#801 | |
Re: Dutch '59 Fleetside Longbed
One thing I have learned is that your garage / workshop can never be too big. We have a 4 car garage and now it is too small for me. We are now looking at some land so I can have a bigger play space. ![]() I like your progress. Keep it up.
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
#802 |
Just like this Kees.... form a little box in the center and weld it into place.... cut your receiver hole and put the license plate holder over it.... flips down for the tow hitch!
My Build: 57 Chevy Pro-Street |
#803 | |
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#804 |
Today I cut a hole in my freshly build roll pan...
For a reason ofcourse ![]() Made a recessed plate holder and drilled holes for the licenseplate lights All welded and ground, no filler needed ![]() Now wait for the hinges to come, then cut a new hole for the hitch and make a bracket for the electrical plug. Next thing while waiting is making the coolant pipes and petrol filler door in the bed side. The list is getting shorter ![]() ![]() ![]()
#805 |
Came out real nice.
Kim |
#806 |
![]() Join Date: Jul 2012
Nice metal work Kees! You are making great progress.
#807 |
Yes sir...looking good!!
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#808 |
![]() Join Date: Mar 2011
Moving right along...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#809 |
Nice job so far.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#810 |
Thank you very much, Gentlemen!!
Did a bit of metalwork the last few days. First the coolant pipes, these are the rough ones, its stainless steel: The filler pipe for petrol, also stainless steel: Next was bedtime ![]() The fillerdoor for petrol and propane comes in the rightside of the bed: Well, no way back now ![]() ![]() At the scrapyard I had a fillerdoor from a Volkswagen Golf III (Rabbit), but that wasn't going to work. It's too small and too round at the edges. I think I only can use the spring hinge from it. So, I must make my own steel bucket ![]() No problem! Then the least fine job, making the holes... Test fitting... Tackweld in and look if it reaches my standards ![]() ![]() I think so. On to weld it in... Halfway through.... Fully welded: Next time on to the door itself. I'm getting there ![]()
#811 |
Looking good metal man!!!!
![]() With that huge license plate box you could have fit the gas filler, the propane filler, a hitch assembly and maybe a couple other hidden things behind there!!!! ![]() I forgot how big the european plates were!!!
#812 |
Yeah, really nice work on the box build and install!
#813 |
Thanks PTC!
Yes we have huge license plates ![]() At the inspection I asked for US style plates, they call it 18.2 plates. They wouldn't give it to me because I have already got a tow rate on my papers.....And they don't give it to commercial vehicles ![]() ![]() You ought to know how many American "commercial vehicles" have those 18.2 plates...countless... But what the h*ll, I've got my registration, and if you drive 80 mph, you won't see the plates ![]() ![]()
#814 |
Thanks Doug!!!
I'll do my best!
#815 |
Man, you're really moving along. Love the roll panel. I may have to do something similar. dug
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
#816 |
Coming along real nicely.
Kim |
#817 |
Kim, Dug, Thanks again!!
Managed to get the fillerdoor itself in. It was a bit of a struggle to get it right, because the dimensions of the donorcar are, ofcourse, different as what I use ![]() But it's in, only have to tweak it a little to get it perfect. This is a part of the Volkswagen fillerdoor, only did use the spring loaded hinge: I made the door out of 2 mm (14 gauge) steel, bent it a little to match the side of the bed The door is welded to the hinge, the hinge is bolted to the box. I also welded in an angle iron with a rubber door stop. Looks like a professional build ![]() ![]() ![]() Next I welded all the holes shut, that the PO had made to screw his tonneau cover on.... It were only 83 holes.... The holes were everywhere ![]()
#818 |
Came out real nice.
Kim |
#819 |
Wow filler door looks real nice. Factory like.
#820 |
Have been busy with paint....
Before: After: Also cleaned the rough waterpipes a bit, painted them black en put them in: Tomorrow is sanding bed again, and when time and body allows, paint again ![]()
#821 | |
![]() btw wy not both coolant hoses in full rubber ? the lower one with a 90 degree piece and the upper with an straight hose with a loose steel spriral so you can bend it without collapsing Sander, |
#822 |
Nice looks upgrade with the paint Kees!
#823 |
Water pipes look clean. Nice job. dug
#824 | |
![]() Btw, almost roadworthy.... You know I've got a million things to do.....you know that ![]() ![]()
#825 |
Thanks Dug!
I thought the same ![]() ![]()
