01-25-2012, 09:07 PM | #776 |
low n' slo
Re: My 68 swb build.
man that column looks good...
truck is turning out nice man..i like it!
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
01-25-2012, 09:21 PM | #777 |
I ordered the same column for my build....... don't think u can beat it for the price
01-25-2012, 10:50 PM | #778 | |
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
01-25-2012, 10:51 PM | #779 | |
01-26-2012, 12:27 AM | #780 |
"Junkyard Dog"
Nice job so far. Love the look of the grill!
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
01-26-2012, 01:54 AM | #781 |
Still plays with trucks
The column looks great. I might have to get me one.
Have you looked it over to see if a stock NSS can be fit to it?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
01-26-2012, 08:05 AM | #782 |
theres no place for a nss, so im still pondering cutting the column to add one...i think the diameter of the shaft is the same size so it might not be a problem, but just the thought of cutting up a new column disgusts me slightly...the only real reason i want the nss is for reverse lights..
01-26-2012, 05:54 PM | #783 | |
01-27-2012, 08:35 AM | #784 |
didnt get but one pic last nite, but its nothing extravagant... managed to get the pressure line for the powersteering done...i found a hose that works, i hope. the return line may be a little high, but im gonna leave it until i get inner fenders.
got my other steering column torn apart and got all the rubber and steel mounts off of it and transferred to the new column. was gonna put it in, but tuckers truck parts sent me the wrong u joint for the gearbox...i will be calling to get the right one... and lastly i got the ebrake pedal assy somewhat finished...had to cut it 2 inches or so to clear the shaved firewall...welded it up and ground the out side smooth. I hope this works cause this cab is no way a 69 because the mounting point under the drivers vent is not there. the hole is not drilled through and the roll on the bottom of the dash is the same the whole length of the dash...took a pair of vise grips and bent that sucker over so it would fit...all thats left is drill the holes for the mounting studs, hole for the cable, blast, paint and install...
01-29-2012, 02:34 AM | #785 |
got these in friday...too bad the gearbox is the wrong size so i gotta send it back to get the right one...didnt know the spline was a 5/8"...
01-29-2012, 02:36 AM | #786 |
got it drawn and cut...not that pretty but i did what i could with what i had... got the tab tack welded in...next i have to drill and tap the holes for the mounting...
01-29-2012, 04:50 AM | #787 |
Keep up the great work, for every 100 that look at your thread only about 1 will post so believe me that people are definately interested.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
01-29-2012, 05:09 AM | #788 |
Thanks for being brave and cutting into that column. Now I know what to do to make it work
01-29-2012, 09:36 AM | #789 |
Looks good! And I dont see anything wrong with what you have done.... A little thought can save a lot of money.....
01-29-2012, 01:31 PM | #790 |
right....lol it took me a few mins to realize im gonna cut it up...lol i think its gonna work...honestly looking at it, i dont think it matters where you put it just make sure that you weld the tab in the correct place.. what ive found is as long as the opening is the correct size and the tab is welded 1/2 inch on the park side...if that makes sense...
01-29-2012, 01:32 PM | #791 |
yup yup, i just hope it goes in easy..
01-31-2012, 08:52 AM | #792 |
i think i got the temp gauge working. i think the problem may be with the headlight switch. the gauge works when heat is applied to the sensor, and falls back to cold when taken off. ill buy a new switch and see what happens...
02-01-2012, 07:37 AM | #793 |
Yeah man. I usually look to see what's going on too, just don't always have/know what to say. You're making good progress man. Can't believe you cut into that column! I'm sure you'll get it working good though.
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
02-01-2012, 11:19 AM | #794 |
^^^^^Me Too. You have a great build going. I feel the same way sometimes about my thread. Keep up the nice work Bud!
1972 GMC (PROJECT LONG OVERDUE) 1998 SWB 4WD |
02-01-2012, 10:40 PM | #796 | ||
02-01-2012, 10:44 PM | #797 |
got the volt meter installed and will only have to take the two existing wires for the ammeter on the pigtail and run an ignition hot wire...and ground of course...what yall think?
02-01-2012, 10:48 PM | #798 |
VA72C10
very nice!!!
Looking for a 67-72 swb or blazer project in or around VA. |
02-02-2012, 10:59 AM | #800 |
Sofa King Crazy!!
Chris, that looks great! Yeah, that's gonna happen to mine! Might be able to get my guages out this weekend if my back has healed enough. Definetely want to do that!!!!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
