11-06-2018, 08:26 AM | #776 |
Re: "Project Orangepeel" 52 A.D
Awesome Thanks
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
11-06-2018, 07:52 PM | #777 |
Pic 1. This is my scribe gauge I made a while ago.
Its fully adjustable Pic 2. Make a perfect line set at the length you need. Pic 3. Cutting the tube in half for a lower riser. Pic 4-5 I'm using (My friend John's) porta-band from Harbor freight (Bauer) and have it mounted to a portable table from swag off road. The saw is usually on sale $140 and the table goes for $125, This super useful for cutting tubes under the vehicle and with the table you can cut shapes pretty easy. Mark
11-06-2018, 08:02 PM | #778 |
thats a neat setup! thanks for the tip, I have always wanted a small band saw setup and that is certainly not expensive.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
11-07-2018, 08:52 AM | #779 |
Joedoh, It's a really handy unit to have.
Cuts through tubing like butter!
11-07-2018, 10:42 AM | #780 |
Post Whore
that is a nice bandsaw setup...luckily my horizontal saw will standup vertical....it just doesn't have abig table...but I could easily make one for it..
11-07-2018, 12:07 PM | #781 |
I have the Milwaukee saw (got used on Craigslist) and that Swag table. Yes, it will cut! Like Reaper said, it's nice.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
11-07-2018, 08:57 PM | #782 |
You can't have to many tools right Guy's!!!
Mark
11-07-2018, 09:15 PM | #783 |
update:
Pic 1. This is why I was showing the saw, I cut it in half to make risers for the radiator. the radiator has a pocket on the bottom and these will fit inside of it and lock it in place. Pic 2-3 I made these plates to tie in the upper fender to the radiator uprights. Pic 4. Cut and welded in. Pic 5. Starting to take shape. Mark
11-08-2018, 05:37 AM | #784 |
Great tools, these bandsaw, my buddy has one too!
Great idea for the radiator! Within a few day I have to build a radiator in the Mustnag II of my son, his alternatorbelt went through it... You give me great ideas!! Thanks!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
11-08-2018, 08:33 AM | #785 |
dude that saw set up is awesome. I like that is not a huge unit that is planted in my already tiny garages!!! Core support is looking good. I'm in the process of designing one myself. thanks for the tips!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
11-08-2018, 08:35 AM | #786 |
Thanks Kees!
Good luck with the Mustang
11-08-2018, 08:41 AM | #787 |
Kees, speaking of Mustangs this is a customer's car I had done suspension,rear end etc. On a few years ago.
He had some fender damage that needed fixing, anyways I talked him into respraying the car in matte clear. Mark
11-08-2018, 08:46 AM | #788 |
Thanks 99!
It beats having to cut everything with a cutoff wheel (and the stink of said wheel) by a mile!! and it takes up minimal space. I've seen some guys making a stand for these that can be moved around the shop. Mark
11-11-2018, 10:00 AM | #789 |
Pic 1. Radiator set in place, now I can make a upper mount.
Pic 2. I didnt take shots during this step. The 2 bolts closest to the radiator come out and the upper mount lifts a bit and slides out. Pic 3. a closer look of the passenger side where it's slotted to slide around the filler neck. Pic 4. Now I can move on to the radiator splash apron, I had one but it was so tore up I cant use it. So i will need to find a new one. Mark
11-11-2018, 10:29 AM | #790 |
That’s some nice enigering Mark!
Good looking Mustang too! My son has a Mustang II, the car nobody wants....but it is a really nice driver!
11-12-2018, 08:47 AM | #791 |
Thanks Kees
My best friend had one in High School, thought it was a racecar! Nice work shed btw Mark
11-16-2018, 09:22 AM | #792 |
Not much of an update, but here is a few shots of the truck with the hood back on.
I needed to put the hood on to check fitment of the hood to fender placement. I will need to make some adjustments with the core support I made to help with the fender support. Mark
11-16-2018, 10:16 AM | #793 |
You do some nice metal work!
11-16-2018, 11:06 AM | #794 |
killer
11-16-2018, 12:48 PM | #795 |
looks outstanding, really really nice work.
I am waiting on a DAR determination this morning, leafing through the AD FSM with my coffee looking at how to adjust the hood, I moved my hinge and that didnt really help anything.
11-16-2018, 01:33 PM | #796 |
Really like the front this way!
Wish those LS engines were so easily available overhere....
11-16-2018, 08:17 PM | #797 |
Thank You Guys...very Kind!!
11-16-2018, 08:18 PM | #798 |
Kees, We could always check on the shipping and get one on the way!!
11-18-2018, 05:00 AM | #799 |
That would be awesome Mark!!
But first have to do some fundraising then....
11-18-2018, 09:52 AM | #800 |
HaHa I feel your pain!
