Old 10-03-2009, 11:41 AM   #776
daverod
SSN 706
daverod's Avatar
Re: Daverods project 66
Originally Posted by ruffrida2005 View Post
Dave I wrote to Jason on the other forum trying to figure out what the pinion is supposed to be set at witht he 2 peice driveshaft. I forgot that's what yall have to have with this kit. I'm only running a 1 peice with my truck so it's a lot easier to work with. When I find out I'll get back with you. but what Dennis said about cutting through the frame is really easy, you just have to go back in and put metal around where you cut. I've thought about doing the same thing. but I'll have to see.
I'm going to raise my bed so I don't have to cut the frame. Cutting a hole that big in the frame would scare me. Don't you think adjusting the nuts on the swing arms will change the pinion angle? Maybe it just moves the axle back? Guess I'll just tack it and see what happens.
daverod is offline   Reply With Quote
Old 10-03-2009, 12:15 PM   #777
daverod
SSN 706
daverod's Avatar
Ya baby. I was kind worried if I had my notch in the right spot or not. Got room to spare. I just looked at the pictures to get it in the right spot. Did'nt really measure anything.
Old 10-03-2009, 01:29 PM   #778
Strodder
Daring to be Different
Strodder's Avatar
Nice job Dave Make sure your diff is square with the frame. Find an alignment hole in the frame that is in the same spot on both sides. Measure to the axles from those holes to make sure your axle will be aligned, or you will be crabbing down the road.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 10-03-2009, 02:30 PM   #779
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
I see what your talking about now on the lower link bars, By adjusting the threade rod end will change the pinion angle. I wont push the alxe back or bring it up since the top will be in the same spot regardless, just rotated either way. As far as cutting a whole in the frame. that's not a problems as long as you box around the frame in that area and add some plate on the outside or inside of the frame rail. I've seen others do it that way.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 10-03-2009, 02:42 PM   #780
daverod
SSN 706
daverod's Avatar
Check it. Got to love the background music and quaility camera work. Damn I watched it about 3 times and it gave me a woodie.
Old 10-03-2009, 03:07 PM   #781
joe231
joe231's Avatar
Adjusting the lower links will change your pinion angle, but it will also change your axle center-line in relation to your notches...it would be best to get your pinion close and just make some fine tuning adjustments with the adjustable links
COOL VIDEO!!
CHEVY ONLY
Old 10-03-2009, 03:09 PM   #782
ruffrida2005
loooks good man I just watched it 3 times but didn't get a woodie, maybe I should watch it some more.
Paul
Old 10-03-2009, 03:14 PM   #783
daverod
SSN 706
daverod's Avatar
Originally Posted by jgh64pkup View Post
man dave your kickin ass and takin names
I know now what I'm I going to do all winter?
Originally Posted by joe231 View Post
if you don't mind it loud, just dump it after the cab
Nice work BTW
Still looking for ideas. Thanks Joe
Originally Posted by Alan's Classic View Post
Nice progress Dave
Thanks Allan
Old 10-03-2009, 03:16 PM   #784
daverod
SSN 706
daverod's Avatar
Ya It might take you a few more times. You're kinda use to this stuff. I'm a virgin. Guess I was kinda premature.
Old 10-03-2009, 03:27 PM   #785
watahyahknow
watahyahknow's Avatar
from the looks of the clip it seems to be working good , changing the pinionangle using the treaded rods should be possible but to move it down you need to lengthen to bottom one and shorten the top one , that way to axle stays where it is , the arc of travel might change a bit when there not parralel bars
i wonder if the angle is needed with the bars because its a pretty solid connection to the frame , usually they use the angle on leafsprings so it straightens when the leafs wind up under accelleration
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-03-2009, 04:27 PM   #786
daverod
SSN 706
daverod's Avatar
I just set it by eye and tacked it for now. When I know for sure I'll weld it on for good. I'm sure I can get a few degree's just by turning the nuts on the arms. I does'nt have much of an arc. It moves pretty much up and down. I don't think the pinion angle is as critical when your using a two piece driveline. There's twice as many u joints. I can always raise or lower the carrier bearing. Have to do some more research.
Old 10-03-2009, 04:56 PM   #787
joe231
joe231's Avatar
It is even more critical with a 2 piece drive-shaft, and more complicated. You don't want any of the joints at 0 degrees of the will wear out prematurely
CHEVY ONLY
Old 10-03-2009, 05:21 PM   #788
Strodder
Strodder's Avatar
Adjust the angle to the center joint. It should be in faze that way. Also I looked at my truck and there's lots of room to put the exhaust pipes from the block huggers along the inside of the frame to where the frame kicks up. Then cross over from there. Remember I have a 73 rear part of the frame, but I looked at the back half of my old frame and it looks like you can do the same thing.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-03-2009, 07:27 PM   #789
daverod
SSN 706
daverod's Avatar
Lots of room. So I guess you can go under. Now all I need are some bezels for cheap. I found some mustang ones. I could'nt.
Old 10-03-2009, 07:29 PM   #790
ol Curt
Junior Member
ol Curt's Avatar
Can I borrow that lift?
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 10-03-2009, 08:24 PM   #791
watahyahknow
just thinking :you might be able to find suntin in a boatshop or boatwreckingyard , i can immagine they use those type of exits for water or exaust or sumtin like that
Old 10-03-2009, 08:41 PM   #792
daverod
SSN 706
daverod's Avatar
I don't think we have boatwrecking yards in Idaho. I'll look on ebay though. Boat exhaust bezels. Worth a look. Got to be cheaper then vette ones. The mustang ones are looking better and better.
Old 10-04-2009, 11:39 AM   #793
Strodder
Strodder's Avatar
Try E-Bay
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-04-2009, 12:50 PM   #794
daverod
SSN 706
daverod's Avatar
Try E-Bay
E-Bay? I was hoping you had a couple more laying around.
Old 10-04-2009, 01:09 PM   #795
Strodder
Strodder's Avatar
They aren't from a boat, they're from a 65 Corvette
http://www.corvetteamerica.com/cf/di...xhaust%20bezel
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-04-2009, 01:12 PM   #796
daverod
SSN 706
daverod's Avatar
I've been using my aircompressor to fill my air bags. I was worried about the pressure. Whats the max pressure I should put in them?
Old 10-04-2009, 01:40 PM   #797
Strodder
Strodder's Avatar
Depending what kind of bags they are, but 150 to 180psi should be OK. 250 to 300psi you might pop them, unless they are Slam Specialties bags. Also it will hop the truck like hydraulics do. My son has a 55 Caddy that he hops with bags. It blows peoples minds hopping a heavy car like that.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-04-2009, 01:40 PM   #798
daverod
SSN 706
daverod's Avatar
Like I said they sure are proud of them. Must be because there for a "vette". Mustang ones are cheap. I like the look of the vette ones though.
Old 10-04-2009, 01:47 PM   #799
Strodder
Strodder's Avatar
Again look in E-Bay. Mustang is a thought also. But I like the Corvette ones better too. They're at a better angle.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-04-2009, 01:56 PM   #800
daverod
SSN 706
daverod's Avatar
I looked on ebay. I saw there's some at a lower price $43 but lets see what they sell for. I'm thinking $100. Ya the mustang ones look cheap. I'm only putting about 120 in my bags so I'm safe. Worried my though. Just did'nt want to hear a big pop.
