#751 | |
Re: 1977 Chevy C10 known as SharkBite
I'll look on my photobucket see if I have a picture but if not I'll take a picture tonight for you. On the q-jet there was a how they described it in the video was a vacuum port for power brakes in which i have. About vacuum ports I do have some on my intake manifold actually on top of my thermostat are my other vacuum ports I know one is for me to bypass the original air equipment so I could have the headers and another is supposed to be a transmission vacuum does that sound right? And then the PCV valve too. Awesome I found a picture! when you look at the picture duane in the right lower corner you'll see a bolt sticking out that's what the brake boosters line was connected to. I tried and tried to get it off it just wasn't budging at all maybe I'll give it a go at it tonight, I could always use my impact gun I suppose? Here's the picture though. ![]()
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
#752 |
So your vacuum source before was the carb? Edelbrock's brake vacuum port is the large port in the center of the carb, if I'm not mistaken. No fitting required. Just plug a vacuum hose to it and the brake booster. I'm fairly certain this is how my GTO was done prior to installing the Hydroboost system.
As for removing that fitting from the Q-jet... be VERY careful if you choose to use the impact gun. It might break the carb body... I've seen it happen. Just a word of warning.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#753 |
That's correct that same bolt is where I loosened my brake like hose from. Does that make sense?
If you go to the link, the 3rd picture down on the left side is the port that I'm talking about just making sure were on the same page with it. http://www.spiderautomotive.com/edelbrock1406.html Yeah, I mean I tried taking it off with my regular wrench and it wouldn't budge maybe I'll try a socket the torque, and use the impact gun as a last resort.
#754 |
Now I'm on the same page. I've got a 1405 on my GTO and the 1406 on the C-10. I've got a cap on the large center port in the front of the carb on my GTO now. I'm fairly certain that's what my brake booster was connected to. My C-10 on the other hand has my valve cover PCV valve connected to that large center front port (all connections for PCV are in the intake from the factory on my GTO).
I don't have a good picture of it, but I believe I can see the vacuum port on the back of the 1406 connected to the old vacuum booster before I changed over to the hydroboost brake booster. With that said, try squirting some WD40 on that fitting and letting it sit for a while before you resort to the impact gun. Or, find out what size and type of threads that port is and go buy a new fitting.
#755 |
Okay glad we're seeing eye to eye now
![]() ![]() Posted via Mobile Device
#756 |
Get a new fitting for the new carb and just run a hose to the brakebooster. You can get one pretty cheaply at the hardware store.
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
#757 |
Yeah, I was going to try and see if I could break it loose last night but didn't get home till late and I just wanted to sleep. Might try to give it a go tonight, if I just can't get it loose I'm just going to go get one like everyone has suggested from a hardware store.
#758 | |
Her name is Quicksilver 1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER gotta pay $$ if you wanna play ![]() |
#759 | |
#760 |
did this kit include the throttle bracket? it should just stand on the a couple bolt holes on the back of the intake.. oh and i did notice you do have a brake booster hole in behind the carb pad.. however its a small one
#761 |
since your carb is wide the qauds throttle bracket wont be able to stretch to where the thottle stirrups are on the carb. heres the design thats suppose to bolt to your intake, so your throttle can be adjusted and center with the carbs stirrups.
#762 |
No it didn't include a throttle bracket I have a friends dad who has a 76, same motor and everything same carb, and same intake he doesn't have it in the bracket it sits just fine it's all about that like nipple fitting that isn't working right so that's my biggest issue right now.
#763 |
Yeah I see what you mean but i think that's if you keep the stock intake being I got rid of mine it got rid of some unnecessary items to clean it up.
#764 |
what part of town are you at sharkbite?
#765 |
You familiar with the clear lake area?
#766 |
Alright so I did what knomadd had suggested sprayed some wd-40 and ta da! just one good turn with a socket and it was loose! So got the brakes connected now so getting closer to start up.
I'm one more step closer to it being installed now my question is the original throttle linkage bolt wont fit in the hole on the carb but the new one they sent won't fit in the old clip so if I just ran the the new bolt and tightened it down (talking about the throttle linkage) would I be fine running it that way?
#767 |
Hmm... Guess I haven't subscribed to this thread yet. I like the truck man.
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD 1998 Trans am, mostly stock with magnaflow catback My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329 |
#768 |
Well glad to have you join us bro!! Thanks for the compliment bro still got a lot to do.
#769 |
So as you all know one thing that bugs me is an over amount of chevy orange sooooo I had to change it what you guys think?
#770 | |
Over use of "Bro" flag..lol. Did you figure out the throttle yet Korwin?
#771 | |
![]() Yeah I got the throttle figured out Scott, all that's left to do is fuel lines, electric choke wire, do all the vacuum lines and then crank it over get the timing done correctly then done.
#772 |
So tell me if I'm the only one with this problem here getting really discouraged with how long this has taken to do a simple swap, last night put on the throttle cable bracket well what has happened is it kinks the throttle cable cause the pedal to be hard to push down. Now tell me what my solutions are? Because we took rough measurements and the intake and carb only sit back about 1" further than the original and that's what is causing this whole problem so any ideas fellas? Or do I just need to bite the bullet and go buy a new cable?
#773 |
What throttle bracket are you using? You may need to change that instead of your cable. It might be worth a shot if you can find something at a local parts store. Or there are cheap online options like this: http://www.summitracing.com/parts/spe-24283/overview/
#774 |
I'm just using everything that came with the Edelbrock carb, didn't buy anything else.
I'm sorry Duane I'm using the stock bracket from the q-jet.
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal Last edited by 77ChevySharkBite; 10-11-2013 at 09:07 AM. |
#775 |
Does your bracket allow the connection to the carb work properly or is the angle off? Where is the cable kinked? Is it near the firewall, carb, or in the middle? Got a picture?
