Old 03-03-2016, 10:49 AM   #776
RockinKees
RockinKees's Avatar
Re: Dutch '59 Fleetside Longbed
Originally Posted by Kim57 View Post
Bed repair looks good.
Forgot about the Jag rear end.
Kim
Thanks Kim.
There's so much fantastic builds here on the board you almost forget who is building what
dug224
Yeah, your bed is in great shape. I have a similar giant CB Antenna hole in my cab. Looking good.
Thanks Dug224!
The bed is in great shape!
I think you have more work on your bed
The hole was 2", I think for gas filler, altough it was a bit low...
Who's using CB antennas nowadays? Must be from the 70's or 80's?
Only did a little primer today:
See if I get the time to spray the rubber undercoating tomorrow...
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 03-03-2016, 01:39 PM   #777
ptc
ptc's Avatar
Thanks Kees!.... this aint a cheap hobby anymore, so every penny or 'Euro' counts these days.
anytime I can help out, just let me know
Project is coming right along!!!!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 03-04-2016, 03:42 PM   #778
lower50's
lower50's's Avatar
Drive shaft hoop looks good and strong.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-07-2016, 03:24 AM   #779
deejaaa1
you are doing some great work. loving your build.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 03-15-2016, 05:53 PM   #780
RockinKees
RockinKees's Avatar
Had a little time in the Hot Rod Shed.
First sad news, our shop dog has passed away. She had a very good life with the owner. She was an original Blond Labrador and reached 14 years old.
R.I.P. Laila.
It's hard, but work goes on...
Had my son help me put the bed on. It's beginning to look like a truck again
I think of making the gas and propane filler where I marked the square on the bed.
Tonight I put the cross sills in and bolt them down:
Now I can route the propane lines, hang the exhaust, finish the truck
Here you see how I routed the exhaust
The propane tanks are nicely under the bed
Cheers!! Kees.
Kool Guyz CC
Old 03-15-2016, 06:06 PM   #781
dug224
dug224's Avatar
Must be the season to work on truck beds!! Looks great. So sorry to hear about the dog. dug
dug224 is offline   Reply With Quote
Old 03-15-2016, 07:58 PM   #782
Advanced Design
Advanced Design's Avatar
Sorry to hear about Lalia, Kees. Truck is looking like a really nice truck!
Advanced Design is offline   Reply With Quote
Old 03-16-2016, 02:17 AM   #783
Nut Case
Nut Case's Avatar
Sorry to hear about Laila, Labs are the best. Keep on keeping on. Nut Case
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 03-16-2016, 08:22 AM   #784
Kim57
Kim57's Avatar
Sorry to hear about Laila.
Truck looks good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-16-2016, 09:16 AM   #785
Steve-W
Steve-W's Avatar
oh damn.. R.I.P laila.. unfortunatly we have had many dogs, so I know what You going through. all the best to you and your family.
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 03-16-2016, 03:40 PM   #786
lower50's
lower50's's Avatar
R.I.P. Tanks fit under there real nice.
1951 MG TD
Old 03-18-2016, 09:30 AM   #787
reaper71
reaper71's Avatar
Sorry my friend!
Mark...
reaper71 is offline   Reply With Quote
Old 03-18-2016, 07:18 PM   #788
RockinKees
RockinKees's Avatar
Thanks a lot guys!!
Laila wasn't our dog, but of the owner of the property I'm having the truck at.
But I've known Laila her whole life, since she came there. Beautiful dog, always happy when I arrived!
Yeah, will miss her.....
Didn't work on the truck these last days, have some brain issues to deal with
Hope Monday will be a good truckday...
Cheers!! Kees.
Kool Guyz CC
Old 03-23-2016, 04:55 PM   #789
RockinKees
RockinKees's Avatar
Feeling good!
So had some things done, first I welded a drain plug in the trans pan.
I had an old engine oil pan which gave his drain plug
I also made bung on the lathe for a transmission oil temp sensor, welded this too in the pan:
Welded these two inside and outside to make sure they doesn't leak.
Fresh coat of paint and it's ready to go.
I want a rollpan at the rear, and want a hidden hitch reciever. So I have to make one, easy!
Made the two 90 degree angles in the metal brake and now had to come up with something to make the radius for the bottom...
I took some 3/8" straight iron and the stainless pipe I will use for the cooling pipes, and bended the future rollpan. It was pretty heavy to do, but it worked
The beginning:
As you see I have to make it in two pieces.
How I made the radius:
Well, that's it for today.
Cheers!! Kees.
Kool Guyz CC
Old 03-23-2016, 09:10 PM   #790
Advanced Design
Nice work on the roll pan Kees! Creative solution on that and the transmission pan drain plug.
Old 03-23-2016, 10:15 PM   #791
Nev68
Nev68's Avatar
Good work Kees. Do you have workshop with lathe and sheet metal folder at home?
Nev
Need a bigger garage so I can keep more cool cars alive
My build, a long way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=595909
Nev68 is offline   Reply With Quote
Old 03-24-2016, 05:19 AM   #792
RockinKees
RockinKees's Avatar
Thanks Doug and Nev68!!
Nev, unfortunatly I have no room at home to build cars....
I have a small shed behind my house where I build motorcycles, here I have the lathe, drill, TIG welder and most of my tools. On the motocycle lift is currently my old Harley which I'm building in Bobber style, it's sold. Riding motorcycles is over for me unfortunatly....
The truck is at a friends house where we built a shop just for me
The metalbrake is homebuild and is there, it's not perfect but it does its job, with a little persuation
So, I'm lucky to have two shops
Cheers!! Kees.
Kool Guyz CC
Old 03-24-2016, 08:16 AM   #793
Kim57
Kim57's Avatar
Nice fab work.
Kim
My build thread
Old 03-24-2016, 09:35 AM   #794
oldman3
oldman3's Avatar
Looks good...Jim
oldman3 is offline   Reply With Quote
Old 03-24-2016, 01:36 PM   #795
ptc
ptc's Avatar
Coming along just great Kees.... youre gonna be driving soon!
Old 03-24-2016, 04:09 PM   #796
RockinKees
RockinKees's Avatar
Kim, Jim and PTC, Thanks a lot guys!!
One step further....
I welded the two parts together, and ground them down so they fit the rear:
I decided to make it a bolt-in, so I made some simple brackets to hold the pan at the sides. Stainless screws will tighten the upper side.
This is how it's bolt in at the right place:
It looks better in real life as in the pics...
Now I have to think about the hitch reciever.
I want it to be hidden....
Well it is now
Have to think about making a recessed, hinged licenseplate holder, any tips are welcome!!
Maybe some hinges that are spring loaded or hinges and wingnuts...
Pictures about this item are also very welcome!
Cheers!! Kees.
Kool Guyz CC
Old 03-24-2016, 04:16 PM   #797
RockinKees
RockinKees's Avatar
Just came across this:
This could be a simple sollution.
Only have a risk of a stolen plate.....
Cheers!! Kees.
Kool Guyz CC
Old 03-24-2016, 04:19 PM   #798
MalibuSSwagon
Most commonly used is the flip down plate bracket from a 70's to 90's GM car with the rear gas fill...77-96 Caprices and similar big GM cars use them, 70's Camaros and Firebirds. Spring loaded for ease of use.
MalibuSSwagon is offline   Reply With Quote
Old 03-24-2016, 05:18 PM   #799
Kim57
Kim57's Avatar
Roll pan looks real good.
Kim
My build thread
Old 03-24-2016, 05:52 PM   #800
RockinKees
RockinKees's Avatar
Kim, Thanks you Sir!!
Eric, I've just ordered spring loaded hinges. I was at G**gle and saw those fold down plates. But as I live in the Netherlands I have to search for US cars. European and Japanese cars are no probleem. I mean at the junkyard then
I decided to make it myself, but then fold up ( more room).
Thanks for the tip!!!
Cheers!! Kees.
Kool Guyz CC
