10-11-2013, 10:22 PM | #8126 |
Re: What did you do to your truck today!
Wired up my electric choke and dialed in my carb.
71 swb 350/4sp manual 5/7 static drop |
10-11-2013, 10:34 PM | #8127 |
RAT1968 '68 Cab/'71 Parts
Finally got the cover fiasco (sizing issues) cleared up with carscover.com.
Nice folks. And they stood tall. So, if you need an outdoor/fleece lined cover and can't get it from a Forum Vendor, the "Ultrashield" (100% rainproof - claimed...jury's out until it pours) you want for a short bed is Product Code 101VLH4AM, regardless of what their make/model matrix wants you to order. I put it on today. It was bucks-up for me at about $175 shipped. Less than the $500 custom-fit Calcarcover I have had before. But still big dough for me. Fit great (no mirror pockets - I use oven gloves over the leading edges of the mirrors) Belt-Strap under the center. Elastic front and back. Looks high quality. Anyone wants a pic or two, speak up. First and foremost, I go with the supporting Forum Vendors. But I didn't get any response as to rainproof/outdoor guarantees, so I went with that one from www.carscover.com
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 10-11-2013 at 10:42 PM. |
10-11-2013, 10:52 PM | #8128 |
I got the truck up on Jack Stands, pulled the front tires, and orders all my front brake parts. The parts will be in by noon tomorrow so as weather is begining to come in on us, I plan on doing a front brake job. Going to replace everything from rubber hoses out to the drums. I am not replacing drums as they are still in good shape. Looking forward tomorrow.
10-11-2013, 10:55 PM | #8129 |
I cut out Rot in preperation to install new Apillar.
10-11-2013, 11:09 PM | #8130 |
Fixed a Gauge issue, installed the chrome pulleys that showed up, and stared at the truck.
'70/C10/402/TH400. |
10-12-2013, 01:02 AM | #8131 |
I was deciding on whether or not to add a console to my truck and googling pictures thats had custom console but this weekend will be finishing up welding my rocker panels in and patching in some holes that I am filling in.
10-12-2013, 08:22 AM | #8132 |
Oh yea I'm keeping it.. I love it. May even put a 22" steelie on it also.
10-12-2013, 08:46 AM | #8133 |
Starting disassembly mode. The build is officially beginning.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
10-12-2013, 10:20 AM | #8134 |
A little pricey. Beautiful truck. Thanks for the measurements...
10-12-2013, 04:11 PM | #8135 |
replaced the ball joints and control arm shafts today. still need to do the idler and pitman arms. I also replaced the wore out front springs with a pair from a 90 suburban, I cut one coil from them.
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
10-12-2013, 08:48 PM | #8136 |
Got the A pillar test fit today. hope to tack weld it Sunday.
10-12-2013, 09:07 PM | #8137 |
Have A Nice Day!
We cut in the new fuel filler and filled the tank. Worked perfectly
1970 CST K10 350/350/205
Short Bed - Fleetside Tach-Tilt-A/C-Tow Hooks Front & Rear Disc Brakes Front & Rear Posi 3.73 Gears 30 Gallon Stainless Fuel Tank SOLD 01/18 !!!!! 2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ |
10-12-2013, 11:56 PM | #8138 |
Front brake kits finished
My build thread for Project TiC TaC/Jazzmin Oh Yeahhh Cheap work is never good and good work is never cheap. Lesson = learn to do it all the right way on your own. SqueegeeMan |
10-13-2013, 01:05 AM | #8139 |
She has bags but with that nice frontend and beautiful rack she is a beauty, sound weird or what Very nice setup, should perform really good too.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
10-13-2013, 07:45 AM | #8140 |
Almost done!
Washed the girl so I can drive her to church! We both will be better for it.
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
10-13-2013, 08:52 AM | #8141 |
Nice work!
Brad handshoe |
10-13-2013, 08:56 AM | #8142 |
Correcting rear end, PO had a car rearend, cut springs, blah blah, mocked up my ten inch wide rally and removing rivets to correct shock mounting brackets annndddd shaving the firewall holes where the blower fan Was....
10-13-2013, 02:21 PM | #8143 |
Finally got the opportunity to take the truck to her first show last night and Ended up taking taking best of show! There were so many crowded around the engine bay all night it was a real treat to hear the responses when they realized that I hadn't just dropped a small block under the hood!
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
10-13-2013, 03:04 PM | #8144 |
Lol very good observation
10-13-2013, 03:29 PM | #8145 |
Removed my 3speed trans to replace it with one that works .
10-13-2013, 10:51 PM | #8146 |
Fitted sheetmetal all weekend. Wrestled the hood all afternoon mostly due to a mix of OEM and aftermarket parts.
10-13-2013, 11:06 PM | #8147 |
I finally started my winter project. Cut out the cab corner, outer rocker panel, the lower door pillar and the cab kick panel area. Just have to get a couple more patch panel and it will be going back together. Then start the left side. It turned out to be about a six beer job so far.
10-14-2013, 09:25 AM | #8148 |
Good deal Ridgeclimber, Do us all novices a favor and document how your doing this with pics if possible. I'm sure we can all learn from your experience. I will be doing this soon on mine....
Thanks legotech7..... |
10-14-2013, 10:23 AM | #8149 |
Yeah! What he said! I'm getting ready to put rockers and a cab corner in too.
10-14-2013, 02:04 PM | #8150 |
Please post pics on cab corner and rocker repair.
