09-30-2017, 07:59 PM | #801 |
Re: How about some pics of Static dropped 60-66
Front:
15x7 smoothie wheels 225/75/15 3 inch drop springs 2.5 inch drop spindles Rear: 15x7 smoothie wheels 225/75/15 4 inch drop springs I am not sure how I feel with the rake...might have to use 2 inch drop blocks in the rear.
1965 Chevy C-10 350 V8 2003 GMC Sierra Crew Cab 6.0L 4x4 |
10-01-2017, 01:47 AM | #802 |
Front: 3" springs and 2" spindles
Rear: 5" springs, 2" blocks, C-notch Chrome Wheels: 15 x 6 front/back, 215/75, 235/75 White Steelies: 15 x 7 front/back, 235/60, 255/70 Last edited by mfm3; 07-25-2022 at 11:14 PM. |
10-01-2017, 09:16 AM | #803 |
Rollin' Old Skool
Looks great!....what color is the truck, a cream or pale yellow? Thanks
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
10-02-2017, 01:44 AM | #804 |
Cool Vanilla...a Chrysler color
10-02-2017, 08:38 AM | #805 |
Rollin' Old Skool
01-27-2018, 09:47 PM | #806 |
Front: 2.5" drop spindles and 1" drop spring
Rear: 3" drop spring. Had a 2" drop block in there at first but it was too low. |
01-27-2018, 11:09 PM | #807 |
Your setup is similar to mine, I’m going to be running 3” rear drop springs and 2.5” drop spindles with stock springs.
02-08-2018, 11:48 PM | #808 |
Just put the new wheels on today (posted under Tire/Wheel pics as well). 1963 C10, dropped 6" in the rear with ECE springs, lowering shocks, and relocation kit. Stock rear bump stops were cut about 3/4".
Front is dropped 4.25" by using 2" drop ECE springs and cutting one coil off. I replaced the bump stops in front with Energy suspension parts. I used longer bump stops up top (Energy suspension part 9.9143R) so when the car is jacked up the springs do not come loose. The lower bump stops (Energy Suspension 9.9101R) are cut to give adequate clearance. This allowed me to leave the drum brakes in place. Tires are 275/55-17 on 17" x 9" wheels. Last edited by Cris; 02-08-2018 at 11:55 PM. |
09-05-2018, 01:34 PM | #809 |
Hi, here's my '63 longbed :
Cut coils in the front, i dont know how much. 1"3/4 lowering blocks on the rear. Front tires are 235/60R15 and rear 255/60/15. I would like a little more lower but stance not so bad like that. what do you thing about it ? |
09-06-2018, 11:52 AM | #810 |
I have a 1962 C10 Panel and I have Q about static drop beacuse all of you know that I have torsion suspension in my front so I wonder howe much can I drop my frontend before it got crazy handling, can I drop 2"?
09-06-2018, 12:42 PM | #811 |
I had 62 which I dropped 2 inches using the torsion bars and everything still worked fine. You will need to get your alignment done though.
09-06-2018, 02:13 PM | #812 | |
But Found Her 25yrs Later!
And please don't take this as criticism, it's just something I started noticing lately. And I think it's caused by adding discs in the front which moves the front wheels out. When I go to discs, I'll be using wider wheels in the back, so it may not be noticeable.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
11-12-2018, 04:08 PM | #813 |
11-12-2018, 05:59 PM | #814 |
The front was 2.5" spindles with 2" springs and the rear was 3" springs and 2" blocks.
65 short step edited by staff |
11-13-2018, 10:11 PM | #815 |
hillbilly
What size tires are you running?
-1962 C-10 |
11-14-2018, 12:53 PM | #816 |
Here is mine.
11-20-2018, 11:46 AM | #817 |
5 and 7 with a rear flip and a front dropped spindles. c notched and shock relocated on the rear. shorter shocks on the front with internal bump stops
01-08-2019, 03:08 PM | #818 |
Well here she is. 64 swb. First time getting to see and play with one. POL 3/5 drop springs. Will get another 2.5/2 once we do the disc conversion. 292/4spd 3.73 posi. Also as you can see in the last pic. The rear wheels are pushed back pretty far in the wheel well. Is this common when dropping the trucks? And what’s the fix? Shorter drive shaft? Thanks
01-08-2019, 04:12 PM | #819 | |
The 60-66 GMC/Pontiac guy....
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
01-08-2019, 09:50 PM | #820 |
I’ve been told that it’s just the driveline that needs shortening. I know the front ones are not centered from the factory that’s why most ppl will buy aftermarket to move them forward. I’ll do some more searching.
01-08-2019, 10:14 PM | #821 |
It's very common for the sb stepsides to have the wheels toward the rear of the fender opening. It is also common that the sb fleetsides had the wheels towards the front of the wheel opening. I don't know why, they just do.
You could probably move your bed back slightly but not enough to center it.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
01-08-2019, 10:19 PM | #822 |
Shorter drive shaft will not move the diff.. research is advised..
01-12-2019, 04:48 PM | #823 | |
03-31-2020, 06:25 PM | #824 |
what rims? seen you went to discs. any issue with caliper clearance?
06-26-2022, 08:54 PM | #825 |
