03-09-2015, 10:18 AM | #751 |
Re: Project: Shiro
I'm planning on replacing my LS1 intake (probably the worst stock piece they made) with the tall runner version of that Holley. If you like the look of the stock intake though, FAST makes a really nice piece.
Speaking on looks alone, there's not much that would beat that dual 4-bbl setup, except that ITB/stack setup. Wow. |
03-09-2015, 10:53 AM | #752 |
Re: Project: Shiro
I like the Holley setup...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-09-2015, 11:23 AM | #753 |
Still Learning
Re: Project: Shiro
Don't lose interest in your project. You will get through the rust repair. It just takes time. I had to put mine on hold for almost a whole year one time. I didn't think I would ever finish it. But now I get to drive anytime I want. Keep your head up.
Please don't put carbs on your motor. Fuel injection is the only way to fly. IMHO |
03-18-2015, 11:08 PM | #754 |
A day late and $1 short...
Re: Project: Shiro
Worked on the sheet metal a little tonight...
The corners bunch up when the panels are pressed into shape, these peaks keep the panels from aligning well. I cut through the raised areas with a cut-off wheel and hammered them flat, I'll weld them up and grind them smooth later. I cut the rest of the cab corner off and smoothed the edges. Then I laid the panel in place and marked for the first trim. It will take several trimmings and some grinding to get a tight fit. I am trying to get a tightest seam I can to help reduce the blow through when welding it up.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
03-18-2015, 11:26 PM | #755 |
Re: Project: Shiro
Glad to see you tore into the cab to give it a go. I took a week just mapping my measurements and cutting sheetmetal preparing to weld the panels up. Take your time and measure measure measure. Good luck Buck.
Scott |
03-18-2015, 11:27 PM | #756 |
Re: Project: Shiro
The bottom edge of the cab corner sort of rolled forward which also made the panels not align...
... so I pie cut the the panel to straighten the edge. Will also be welded up and smoothed later.
03-18-2015, 11:28 PM | #757 |
Re: Project: Shiro
Thanks bro!!
03-19-2015, 10:44 AM | #758 |
Re: Project: Shiro
You're attacking those panels like a pro. I thought you hadn't done this before?? Keep it up!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
03-19-2015, 10:49 AM | #759 |
Re: Project: Shiro
Those videos must teach you a lot, because it sure looks like you know what you are doing. I might have to get me a set.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
03-20-2015, 08:23 PM | #760 |
Re: Project: Shiro
Man...bodywork...I don't want to know what is under the bondo on mine....
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" |
03-21-2015, 09:30 PM | #761 |
Re: Project: Shiro
New addition to the Porterbuilt collection I've started.
03-21-2015, 10:21 PM | #762 |
Re: Project: Shiro
Sweet!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
03-31-2015, 07:43 AM | #763 |
Re: Project: Shiro
A little progress,,,
03-31-2015, 10:16 AM | #764 |
I'm just glad to be here!
Re: Project: Shiro
Looking Good there Buck!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
03-31-2015, 10:53 AM | #765 |
Still Learning
Re: Project: Shiro
Killer score on the Porterbuilt gear! Nice work on the cab corner too. Keep up the good work.
03-31-2015, 11:46 AM | #766 |
Re: Project: Shiro
That porterbuilt stuff looks a lot more fun than bodywork.!! Pretty sweet looking frame Buck
03-31-2015, 03:37 PM | #767 |
Re: Project: Shiro
03-31-2015, 04:35 PM | #768 | ||
Re: Project: Shiro
I'm not sure what you mean by that. So... (It's never good when the conversation begins with "So...") So I am thowing in the towel on the rust repair and taking the cab up to DeWayne and his crew at Nsane Hot Rodz. Plans for the moment include blasting and priming the sheet metal, rust repair, as well as powder coat for the frame and suspension parts. I just do not have the talent or the temperment to accomplish the repairs to the level I want them done. I'd like to have a nice straight truck and I think this is the best avenue to reach that goal. While the sheet metal and frame are gone I'll work on the detailing the engine and transmission. Oh, and clean up my garage!!
03-31-2015, 06:08 PM | #769 |
Re: Project: Shiro
Frame looks good. Looking at that new crossmember makes me want one even more now. Gotta draw the line somewhere.
Understand the body work deal. I'm considering your plan as a backup but going to try and give it a go first.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
03-31-2015, 06:54 PM | #770 |
Re: Project: Shiro
Good plan, Buck! Looking forward to seeing their work.
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
03-31-2015, 08:04 PM | #771 | |
Re: Project: Shiro
So what is the purpose of this piece? And does it replace anything? |
03-31-2015, 08:35 PM | #772 | |
Re: Project: Shiro
Thanks It stiffens the frame and replaces the trailing arm and transmission crossmembers.
03-31-2015, 08:38 PM | #773 |
Re: Project: Shiro
It stiffens the frame and replaces the trailing arm and transmission crossmembers.[/QUOTE]
Ah ok gotcha! thanks! |
03-31-2015, 11:22 PM | #774 | |
Re: Project: Shiro
04-01-2015, 01:29 AM | #775 |
Re: Project: Shiro
What video's would you be referring?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
