09-19-2017, 09:01 AM | #751 |
Re: 1956 Chevy Pro-Street Build
Says I'm not in a group, so I can't see it...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-19-2017, 01:49 PM | #752 |
Sorry Jim - -had to make it a PUBLIC post ---- try it now.
https://www.facebook.com/paul.christ...8155982304738/ thanks
My Build: 57 Chevy Pro-Street |
09-19-2017, 02:31 PM | #753 |
Sounds good and rowdy Paul! Congrats...
09-19-2017, 04:00 PM | #754 |
Great job it sounds really healthy.
09-19-2017, 07:08 PM | #755 |
Got it now, and you are correct it sounds ANGRY...Jim
09-19-2017, 07:42 PM | #756 |
Sounds great.
Kim |
09-19-2017, 10:07 PM | #757 |
Marvelous!!!
09-19-2017, 10:57 PM | #758 |
Post Whore
ABREED!!!!!!!!! sounds awsome!!!!!!
09-19-2017, 11:21 PM | #759 |
She's a mean sounding beast! Daily driver, huh?!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
09-19-2017, 11:53 PM | #760 |
Just plain nasty, love it.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
09-20-2017, 02:47 AM | #761 |
ptc
The national earthquake center reported a disturbance in the force about the time you started that fire breather. MUUUUUMMMMMMM Strong work You have 6, 2" gauges, what are they? Fuel, oil pressure, volts, and gas--- Keep on keepin on NC
Been there, wrecked that |
09-20-2017, 07:46 AM | #762 |
Oh sooo gooood!! I love the idle when you can count the 4 on each side.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
09-22-2017, 07:00 PM | #763 |
Thanks all.... its been a long hard row to hoe.... but its very close now. The brake pedal system is becoming a head scratcher for me because that one system has to WORK BETTER THAN ALL THE OTHERS.... or theres gonna be trouble. Im gonna take the whole assembly down to a machine shop and see what they can design that can go back in easy enough. Would a slave cylinder have enough pressure to push that booster rod ? or would it be just full ON and full OFF?
The P/S psi line is also a problem, it has blown the -6AN line off the psi side of the pump twice now. I think its blowing under higher revs. These are good Earls type hose ends, and the second time I put the hose together I made sure it bit good and hard so I dont know quite what is happening there. Just wondering if the hydroboost is messed up or something. NUTCASE --- the small gauges are 2 1/16" dia. and they are VOLT, WATER TEMP, OIL PSI, OIL TEMP, FUEL LEVEL and ---- BOOST! anyway ---- still working it.... Thanks again!!
My Build: 57 Chevy Pro-Street Last edited by ptc; 09-17-2019 at 12:44 PM. |
09-22-2017, 07:26 PM | #764 |
[QUOTE=ptc;8038156]Oh well dont need brake lights anymore cause I just broke off the brake pedal assembly.... can you say MAJOR SETBACK!!!! --- this thing is ready to run! and no brakes!!!
Remember this custom thing I made out of a Wilwood multi-res assembly to go under my floor? Well I just snapped the end of that long 1/2" bolt off that pushed the ram into the booster. I guess Im just gonna have to take the whole thing out and start over with a different idea.... tear up the firewall again and weld in some type of STANDARD brake pedal assembly like regular "white-folk" do..... instead of this redneck backyard mechanic stuff! oh well.... thank God - good thing it happened now instead of out on the street!!!! I need a vacation --- think I'll go to Florida! Okay so this is what I essentially made (from scratch) This is an $80 Porsche clutch lever..... I used just a 1/2"-13 Bolt black steel and then I had to drill and thread 1/4-20 "pins" on either end for the pedal and the lever. So I removed 50% of the bolt material on both ends and thats why it failed right at the 1/4" threaded hole on the lever end. QUOTE] ptc, use a pillow block bearing bolted to a plate and mount it under all 4 bolts of your bracket, to support the brake pedal shaft, you are sticking out way too far unsupported! |
09-22-2017, 07:47 PM | #765 |
What type of hose and fittings?. I used a Detroit speed hose my and it's got different fitting and hose than a standard -6 hose
Truck is looking good and hope you can get a linkage for brakes worked out.
1950 3100 5 window |
09-22-2017, 07:57 PM | #766 |
you need a fitting with a ferrell that goes on the outside of the hard line in the center.
09-26-2017, 05:55 PM | #767 | |
The brake pedal thingy is going to be a whole 'nother project. It was just to move it on the left side of the steering column where the clutch used to be. I should have left the clutch assembly in the frame! Im thinking I may go with flanged bearings, like this: and drill a hole in the frame rail and run a shaft right thru from pedal to lever, key it, bolt it. IDeas? Comments?
09-26-2017, 07:00 PM | #768 | |
09-26-2017, 09:24 PM | #769 |
Using flanged bearings is a great idea, you can kind of replicate the wildwood mounting plate with a bearing on each side and a transverse shaft. It's not hard to find steel and stainless steel keyed shaft online, keyed collars are available too.
http://www.surpluscenter.com/Power-T...-2982-50-3.axd http://www.surpluscenter.com/Brands/...r-1-1563-A.axd |
09-27-2017, 07:50 AM | #770 |
I would go with non swivel flanged bearings. It will help keep the shaft straight.
09-27-2017, 11:39 AM | #771 | |
The wilwood idea was to make the brake pedal assembly part of the cab instead of part of the frame. I guess that one will have to go back to the drawing board at some point or just use some better materials. I have a meeting with my machinist friend today, so we will see what he thinks.
09-28-2017, 05:15 PM | #772 |
WOW & WOW gr8 to see how far you have come along, looking forward to seeing more photos. GR8 work man.
I'm not tail-gating, I'm drafting. http://67-72chevytrucks.com/vboard/s...d.php?t=432758 |
10-14-2017, 12:00 PM | #773 |
Got the doors hung and aligned and now working on the latches from AutoJunk... with no directions at all. Well maybe Ill make a video on how to install them into a TF truck - I guess AutoLoc doesn't believe in support for these trucks.
Also -------waiting --------- on machine shop that said it would ONLY take an hour to rebuild my brake pedal idea the RIGHT WAY.... but that was 3 weeks ago!!!! HATE TO WAIT!!!!! ---- But I have my day job to keep me busy, what with 2 hurricanes, high rise fire in Hawaii and Northern CAL totally in flames! --- guess Ill be busy for a bit.
My Build: 57 Chevy Pro-Street Last edited by ptc; 09-17-2019 at 12:51 PM. |
10-14-2017, 08:44 PM | #774 |
been a while since i checked , Its lookin awsome buddy.
10-14-2017, 09:56 PM | #775 |
Wow, she's looking REAL good! I seriously considered those rims for mine and now I am considering them again! What sizes/widths are you using?
