Old 04-13-2022, 10:48 AM   #776
Gregski
Post Whore
Gregski's Avatar
Re: My Dusty 71 GMCe Electruck
Originally Posted by tutone View Post
Let me be the tin hat in the room. Somebody doesnt want you building an electrified truck and them not share in the profits? Just a theory.
that is on point, and you think Tesla's lab caught on fire by accident, hmmmm
Gregski is online now   Reply With Quote
Old 04-13-2022, 12:43 PM   #777
jimbosprint
jimbosprint's Avatar
Cloud backup. I use Google Drive.
jimbosprint is offline   Reply With Quote
Old 04-13-2022, 01:21 PM   #778
Gregski
Post Whore
Gregski's Avatar
yes me too, but I was manually copying stuff there and so I have about 90% of it backed up, I could not figure out how to make it automagical (I used to have it like that I think, then something changed)
Old 04-13-2022, 09:54 PM   #779
DoubleDubya
I agree with tutone. The same thing is happening to you that happened to that guy in the 60's that invented the 100mpg carburetor. Keep your doors locked and the blinds pulled. Good luck.
DoubleDubya is offline   Reply With Quote
Old 04-13-2022, 09:58 PM   #780
Gregski
Post Whore
Gregski's Avatar
just because everyone's out to get me doesn't mean I'm paranoid
Old 04-13-2022, 09:59 PM   #781
Gregski
Post Whore
Gregski's Avatar
so we pressed on with the firewall
toper wear lids aint just for tuna casseroles you know
Old 04-13-2022, 10:03 PM   #782
Gregski
Post Whore
Gregski's Avatar
let's put on our hole saw attachment on our angle grinder
Old 04-13-2022, 10:04 PM   #783
Gregski
Post Whore
Gregski's Avatar
then a quick pass with the SharpEdge Eliminator 2,000 SemiPro
Old 04-13-2022, 10:10 PM   #784
Gregski
Post Whore
Gregski's Avatar
I am 67-72% certain that I welded up some holes I should have left open, and forgot to weld up sum that should be shaved, anyway I just had to bazinga that firewall today and I hate spray bombing stuff even if the rest of the rig does look like death so out came the Dexter Starter Kit
Old 04-13-2022, 10:30 PM   #785
Gregski
Post Whore
Gregski's Avatar
Oh Top Tip on the grindage of the firewall, get yourself some brand new coarse sand paper discs, the new discs will generate less heat than the old used up ones and prevent the sheet metal from warping
I think these were 36 grit
Old 04-14-2022, 10:03 AM   #786
Gregski
Post Whore
Gregski's Avatar
I also paintarized the crossmember
KRYLON changed the nozzle on this paint so I no longer recommend it
Old 04-14-2022, 10:04 AM   #787
Gregski
Post Whore
Gregski's Avatar
should look good from where you're sittin'
Old 04-15-2022, 09:45 AM   #788
Gregski
Post Whore
Gregski's Avatar
ladies and gentlemen I give you the self leveling Inver-A-Jack ... now available in rustic white
If you recall the Inverter changes Direct Current coming from the batteries to Alternating Current for the motor to function [think of it as a distributor/carburetor combo]
Old 04-15-2022, 09:46 AM   #789
Gregski
Post Whore
Gregski's Avatar
naturally the exhaust nipple and the firewall bulge won't allow us to set it on center
Old 04-15-2022, 09:47 AM   #790
Gregski
Post Whore
Gregski's Avatar
Me: for this project I will only use the strongest and lightest of metals, preferably unobtanium or at the very least aluminum
also Me: let's just check the scrap pile first
Old 04-15-2022, 09:48 AM   #791
Gregski
Post Whore
Gregski's Avatar
so some ideas taking shape
I call it the Tee Pee design
Old 04-15-2022, 09:49 AM   #792
Gregski
Post Whore
Gregski's Avatar
just checking the Stick Outability
Old 04-15-2022, 09:51 AM   #793
Gregski
Post Whore
Gregski's Avatar
if you tilt your head just right, it's perfectly level
Old 04-15-2022, 09:51 AM   #794
Gregski
Post Whore
Gregski's Avatar
side bracketry
Old 04-15-2022, 09:55 AM   #795
Gregski
Post Whore
Gregski's Avatar
and I guess this is a good place to stop for the night
Old 04-15-2022, 09:56 AM   #796
Gregski
Post Whore
Gregski's Avatar
so this is how far we got (me and the mouse in my pocket)
Old 04-16-2022, 11:19 AM   #797
Gregski
Post Whore
Gregski's Avatar
I don't usually stop to check if the cables will reach the component I am trying to install, but when I do, I make sure it is when I am half way through making the bracket...
Old 04-16-2022, 11:20 AM   #798
Gregski
Post Whore
Gregski's Avatar
I am really not a fan of this run both cables to one side design (ie East), plus one of my cables has a booboo owie so I decided to unwrap it in hopes of heeling it and seeing if it can be rerouted Westward
Old 04-16-2022, 12:26 PM   #799
Gregski
Post Whore
Gregski's Avatar
then it was time to Xerox the driver side on to the passenger side
Old 04-16-2022, 12:28 PM   #800
Gregski
Post Whore
Gregski's Avatar
looks pretty polywhompus out in the wild doesn't it?
