#751 | |
Re: 48 Burb, bagged, 5.3, 20 year wait
I am happy with the fit of my headmen but they were not cheap. |
#752 |
![]() Join Date: Jul 2012
Will do Jim. I cheated ...took the tire and the truck to dealership to fix. Glass guy is here replacing windshield. Prioritizing my time to be able to do some burb work. Will get back on it!
Sid, looking forward to seeing how your headers fit. I will throw these Camaro manifolds on to see how they look. Iceburgh, Did you have to trim the frame just a bit? Also, did you get your electronics on your LS worked out? Back to the shop for me.... |
#753 |
2010 Camaro manifold on the left side needs this much angle to almost clear the frame.
#754 |
And with the angle, the manifold hits the block. So, I'm going to go with some headers and use these manifolds on a different project.
#755 |
I'm glad I'm not the only one who has had problems with headers...
It seems like we all do! Hope you find the right ones the first time ![]()
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#756 | |
Never give up, never surrender......... |
#757 |
[QUOTE=Advanced Design;7387211]Will do Jim. I cheated ...took the tire and the truck to dealership to fix. Glass guy is here replacing windshield. Prioritizing my time to be able to do some burb work. Will get back on it!
Iceburgh, Did you have to trim the frame just a bit? Also, did you get your electronics on your LS worked out? QUOTE] Yes slightly...they fit but with the motor torque I wanted 1/4" No not yet maybe on Turkey day. Gives me something to do when the rest of the family is there. Been working on the '56....LOTS of work to do there |
#758 |
![]() Join Date: Mar 2007
I'm curious if my Camaro manifolds will work with the PB set up. I remember one of the changes they made that delayed things was a change to allow a more flexibility on header selection. Fingers crossed that I can use the stock manifolds. I wont know for quite a bit.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#759 | |
Saturday morning planned the day in the shop, then wife reminded me we had a funeral to go to. Leaving at 9. OK, lunch in town, back home at 1:30. Sit down in recliner for just a minute before hitting the shop. Mistake...two hours later I headed for the shop. Ugh. Not much done again...removed a broken bolt from the radiator support. Need to mount it up to see if I will have room for the accessory drive. Don't want to move the engine back unless necessary. Can't really tell yet. This is the truck water pump. I will put the inners on, add the accessories, mock up or buy the radiator assembly and then decide. |
#760 |
Well that worked pretty slick. Any progress is good progress. My Sundays are usually really good days for me to spend in the garage. Only problem was I was very FESTIVE at a holiday party last night and just felt like holding down the couch today......
Keep at it Marc
#761 | |
Iceburgh, it would be great if you could start a build thread on the 56 you are working on. |
#762 |
Another way to get a bolt out is to place a bigger nut on the head and weld up the center. Lookin good!!
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#763 | |
Marc
#764 |
Must be. He mentioned doing a lot of work on a 56.
#765 |
Saturday was fun.
#766 |
And C6 manifolds won't work. They are pretty tight on the left side and hit the frame on the right side.
#767 | |
Marc
#768 |
Lower, good idea too. Way better than drilling and trying an easy out!
#769 |
Yep, a friend had these laying around. So either the headers Iceburgh used or the Hooker ones Sid used will fit ....I hope.
#770 |
Don't know how the C6 compare to the Camaro manifolds but the flange is higher and closer to the block with the Hookers. Got anymore pics of the flange area on both sides?
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
#771 |
Hey Doug here is the set of headers I used on John's Dodge truck.
They are from Speedway #9300114 $200.00 comes with O2 bung, gaskets and the flanges witch you can turn in several positions. Pic #2. installed on johns. (By using Hugger Headers You will have to move motor mounts forward!) Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#772 | |
Mark, Thanks for the lead on the headers you used on John's Dodge. I'll look them over to see if they will work. Like you mentioned, the engine mounts would probably need to be moved forward. |
#773 |
I found these on Ebay and since Im a huge fan of stainless and have bought ebay headers bf, they are worth every chineese cent. I was skeptical on trying them cause I have nothing moched up yet, then I stumbled upon a guys build on here, but he hasn't responded back to my question (I don't think he gets on here much) or maybe I missed it and I can't recall his build thread. But... I did poach a pic from his thread when I saw it. Cause I recognized the headers. For me I think this is the route I'll try and take, so I'd need to order them, then do engine mounts and try and find a happy medium.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#774 |
Thanks 99. Those look good and I appreciate the idea.
#775 |
I think your engine is a little lower between the frame rails than mine but here's a few of mine with the Hookers on. Hard to see through pictures but the right side down pipe is about an inch from the frame rail. You can see the flange is a two bolt and is higher than the Camaro manifolds.Gives you something to think about.
