12-12-2016, 08:57 PM | #776 |
Re: Loadmaster '47 COE
i think it's appropriate.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
12-12-2016, 09:09 PM | #777 |
Rob, I hope you do the camper build here. Your problem solving and build skills are great to learn from.
12-12-2016, 10:20 PM | #778 |
Do it here Rob. Can't wait to see what you come up with.
Keith |
12-12-2016, 10:40 PM | #779 |
Definitely wanna see the build! Gives me bad ideas!
1958 Apache 454ci 4 speed |
12-12-2016, 11:30 PM | #780 |
Make it Happen Rob!!
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
12-13-2016, 06:18 AM | #781 |
Keep her rollin here. I do not know of any campier/camping sites that would be of any help.
12-13-2016, 09:32 AM | #782 |
Take a look back on page 3, post 64 of my build thread at option 8.2. Look familiar? Not to far off for a plan made back in 11/13.
Rob
My '47 C.O.E build |
12-13-2016, 09:56 AM | #783 |
So here we go: These are some ideas of what I am going to attempt for the COE camper. These where drawn with the idea of using steel as the wall frames but I'm starting to lean towards wood. Yeah I know, some of the things in the drawing don't work out (under bed storage and dinette set), it's just the details that I need to figure out. Ha, just the details, how hard could that be?
Rob
12-13-2016, 10:25 AM | #784 |
Yes sir that'll work
Mark...
12-13-2016, 10:53 AM | #785 |
This is gonna be cool to watch .
12-13-2016, 04:43 PM | #786 |
This is going to be so cool. Can't wait.
On my 18' trailer I built 7 years ago. I have steel floor frame, 2x2 steel tubes in corners then wood 2x4 supports for the walls and 2x2 roof. I then used plywood for the front V and transport trailer aluminum siding for the roof and walls. Might save a bit of weight. Also I have to paint the wood every 2 years and have yet to touch up the aluminum. Just some food for thought.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
12-13-2016, 06:23 PM | #787 |
Very nice Lower. How did you attach the floor and walls to the steel frame? I was thinking 1 1/2 square tube with bolts. I would need to bore a larger hole in the bottom of the frame as to keep it flat on the bottom. I think my biggest issue will be the changing radius for the top, that's gonna be a challenge. I think I have got it figured out how to attach the camper steel frame to the steel truck bed and how to remove it so I can roll it into the shop when not in use but other things are yet to be solved. By the way the goal is to complete it by April 1st of next year and 3K max.
Rob
12-16-2016, 01:07 AM | #788 | |
the only problem I see with making it removable is that it will have to be self supporting, and that may add a whole ton of weight and bracing. why not make the thing sectional, so a two piece roof and it latches to the sides which also remove individually? it gets its assembled strength from the attachments and doesnt need lifted. just spitballing
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
12-16-2016, 07:51 PM | #789 |
I could take a pic but this is prob better. Hope this helps. If I ever build another I am doing it the same.
12-17-2016, 05:29 PM | #790 |
Got started on the frame for the camper today. I started by making a a rectangle frame out of 1 1/2" square tubing. To that I added 1 1/2 X 2", 1/4" angle iron for cross bracing. With the 1/4" I will later be able to drill and tap to attach the flooring. The frame should go in the 250-300# range when complete. The angle pieces where used to keep it square while welding. It should end up even with the rear of the bed but hang over on the sides just a touch. More floor supports will go on, ran out of steel.
Rob
01-02-2017, 10:12 PM | #791 |
OK, so i'm taking some small steps in the camper project. I picked a square tubing roller and modified the truck to haul 20 foot sticks of tubing. The idea being I don't need to have them cut just to get them home. One plus of having a steel bed is I can weld on it and just grind it back off later
Rob
01-02-2017, 11:38 PM | #792 |
Love the camper idea. This is a project I'd love to do. I've always thought of using aluminum square tubing and bolting it all together if I didn't have the proper welder in order to save weight.
Having that roller will make is super nice regardless of what you use tho. Posted via Mobile Device |
01-03-2017, 07:17 PM | #793 |
Check out homemade teardrop trailer forums. They're different but have the same systems you'll face. Might give you ideas too.
Have you thought of a leveling system that's attached to the truck or camper? Large stands like what pickup campers use. |
01-03-2017, 07:58 PM | #794 |
Nice tool!!
Found this on FB
01-03-2017, 09:39 PM | #795 |
So you need to haul 20 foot sticks of steel tubing? got it covered. Started working on the walls today. Got the first basic frame shaped. First one wasn't bad, matching it will be a chore. Cool FB pick, Thank you.
Rob
01-03-2017, 10:11 PM | #796 |
Now that is some impressive work with your tubing bender! Which one do you have?
01-04-2017, 12:42 PM | #797 |
great ideas and craftsmanship. I like the idea of hauling 20ft pieces.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
01-04-2017, 05:55 PM | #798 |
It's a TR-40 model, Chinese made of course. Actually the quality looks to be pretty solid. Cost $300.
Rob
01-05-2017, 04:19 PM | #799 |
Nice!
http://67-72chevytrucks.com/vboard/s...d.php?t=648783 |
01-06-2017, 11:37 AM | #800 |
haha what a great way to haul steel.
