04-19-2014, 10:50 AM | #751 |
Re: Donz '65 SWB Stepper Budget Build...
Chevy Orange Engine Paint, not sure of brand... May be going a different route... PM Sent
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
04-21-2014, 02:11 AM | #752 |
UPDATE ALERT!!!
What a day… Started in around 1030 and finished around 2030... Started the day getting the hood for the 90 model painted flat black in order to free up room in the shed to make further progress on the '65... Then decided to get the radiator core repaired and in primer… Gonna stretch this out over a few replies, so bear with me... Here are a few pics to get things going… The work area… The hood installed with the '65 patiently waiting… The hood installed...
04-21-2014, 02:18 AM | #753 |
The saga continues...
The Pizza Box that gave it's life for the cause... McMurphy gets the credit for the Pizza Box idea!!! The cardboard pattern… The Metal Patch being fabricated... a couple installed shots…
04-21-2014, 02:23 AM | #754 |
… More to come...
Inner Fenders are all welded and ground, waiting for me to finish prepping for primer... …and along the way I reached a milestone… Killed my first roll of Welding Wire... Here's a pic of the empty roll just because… Thanks again Jeff daBears for the patch panels, I can finally call them installed...
04-21-2014, 02:38 AM | #755 |
Finally…
For those of you who have just tuned in, or somehow or another missed it… The PO decided black paint with rainbow glitter was cool... This is what goes through my head whenever I see any of that paint... The reason for this tirade… the idiot PO even sprayed this crap on the radiator support… After this epic day… IT IS GONE!!! Lastly… Had a chance to use my new to me Drill Press… Here it is near my wall of toys… small collection of Hot Wheels and such... Hope you Guyz and Galz had a Great Easter!!!
04-21-2014, 08:50 AM | #756 |
Nice work Don!!!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
04-21-2014, 08:59 AM | #757 |
That pizza box did you up right !! That patch you made looks better than the one I did for that same area on my p-side inner fender, Rock on Man !!
You are going to LOVE that drill press, it really helps to step up your game I love Hot Wheels, and all the others like them, I got my first Hot Wheels set when I was 7 and it was the Snake and Mongoose special edition (sure wish I still had that !!) You may want to bite the bullet and get the 10lb spool of wire next instead of those small ones... I always buy two at a time because there is little more fustrating than running out of wire in the middle of a weld session, especially on a day or time the supplier is closed. Good to see some updates on your build man !!
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
04-21-2014, 10:23 AM | #758 |
Post Whore
Good work brotha!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-21-2014, 10:37 AM | #759 |
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
04-21-2014, 11:03 AM | #760 |
Nice work on the metal patches!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-21-2014, 06:44 PM | #761 |
great work on the radiator support! I ended up buying some 1.5" c channel and redid the whole thing, as mine looked a lil weak and thought it would break off or fall apart it I just did that same as you have done! the whole middle of mine was pitted and rusty, it was bad
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
04-21-2014, 10:11 PM | #762 | ||
Thanks Man!!! Gotta get to Strawberry soon!!!
My mom worked as a Nurse's Aid when I was probably 5 to 7 years old and the hospital she worked at had a vending machine that sold Hot Wheels! I still remember the little cars and how cool it was that she brought those to me, and man how I wish I would've held on to a lot of those... Thanks for checking in… I saw on TV earlier that Fairbanks was up to 52F today!!! Appreciate the compliment TJ… Glad to see ya back Craigerr! Thanks, and you're 348 is going to be Quote:
04-21-2014, 10:11 PM | #763 |
Rollin' Old Skool
Nice work Don! Good to see you making some progress again.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
04-21-2014, 10:32 PM | #764 |
Today was slow in the progress dept… after a bit of organizing in my shed, I pulled the antenna, OK, cut away the antenna, and filled the hole...
The antenna was a cheap aftermarket rig that had rusted and made normal removal impossible, so I grabbed my trusty cut-off wheel and removed the stubborn thing... Here are a few pics… Antenna Hole Ready to weld with plug in place After grinding… need to skim coat some glaze coat then prime Teaser Pic with Emblem….
04-21-2014, 10:33 PM | #765 |
Thanx Man!!! Feels good to be pushing forward...
04-21-2014, 10:35 PM | #766 |
Post Whore
Holy Fire!
04-22-2014, 04:36 AM | #767 |
Patch panel and your welding looks good Don
Also welding up my aerial hole when I get to it. Got Nicolas PC uploading the last 150 photos while at work, so will update Steam and Traction show pics when I get time. Out of town two days this week. http://67-72chevytrucks.com/vboard/s...d.php?t=625828 Amazed that I took over 500 photos over the two days. Yesterday was just awesome. My favourite comment from a 5 year old in his dads arms, looking at my trucks rear was : "Daddyyyy.... Can I jump on the trampoline?" Got to love kids.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
04-22-2014, 11:25 AM | #768 |
Heyyyyyy that emblem is going to look pretty freeking cool there man !! I have got to remember to make sure Jay sees that
04-22-2014, 06:45 PM | #769 | |
did find out the co-owner of the place I work at has drag cars and a pit crew! everyone at work was giving pass to (throwdown in t-town) may 16-17 at the Tulsa raceway park, 3101 N. Garnett, Tulsa, ok. gates open Friday at 5pm. and Saturday at 9am
04-22-2014, 09:28 PM | #770 | |||
Thanks TJ
04-22-2014, 09:35 PM | #771 |
1 thing at a time is progress.
I love the emblem! Awesome!
Alan
Philippians 2:14-16 |
04-22-2014, 10:35 PM | #772 |
04-22-2014, 10:44 PM | #773 |
Senior Enthusiast
All the welding and patching is inspiring! That emblem looks fantastic, and will really draw attention when the truck is all back together!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
04-23-2014, 05:53 AM | #774 |
04-23-2014, 10:29 AM | #775 | |
Thank You Sir!
Thanks Clem! Looking forward to Saturday! Passed on that 64 in KY, too far gone for the money...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 04-23-2014 at 10:30 AM. Reason: forgot something |
Tags |
65 swb, c10, step side, tattoo |
