#776 | |
Re: 1977 Chevy C10 known as SharkBite
I like the idea of using the bracket you showed me but I would hate to get it and get the same results from it you know? I did notice it was adjustable which I think that's the positive to it all.
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
#777 |
The adjustability of the bracket is nice, but depending on how severe the kink is, it might not help you. I looked at a few lokar cables on summit's website to see what they say about overall length and most say you'll need to measure from the firewall to the carb bracket and add about 2" extra length. This will allow for engine movement. I'm assuming it will bind pretty badly or even kink if you have way more than that (6" plus??)
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#778 | |
The kink is minor we have it narrowed down if it was shortened 1" overall in I would be fine, so if that adjustable bracket could solve that I would go that route because it's minor issue.
#779 |
You're lucky I live less than a mile from work. I ran home and snapped this pic.
#780 | |
#781 |
I want you to know that I did not install this. I really don't like how it looks and I think it was a bit rushed when the PO put it together. I mean, who puts the return spring forward of the carb, instead of back toward the firewall? Oh, and it doesn't have as much play in the cable as I think there should be. I'd say he has about an inch of extra cable. And the throttle kick down cable is at an angle.
Needless to say, I'll be fixing this later on down the line. It works though, so it's not high on my priority list.
#782 |
It's on my C-10 and yes, I have the same setup as you.
#783 |
I have a factory throttle bracket on my GTO. It's MUCH different than aftermarket items so it wouldn't help you at all.
#784 |
Sweet! Hince why you suggested the part to me
![]() Okay now let me ask you this though how would you put the return spring towards the back of the firewall because I know for me I would have to cross over the throttle linkage and kick down. Now I'm not saying it's right but I know one of my friends on his dad's 76 that's how it's done and then a couple people on the forum has done it this way as well.
#785 |
Hmm... You know... I don't have a good suggestion with the bracket I have. I don't see a good place to connect it on the bracket, or the throttle lever. Not sure what brand it is though.
The link I posted earlier has a small piece that points downward near the throttle cable connection point. The return spring could connect to one of the two holes in that bracket, but I'm not certain how you would connect it to the throttle lever on the carb. The return spring on my GTO (using edelbrock 1405 carb) has a vacuum kickdown for the trans so the lower hole in the throttle lever is open... that's where the return spring is connected, then back to the throttle bracket.
#786 |
Here's what I'd plan on using. Check out the instructions for this throttle cable. It shows the bracket with the kick down connection. http://www.summitracing.com/parts/lo...a/instructions
Keep in mind that this only works with the lokar throttle and kick down cables, not OEM.
#787 | |
Maybe that's something I'll be able to figure out for us because I'm not going to lie I don't care for it in the front too much, of course as a temporary hold that's what I'm going to do but I rather have it facing the back as well but there's got to be a way to do it. I like your kick down bracket from I think it's a 700r4? I need to get something like that.
#788 | |
#789 |
I've got it...
You can make a bracket that mounts to the back side of the throttle lever at the transmission kick down stud. Similar to the small bracket (flat piece) in this picture. The large hole is for the kick down stud and the small hole would be for the spring. I'm sure you could use all kinds of things to accomplish the same task. It just needs to be strong enough not to bend or tare out from spring tension.
#790 |
You Duane, are an absolute genius!
That sounds just about right. Well correct me if I wrong, but instead of having like that big bulky side piece if you just fabbed up something like the top half and then just drilled a hole in the correct spot that could work too huh?
#791 |
I'm not sure I'm following you. Please explain... maybe I've used up all my genius for the day
#792 |
![]() And since you would be using the hole given where the kick down would go just drill another hole big enough to put the kick down cable through but put it lower than the original one. Obviously you would need a spot to put the return spring so then just take a drill put a small hole for your return spring then bam! Done! Does any of that make sense or am I trying to think like a genius just not one? ![]()
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal Last edited by 77ChevySharkBite; 10-11-2013 at 11:40 AM. |
#793 |
Are you thinking about adding a small hole to the throttle lever on the carb? That could work if it's in a good spot to give the spring some leverage. If you're thinking about moving the trans kick down further down, you'd be adding more to the throttle lever... same concept with the little eyelet idea for the return spring... If i'm understanding you correctly. This is why I like pictures
![]() If you're talking about the throttle cable bracket in the picture I posted, I'm wondering if you're seeing it correctly. The oblong hole at the top of the pic is to mount the bracket to the carb. The 3 holes in-line with each other are for the throttle cable (largest hole) a bolt hole for another trans kick-down bracket (middle hole-kick down bracket not shown) and the return spring hole (bottom hole). EDIT: oh, and this bracket is for the lokar style throttle cable. Not sure how you'd mount a factory throttle cable to this.
#794 | |
![]() ![]() Yeah I don't think I understand your picture right, I was thinking that screw with the bolt would go into the existing hole of the kick down cable, and the other were holes for misc items that's why I was thinking you could fab up something using mostly stock components or using the components that already came on the edelbrock carb. I wonder though if I could actually fab up something like I just mentioned in the sentence before this one, what you think?
#795 |
You can always try. If it works, great... if not, continue on the path you're on... new bracket and/or cable. No harm in trying.
EDIT: that screw you were looking at is supposed to help keep the bracket from rotating on the carb stud, since that's the only location it mounts to the engine.
#796 |
Cool well looks like I get to learn how to weld then
![]() I think I'm going to try and take the Lokar's idea but of course improvise it a little bit so we shall see how things turn out. Thanks for all the help today Duane! You rock bro!
#797 |
Here's the spectre bracket at advance for $15. Might be hard to make one for less. Considering your time and materials, welding etc. Just an idea.
Spectre Bracket The website says it has to be ordered online though. And a Mr. Gasket bracket at Oreilly's for $20. Mr. Gasket Bracket My local store has this in stock.
#798 |
Let me suggest, if you're going to attempt to make your own bracket, try to put your idea on a piece of card stock, or poster board or something like that so it has a bit of rigidity but still easy to fold and cut. Cardboard will work, but use a cereal box or something, not a shipping box.
figure out where you want your bends and how you want it shaped, mark your bends and holes in ink, then flatten it out and trace it on a piece of metal (steel, aluminum, stainless, whatever you want) and bend it where you put your marks on the cardboard. Drill your holes, and mount it. Much easier than trying to weld everything together.
#799 | |
![]() For the throttle cable bracket that's what I'm actually going to buy, what I'm going to try and attempt to make is a custom kick down/return spring bracket to have the return spring at the back instead of the front that does that make sense?
#800 | |
