#801 |
VA72C10
![]() Join Date: Mar 2008
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
I'm sure that made your wife and neighbors happy to get rid of that
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#802 |
VA72C10
Exhaust turned out great so far!
#803 |
Wow! I just went through this thread last night. What an undertaking! I've thought about attempting this myself with my 69 LWB. I could probably do the work but finding the time and money is my problem. I thought about just swapping my body over to a later model chassis, but I just don't know if I could dedicate myself to the extent you have. I have to say, for someone who doesn't do this for a living, you have a lot of skill. Maybe you should consider a new line of work. I am definitely impressed and I will be keeping up with your project. Thanks for posting all this info. Maybe it will inspire me.
#804 |
67cheby
![]() Join Date: Sep 2008
i love how everything is tucked in nice between the frame rails ...looks great
#805 |
That Denali was a boat load!
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#806 |
Lucky Teter at the wheel
Thanks, I have it easy though because the newer frame rails are wider so there is more room in between.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#807 |
I have to say, you have quite a project going. I log on everyday just to see what else you've done. Very impressed with your work. It looks factory built.
#808 |
My boat trailer never had it so easy.
#809 |
Sofa King Crazy!!
This is really a huge, costly undertaking......and you make it look so clean and sanitary?!?!? I love this project and will be around adding views to your thread till it's done.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#810 |
I just read your entire thread. Awesome! I love reading everything I can on those doing 67-72 crew cab conversions. It is simply amazing! Great job!
I also love the use of a newer drivetrain. I often thought how cool it would be to drop a crew cab conversion onto a newer crew cab too. Nice! God's Speed! Last edited by thor; 03-14-2011 at 02:56 PM. |
#811 |
Drew,
Just read your entire thread as well. VERY NICE!!! Let me know if you need any help with anything. Be glad to. Glad those cabs were able to be used for something.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
#812 |
Picture Time
I made some progress on the firewall and welded in the giant grommet hole. I mounted the dummy air handler for the last time and it all works out, so I have them side by side to make the final modifications to the real air handler I am using.
#813 |
Restoration Virgin!
Gee whiz....I'm glad I caught this one to watch before you are done!!!...Great work here Drew....I appreciate what you and your family do for missionaries and believe it or not, I use to eat those Charles' Chips growing up...loved them....
Keep up the great work....I look forward to seeing you finish this one ![]()
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#814 |
It was such a pretty day that the Lord had made, we worked outside. While I painted the exhaust with Eastwood products, I had the boys sanding down the bed with 120 grit.
#815 |
VA72C10
Looks good. You'll have to let us know how that paint holds up.
Did you have to do anything special to prep it?
#816 |
I had to order the Eastwood version of Dynamat to insulate the firewall before I do the final install on the Air unit. It is less than half the price of most others. Something I had to do to fit the unit under the dash was move the wiper motor over about 3 inches. I'll fabricate a new arm linkage later. Prepping the firewall with Bondo since I am finished drilling holes and welding up others.
#817 |
wow the bed and cab look nice and clean! great job drew looks good the exhaust looks good to i wonder how long it will stay nice sliver
#818 |
And now for the moment of truth, will she fit????? YES!!!
Tons of clearance for the trans. and fuel lines with the high hump. Engine has at least an inch on the passenger side, way more on the drivers. Not even close to the firewall. All of the body mounts lined up and frame barely shows under the truck. Sarah had me put the seat in so she could check it out.
#819 |
More pics of the non-event...
I'll pull the cab back off again of course for paint, but I have to have it in place to set up the steering and brake booster mount.
#820 |
Starting to look a little more normal.
A shot of the fresh air intake from the inside.
#821 |
VA72C10
Awesome! Great job!!!
#822 |
chevy only
![]() Join Date: Sep 2006
wow!!! great job concrats
CHEVY ONLY... Nothin Else ! |
#823 |
Local Redneck Authority
COOL COOL COOL! You are an amazing artist for sure! Keep up the good work in and out of the shop!
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
#824 |
Its as if the factory made it! It looks like it fit perfectly.
#825 | |
The metal was so rough already, I just washed it/scrubbed by hand and shot the paint.
