06-30-2020, 09:13 PM | #776 |
I'm trying....
Re: 67 GMC super custom build
'Awesome'? 'Ford'? My good sir, I must protest.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
06-30-2020, 09:55 PM | #777 |
Yeah I know. But ford used the exact same speed sensors in 1969-73 for their cruise control as gear vendors does so the bracket was taylor made for that sensor and looks completely like it should be there. I know it's still a Ford part. At least it doesn't have a fomoco part number stamped into it. I would have had to fill it over.
06-30-2020, 10:13 PM | #778 | |
I'm trying....
06-30-2020, 10:23 PM | #779 |
1972 K10 1986 K30 crew cab dually 2002 Z06 2007 Escalade |
07-03-2020, 09:56 PM | #780 |
If there's one thing I hate it's having metric bolts on my 67. My new ac compressor came with metric threads for the front bolts. I tapped them to sae threads. I'll be putting the original style decal on to cover these when it's completed.
07-17-2020, 01:23 PM | #781 |
Got my new engine drive belts. They are just as the originals were cloth wrapped and stamped with the gm part numbers.
07-17-2020, 02:44 PM | #782 |
I'm trying....
Now that's what I'm talking about! Looking good.
07-17-2020, 03:50 PM | #783 |
07-21-2020, 02:00 PM | #784 |
Although I love my original hub caps and radial tire look (which I'll never sell) I purchased a set of these with the blank small 67 center caps. I'm going to have my cnc guy make me a gmc center to mount in the smooth part of the center cap. They do make the tall centers now with the words " general motors corporation" but I'm not sure I like the tall cap look. Just don't want a bowtie on my gmc
07-21-2020, 02:34 PM | #785 |
That will look pretty awesome!
08-27-2020, 06:37 PM | #786 |
Got me some Nos rockers locally!
09-01-2020, 05:56 PM | #787 |
I'm trying....
Dyn-o-mite!
09-03-2020, 05:59 PM | #788 |
It's goona be slow for a bit here now. Petty much all that's left is the metal and paint but nuke1 closed up shop so I'm looking for a new "quality" shop to do the work. I don't want to waste all my Nos pieces on an amateur again.
09-15-2020, 08:22 PM | #789 |
I picked up one last option to put on the 67 before metal work starts. It is the hd air cleaner. It requires I change my air cleaner. I may try to adapt the snorkel into my existing one but we'll see. I'm just missing the hose that goes from the air cleaner to the pre-cleaner if anyone has one to sell. Also picked up a gm tissue/litter container. I'll be matching it to the interior color.
09-25-2020, 07:29 PM | #790 |
I got the pre cleaner yesterday. It has a flap in the inlet that is operated by a spring. When not moving it must suck air from the engine bay and when your driving the air forces the door with the spring down and closes off the air inlet to the engine bay. I wonder if I could get this decal off without ruining it?
09-25-2020, 11:16 PM | #791 |
Heat to the backside and then a razorblade underneath. I've removed stickers like that. Takes a while. Something else that can help if the sticker isn't paper, is goo-gone. That stuff under the sticker will take the sticky off like butter.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
09-26-2020, 03:17 AM | #792 |
Ok I will try that possibly on a decal on another cleaner first. Have you successfully reused one after removing it?
09-28-2020, 10:08 AM | #793 |
Yes if it's not paper
You can use the same glue for headliner to make it stick and not be permanent. Or if it goes somewhere where it will get wet, make sure to use something water resistant.
09-28-2020, 11:31 AM | #794 |
I'm trying....
Not that I really want to get another decal project going, but I'm happy to help if it doesn't come off cleanly. You know I like this project.
Take careful measurements before you attempt removal...that's always helpful. If there is not a good reproduction version currently available, it shouldn't be a particularly difficult one to do (if you want).
09-28-2020, 06:43 PM | #795 |
If I can't get it off I would like to have another made. I will take good measurements just in case. Probably do it on the weekend coming up
09-28-2020, 07:07 PM | #796 | |
I'm trying....
EDIT: After a quick internet search I found a lot of these decals, just no 6420553s.
09-28-2020, 08:42 PM | #797 |
Yeah I couldn't find the correct part number either
I'll keep you posted if this comes off clean or not |
10-01-2020, 08:53 PM | #798 |
Got it off unharmed!
10-01-2020, 08:55 PM | #799 |
I'm trying....
You're a surgeon. Well done.
10-17-2020, 06:31 PM | #800 |
Well it's all about the details around here. I finally found the correct cast iron pulley for the 67 air injection. I've seen 2 factory smog 327 trucks and they both had the cast iron pulley. Last pic is the only photo I have of an original still on a truck.
