#776 |
Re: What did you do with your truck today, take 2
Putting new lights in the shop.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#777 | |
More light is always good! Led? |
#778 |
Wifee sewed up a new headliner and installed that along with new carpeting. And got the seats in.
#779 |
Very, very nice!
#780 |
Milestone, makes it look like months of progress! Wife did a good job.
#781 |
Not done by me, but a shop haha. But got my headliner and door panels made. Getting him to make me kick panels, and a panel behind the seat. also inner fenders and radiator cover too.
1954 Chevy 3100 5 window, bagged on s10 frame, 6.0 ls swap/4l80e Past build thread http://67-72chevytrucks.com/vboard/s...=531261&page=3 1949 3100 s10 swap 5.3. Instagram -@thejcates |
#782 |
Nice cruiser! What are those seats out of. Great wife you got there.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
#783 |
The seats are out of a 2008 buick rendevous, second row. The centre folds down for arm rest plus a tims holder.
#784 |
Tim's holder. Ha! How'd ya mount them? They look great in there.
#785 |
Made up a rectangular frame that bolts directly to the floor where the original seat went, bolted the buick seats to the frame
#786 |
Finished cleaning bottom and put in primer. My hands are tired....lol
#787 |
A320 Pilot/USAF Retired
Inventoried the Altman East Latch Kit I got from Yogi's. Hope to install it next weekend!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#788 |
if that is your frame the cab is sitting on you want to beef up that crossmember that has a piece cut out.
#789 |
Thanks dsraven.....that is the frame and yes it will be beefed up. Thanks!
#790 |
111
1953 Chevy 210 convertible, 1955 GMC pickup, 1957 GMC Suburban Carryall |
#791 |
57 chevyman- regarding your damaged paint- speaking as an insurance professional, I would suggest you go thru your own insurance company. You will initially have to pay your deductible, but you will probably have more control in choosing where you want to get it fixed. Explain the custom paint situation to your claim representative- he may be more than glad to have you handle where it goes for repairs under the circumstances. Once your company collects back the repair cost from the other company, you will get your deductible $ back.
If you go thru the other guys business insurance, there's a real good chance they will direct you to the shop of THEIR choice and no guarantee of the results, and your stuck with it..
#792 |
Rewired the headlight buckets and replaced the adjusters.
#793 |
I made a "die" for my patch panels I will make for the cowl. I cut out one side and had plans to just hammer it out but then remembered the drivers side was rusted even worse to I thought I would make this "die" out of 12 gauge sheet to hammer the line into them.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#794 |
Put dash in primer and worked on tucking in front bumper.
#795 |
Looking good!
#796 |
Attempted to start stripping the paint off. I found it this thing has had at least 4 primer/paint jobs, original color appears to have been white. I tried using 80 grit and went through about 8 sheets and only really cleared about 2' of the top of one fender and that area by far appears to be the 'easiest' to strip
#797 |
I drove mine for the first time! Bought it a few months ago not running and finally got it going! Been 15 years since it had been on the road according to the previous owner...
Still several bugs to shake out but it drove! Also moved it to the garage so I can work on it more. |
#798 |
made the brackets for the sending unit on the transmission.
the sender powers the gear shift indicator. Also made an oil pressure piece to hold the classic instruments sending unit. Machined it from 6061 aluminum.
53 Chevy Pickup |
#799 |
Started the rust repair on the other rear fender(not as bad as the last one). By the way, found an old dive weight, works great as a dolly!
1958 Apache short bed |
#800 |
![]() Join Date: Aug 2012
