06-09-2014, 01:03 PM | #751 |
Re: What did you do to your truck today part II.
Drove it 600 miles on the HotRod power tour. The old 250 with T5 hung right in. Got over 20 MPG. Had a blast with her.
06-09-2014, 02:03 PM | #752 |
last coat of filler i used fiberglass first, then bondo to fill the pin holes. now sanding the whole cab with 80grit clean one last time tack rag it, then finally PRIMER. oh yeah!!!
06-09-2014, 02:10 PM | #753 |
making the patch panels disappear is a pain on ur back, the tilt is the way to go
06-09-2014, 02:14 PM | #754 |
so much filler only to sand 99% off, ugg
06-09-2014, 04:07 PM | #755 |
Another small safety related purchase today.
The existing mirrors were 5 inch round ones, tired, rusted and not very good as mirrors. So I decided to go for the 5 X 7 inch rectangular ones so that I could see what was going on around me. Another £28.00 out of the kitty. But a good spend in my view. Also went to the Exhaust doctor to start investigating the full cost of a complete new stainless system, including a pair of cutouts. Price quoted had me taste bile. More homework.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
06-09-2014, 04:58 PM | #756 |
06-09-2014, 05:06 PM | #757 |
It's Better With Nitro
Finished the instrument cluster today...checking the high beam and turn signal indicator lenses i restored.
06-09-2014, 05:42 PM | #758 |
06-09-2014, 07:30 PM | #759 |
Put plywood in the truck so now I can acually use it as one. Even made a cut out so I can get to my battery without climbing under the truck. All that work for something that is temporary. I guess you can tell how I get gas in the truck..
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
06-09-2014, 08:23 PM | #760 |
Not exactly today but over the last few weeks. I removed the rear springs & installed air bags with separate Schrader valves. I removed the home made receiver hitch that was welded on the truck and bought a used Reese receiver hitch off Craigslist for $30.00 - modified it, painted it & installed it. I wrapped the exhaust pipes with a fiberglass cloth where they passed near the air bags. I installed & wired a Curt brake controller ($55.00 off eBay). I finally hooked up the truck to our 28 foot travel trailer and took it for a jaunt around town. I was surprised how well the truck handled it but I didn't take it up any hills. Hills and rust haven't been invented yet out here in the central California. I still need to drop the stabilizer hitch down a notch or 2 but it's 109 degrees out here now and that's going to have to wait.
Tuesday morning the truck goes to the upholstery shop to get the front seat recovered. |
06-10-2014, 06:04 AM | #761 |
We discovered that the rear bumper for the 62 was actually 63 to 66 (duh) -so we had to figure out the mounting since I had it powder coated already.
I’m really "smart" like that. Took some 1½” x ¼” mild steel bar stock and 1/2"-13 Grade 8 bolts & made adapters for the bumper mounting bolts. Now we can still run the 60-62 brackets that we have on hand while mounting the 63-66 bumper that we had coated white. rg & ray~ray |
06-10-2014, 10:59 AM | #762 |
Question? If you were going to partially restore a 65 C-10. Would you paint the frame and suspension parts. This truck will be my driver and will be taken on trips around the country. I don't have a sand blaster so will be scraping and wire brushing the frame before priming. Was wondering if anyone has used the industrial paints for the frame. I believe that was what was put on them from the factory right? BTW I have the body off the frame at this point.
Thanks for any responses. Ron |
06-10-2014, 04:50 PM | #763 |
hey if the cab is away from the frame,its a full on resto in my opinion. well today i did the final sanding before primer, if this beast aint clean after all these suds...
06-10-2014, 05:30 PM | #764 |
Hey pimpston...mind me asking how you removed the old sound deadener off the bottom of your cab?
06-10-2014, 06:15 PM | #765 |
i used a putty knife til i rounded the edges and a cup style wire wheel, wasnt bad. im lie'n. cab sat outside for a few yrs rusted i sand blasted sat some more, then i had a guy blast it again then he prime'd it with some hellofa stuff, wasnt easy to even scuf with 80grit,but thats all behind me now...
06-10-2014, 06:27 PM | #766 |
Drove it!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
06-10-2014, 09:28 PM | #767 |
Moderator
New front brake lines, bled brakes. New rear shoes/combi, greased front end. Upper ball joints are still OEM, and tight! Repacked wheel bearings. Getting closer...
06-10-2014, 10:03 PM | #768 |
quick question, i installed the inner and outer bearings on the front spindle, i noticed they call for a inner bearing seal that goes on first, closest to the backing plate. dumb question is it needed? cuz i pounded like heck to get the inner bearing on, i guess i could use a puller to get em off if needs be...
06-10-2014, 10:29 PM | #769 |
hey Grizz1963 love that yellow seat cover, u should send it to me!!! glad you have a mate to help with things. now my cab hasnt been on the frame since 98'. so i hope yours doesnt take as long. if you thought it was fun taking it off the frame, bet you wet your nickers when its time to put it back on... keep up the good work.
06-11-2014, 01:18 AM | #770 | |
Senior Enthusiast
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
06-11-2014, 01:19 AM | #771 |
Senior Enthusiast
That cluster looks fantastic!
06-11-2014, 02:09 AM | #772 | |
Martin My build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
06-11-2014, 02:14 AM | #773 |
meowMEOWmeowMEOW
Today, I hooked up a wideband, worked on my SD-tune, and grumbled about getting around to coating my bed.
06-11-2014, 05:01 AM | #774 | |
06-11-2014, 06:32 AM | #775 |
Just recently I filled the nail holes in my old yellow pine with Clear two-part Epoxy and sanded it all down for some clear polyurethane...
Fabbed and welded up some 2 x 3" blocks on the cross sills... Fabbed a 3" filler panel frame for rear sill gap out of 1" angle... Because we're bringing our floor up inside the bed-box to avoid the cut out or tunnel for clearance at the pumpkin. (Hope to bag it one day if I can) rg & ray~ray |
