09-01-2015, 06:40 PM | #776 | |
Post Whore
Re: Tricked-out Chevy six cylinder engines
I can give an estimate. lol With a 390 holley, headers(any kind), HEI and a lump port head with 1.86 intake valves and stock exhaust valves I'd say about 40 more hp than stock....so close to 170-180 hp I think. I don't remember the hp specs on the 250's as of now. You'd really be wasting time not adding a little more lift on the cam at least. I'd go a step over stock with a cam if I was doing a light build. Comp cams has some good grinds for cheap.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
09-01-2015, 10:25 PM | #777 |
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
09-02-2015, 02:51 AM | #778 | |
so i think with a good street cam like 0.490 valve lift and duration at 050 212 and lobe 110 can deliver 250 horsepower ! is this true ? |
09-02-2015, 10:42 AM | #779 | |
Post Whore
Head work: 1.86 intake valves 1.60 exhaust valves Be sure to have a at minimum 3 angle valve job and make sure the bowl is opened up as well. No chamber relief will be required. Lump ports. Z/28 valve springs. .030 shave off the head. Block work. .040 over forged aluminum flat top pistons. Ross is a good place to check. Tom Lowe does sell them for cheaper. Those will give you about 9.5.1 compression. A good cam would be comp cams 268H 218@ .050 .499 lift on a 110 lobe center. That'll give you a choppy idle and good RPM range. Here's the cam spec number 61-244-4. Go to their sight and see their camshafts. They have some nice options. Custom grinds are available as well. Stock rods balanced and refitted with ARP studs and bolts. Crankshaft balanced and ground for sure. Add a good intake and headers will a 390 holley or 500 edelbrock and HEI. You should see around 290 hp and 270 torque. Larry aka Twisted 6 can give you some options as well. He's on this forum once in awhile. Tom Langdon at Langdon's stovebolt will also have good advice. Mike at Ravenswood Paint and Body.....hard to get ahold of but a good man as well. lol Tom Lowe has done dyno testing so you could probably get some specs from him.
09-03-2015, 01:25 AM | #780 |
I saw this in a CL ad. Thought I'd share.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
09-03-2015, 10:24 AM | #781 |
Post Whore
That's really cool!
09-03-2015, 04:09 PM | #782 |
Barracuda aspirated!
09-18-2015, 07:54 PM | #783 |
Just received my offy 2 carb manifold for my 230 from speedway. It appears that there is no way to use any of the original linkage. The installation instructions are very vague. My question is has anyone here have this set up or seen it? The instructions for the linkage kit says to connect it to the original bell crank but that was connected to the original manifold and the offy has no provisions to install the bell crank set up. I thought it was going to be a simple swap out. thanks for any info.
Chief US Coast Guard Ret. 1963 SWB Fleetside Chevy L6 230 1962 Cadillac Coupe Deville 390 |
09-18-2015, 08:33 PM | #784 | |
Dual Carb or 2 barrel? Dual carbs may pose a challenge above my pay grade. Or you could fab a pivot on the Offy like the one the cast iron GM intake. Not sure how.
09-18-2015, 08:56 PM | #785 | |
Post Whore
https://www.youtube.com/watch?v=evcz4k1vjwQ
09-19-2015, 08:59 AM | #786 | |
Can you point me to details on how you did this? (Pictures, part#s, etc.) I am about to drop a 292 with the same carb on a Clifford intake in my '63 and have been thinking about throttle strategies. A cable setup sounds much simpler than some of the fab'd-up mechanisms I have seen.
Many thanks...ned. EDIT: I found this thread that answers about all my questions. Thanks TJ! Great work Quote:
'63 C10 long wide; '61 Corvair Lakewood; '74 BMW 2002tii; '89 BMW 325i, '49 Ford 8N Last edited by ncoonen; 09-19-2015 at 09:35 AM. Reason: Add link |
09-19-2015, 09:16 AM | #787 |
How about this
https://www.carbsonly.com/carbs/dualrochestercarbs.htm
09-19-2015, 10:15 AM | #788 | |
Post Whore
09-19-2015, 12:32 PM | #789 | |
09-19-2015, 12:34 PM | #790 | |
09-19-2015, 06:39 PM | #791 |
I left the original pedal and arm and then made up some short rods to go to the original bellcrank that I mounted sideways. Fabricated a mount off the back of my Edelbrock carb. Been on there for about 10 years now and works perfect. No bad spots in the pedal just nice and smooth.
09-19-2015, 08:08 PM | #792 |
I think I'm going to send the manifold back and cut my losses unless someone has this set up already operational. If my truck was 3 on the tree it might be easy to set up a cable linkage but with the power glide and kick down bell crank. Nah! Someone has to be running this manifold. the only thing that would make this thing work is to weld a piece off tubing onto it to provide the pivot point for the original bell crank set up.
09-20-2015, 08:09 AM | #793 | |
...ned.
'63 C10 long wide; '61 Corvair Lakewood; '74 BMW 2002tii; '89 BMW 325i, '49 Ford 8N |
09-20-2015, 08:11 AM | #794 |
Saw this one this weekend at Goodguys in Bowling Green Ky
Bruce 1964 C10 SWB #Junk 1979 C10 utility #cargopants (sold) 1971 GMC Sprint (sold) 1974 GMC Grande Sierra (sold) |
09-20-2015, 08:18 AM | #795 | |
I really like the clean simplicity of the cable setup. ...ned.
09-26-2015, 09:11 PM | #796 |
09-26-2015, 10:05 PM | #797 |
Mehoff400,
Just curious what's your build plan is? Just started tearing my 250 down for a winter rebuild. Planning on building one with a little attitude as well. Thanks, Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 |
09-26-2015, 10:23 PM | #798 | |
Post Whore
09-26-2015, 10:58 PM | #799 | |
its has been stock rebuilt.. i plan on dual carbs and headers.. maybe cam and stuff later but dont want to dig that deep into the pockets |
09-26-2015, 11:52 PM | #800 |
mine with new disc brake booster
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
