in my cluster this weekend. Trying to cut a new backing for it as my old one was too flimsy. Easier to do this time around as my gauges are already set in the cluster do I can tell exactly how much to trim.
Old cluster back:
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 05-12-2014, 05:15 PM   #752
Gordonr1973
Home Built '87
New one:
Gordon
Old 05-14-2014, 09:33 PM   #753
Gordonr1973
Home Built '87
Looking forward to getting my aluminum pull strap bezels from UAtahoe, which can be found here:
http://67-72chevytrucks.com/vboard/s...d.php?t=628534
Gordon
Old 06-12-2014, 12:55 AM   #754
Gordonr1973
Home Built '87
Started wet sanding today
Gordon
Old 06-12-2014, 02:33 PM   #755
Hankster
Hankster's Avatar
Looks good!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 06-12-2014, 03:33 PM   #756
jpnh
jpnh's Avatar
I Agree. nice pearlesence
jpnh is offline   Reply With Quote
Old 06-12-2014, 03:46 PM   #757
kikkegek
kikkegek's Avatar
p.o.r.n.!!!!
looks killer man!
kikkegek is offline   Reply With Quote
Old 06-12-2014, 11:28 PM   #758
Gordonr1973
Home Built '87
Thanks guys!
Decided to get rid of the drop and go with an old school rake instead ;-)
Gordon
Old 06-13-2014, 09:48 AM   #759
NastyBuzzard
NastyBuzzard's Avatar
I am doing a ls swap into my 87 GMC V1500 longbed.
I am transferring the entire wiring harness from my 01 donor.
My original plan was to fit the 01 gas tank onto my 87. Wont work.
So I am back to trying to figure out the fuel setup.
I have dual 16 gal tanks currently setup for tbi fuel injection.
I am going to use the cluster from the 01 in the 87 I have read that 87 sending unit reads 0-120 ohm and the 01 sending unit reads 90-240.. So having to find a way to leap that hurdle.
So what do I need for my fuel tanks to handle the ls engine? Upgraded pumps, i'm guessing.
Any ideas?
I am also considering deleting the 16 gal tanks for one 20 gal tank. What you think?
NastyBuzzard is offline   Reply With Quote
Old 06-13-2014, 08:40 PM   #760
y5mgisi
Second Chance Program
y5mgisi's Avatar
Without highjacking Gordon's thread, You can drop in EP381 fuel pumps in your tanks. THey are for like 96 vortec trucks and vans or something. But they fit right in place of the old pumps. After that, you'll have to google (or gordon may answer) about a high pressure selector valve. But thats all you need there. I cant answer to the ohm issue.
EDIT:
Here is a list of all the vehicles that use the EP381 pump.
http://www.summitracing.com/parts/ad.../applications/
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 06-13-2014, 08:54 PM   #761
NastyBuzzard
EDIT:
Thanks! You've been a great help. I think I already have the high pressure pollak switch, however I plan to get away from dual tanks and just run one of the saddle tanks, 16 gal for now. Later on if the 16 gal isn't enough I'll go back and swap out for the 20 gal saddle tank.
Old 06-18-2014, 12:08 AM   #762
Gordonr1973
Home Built '87
I'm not sure if you can switch tanks on all trucks due to space needed for the 20 gallon.
Gordon
Old 06-18-2014, 12:10 AM   #763
Gordonr1973
Home Built '87
Made a remote oil pressure sender setup bc I was tired of the gauge fluctuating.
Gordon
Old 06-18-2014, 07:43 AM   #764
NastyBuzzard
I should be good, my truck is a longbed.
Old 06-21-2014, 05:02 PM   #765
Gordonr1973
Home Built '87
Bought a lift today for my muscle cars. Now I need to reorganize the shop!
Gordon
Old 06-21-2014, 07:38 PM   #766
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
Very Nice!
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 06-24-2014, 11:48 PM   #767
Gordonr1973
Home Built '87
Here's a question for you all: when I was first trying to get my truck wired up and I didn't know anything about wiring I paid a forum member here $500 to come wire my truck up. In the end he charged me $80 an hour to have him bring his dad over and tell me stories while he only put in three wires: the negative to the frame off the battery, the positive to the alternator and a straight line positive from the battery straight to the starter without a fuse in that line.
When I noticed that this past weekend I thought 'what am I supposed to do if my starter solinoid goes out and the starter stays engaged and won't shut off?' Without a fuse isn't there a chance my truck could burn?
Hey 'black knight' (as he called himself, that's not his forum name) --- you're an idiot. If you are doing this in all the big dollar builds you say you do for the local Hockey players like you were bragging about, you're full of Sh*t.
Gordon
Old 06-25-2014, 12:02 AM   #768
y5mgisi
y5mgisi's Avatar
There is doing it, and doing it right. Sounds like YOU will be doing it right this time.
Old 06-29-2014, 01:13 AM   #769
Gordonr1973
Home Built '87
Grill
Gordon
Old 06-29-2014, 11:19 AM   #770
Sodell
Sodell's Avatar
What did you use for the center white on the grill. It looks great. I had a local guy put some new vinyl in after I cleaned and polished them, not sure I like the results. I like your wheel selection as well!
[IMG][/IMG]
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 06-29-2014, 11:28 AM   #771
naphtali5725
naphtali5725's Avatar
what wire are you talking about going to the starter? the main positive cable or the solenoid positive wire from the ignition switch?
You should have a main cutoff on your positive cable, so you can kill the power if need be
since you have top post, and side connections on your battery, you'll either need to change that, or get two cutoffs...
google battery cutoff, you'll see.. cheap insurance...
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 06-29-2014, 10:49 PM   #772
Gordonr1973
Home Built '87
Bumper and tall air dam on. My shorter air dam didn't line up with the holes very well.
Sodell: I painted those inserts when I painted my truck. If I could have found vinyl coloured to match, I'd have gone that route. Painting and taping the inserts was hard.
Y: thanks for the hint, I'll look up the switch.
Gordon
Old 06-30-2014, 12:11 AM   #773
naphtali5725
truck is looking awesome man!!!
My build thread...
Disabled Veteran
Old 06-30-2014, 12:59 PM   #774
TheBlueBomber
TheBlueBomber's Avatar
Looking really good! When you bolted the Dirty dingo mounts on the motor did you leave them forward all the way? I'm having problems with mine. The oil pan is hitting the crossmember.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 06-30-2014, 05:48 PM   #775
Gordonr1973
Home Built '87
Yes, I moved it all the way up to clear the firewall. But I didn't have the big mech fan to deal with as I went with electrical fans.
Gordon
