Old 02-24-2015, 11:48 PM   #801
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Muncie SM465
cleaned the tin transmission side covers in preparation for paint
Gregski is offline   Reply With Quote
Old 02-24-2015, 11:55 PM   #802
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Muncie SM465 Gasket Set
then after 3 long days the Muncie SM465 Fel-Pro Gasket Set arrived
that's right my Township Autozone had to special order these gaskets, what special order for a dime a dozen Cheby 350?
so I go to pick 'em up today, and the box is torn in half (as shown) I say to the young lady I hope everything's in there, she assures me it is [aha]
well sure as heck the constructions (as my three year old would call his Lego's instructions) be missin', one of the reasons I get Fel-Pro gaskets is for their 3x5 card instructions, and here they are missing
also see how they packaged that large gasket, why would they do that, why not get a bigger box? [they need to hire Summit shipping guys]
Old 02-25-2015, 12:54 AM   #803
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
Smh...
Chaplain is offline   Reply With Quote
Old 02-25-2015, 01:22 AM   #804
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I'll be honest wichya all I've spent the evening wrasslin with that pig and I just can't get the lid back on her for the life of me
now something told me don't glue / goop the new gasket on there just yet, first try to just put the lid back on, and sure enuff I can't
I am trying to find some video on YouTube right now to figure it out, I know to take it off I had to put the joystick half way in reverse, but guess what I can not shift at all right now with the lid off the tranny
any advice / tips greatly appreciated
Old 02-25-2015, 01:45 AM   #805
rich weyand
rich weyand's Avatar
Re: Restoring Rusty
http://67-72chevytrucks.com/vboard/s...d.php?t=427819
http://forum.ih8mud.com/threads/sm46...nstall.261929/
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 02-25-2015, 03:04 AM   #806
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Thank you so much Rich that did it, to be honest with you the first time I got her sealed I must have missed the darn idler gear cause she would only turn in Neutral, I stuck my finger in her and could slide the idler with my hand, not good
so I took a deep breath and removed the cover and tried again with no gasket this time and she shifted and turned in all gears
so I did a third take (with gasket this time fer good) and got her in - the key is lining up those three large slider bars in the lid like in the pic below, see how the one is longer than the other two, it is not all the way out, nor is it in neutral it is in between, the other two sisters are just snapped in to neutral (very technical explanation I know)
and here's a top tip, after you get the lid back on, the transmission is still stuck half way in Reverse so you may not be able to get her to shift
I took a large screw driver and snapped her all the way in Neutral or reverse I forget which and then I could stick the shifter back in and shift
Old 02-25-2015, 12:07 PM   #807
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I am fixin on re assemblin' the bell housing and the clutch fork and throwout bearing, question is will I be using the Lubriplate lithium grease on the metal ball joint that the metal clutch fork pivots on inside the bellhousing, or is there some other grease I should consider?
Old 02-25-2015, 12:11 PM   #808
bnoon
Re: Restoring Rusty
I've always used a dab of heavy axle grease.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 02-25-2015, 12:29 PM   #809
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Might could this work, my daddy bought it 30 years ago
Castrol Multi Purpose Wheel Bearing Grease NLGI No. 2
(now I aint no mathematician but if that aint no oximoron I don't know what is, how can something be multi purpose / wheel bearing grease, that's like saying any flavor / black cherry, LOL)
Old 02-25-2015, 12:39 PM   #810
Titomars
Titomars's Avatar
Re: Restoring Rusty
"One size fits all"
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 02-25-2015, 01:22 PM   #811
rich weyand
Re: Restoring Rusty
Use the white lithium grease. Axle grease is for load-bearing situations such as axle bearings and U-joints and the swivel plates underneath the tires on an alignment rack. It holds up under those loads better than white lithium grease, BUT it has a higher drag to motion than white lithium grease for low-load applications. That is, it is less slippery for low-load applications. Anything other than axle bearings and U-joints on a vehicle, you are better off with white lithium grease.
For high-load applications, TRC 880 Crown & Chassis Grease is number 1. (IMO, OC!)
Rich Weyand
1978 K10 RCSB DD.
Old 02-25-2015, 01:28 PM   #812
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
once again, thank you so much Rich that totally helps, really good explanation, and by now it aint no secret I am the worlds' worst chemist
Old 02-25-2015, 04:19 PM   #813
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so it was time to button up the transmission I used the Permatex Spray-A-Gasket Sealant to get the gaskets tacky
Old 02-25-2015, 04:21 PM   #814
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
cleaned the siamese twins, Phil and D'rain
Old 02-25-2015, 04:28 PM   #815
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and then it was time to paint the transission
Finally, thought this day would never come (I know you and me both)
Wait you gonna paint it white?
No, that paint needs a mixin' though it does look old like it's left over from when they painted the Titanic.
There, that's better... G R A Y
Old 02-25-2015, 04:33 PM   #816
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and here is our subject (I did tape off the electric switches for backup lights and that SMOG thing)
Old 02-25-2015, 04:34 PM   #817
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
wait what? You painted it WHITE?
wait a minute, that's not the color I wanted?
It was supposed to be gray, I was picturing cast iron. I know POR15 has a SILVER, but I purposely bought GRAY. LOL
Old 02-25-2015, 05:18 PM   #818
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Eastwood Metal Blackening Solution
and what do we have here?
seriously, that's all that was in the box?
Yup, Eastwood's Metal Blackening Solution $14 bucks plus another $5 for shipping, not bad
now back in the day, Eastwood had a two part Metal Blackening kit, it came with:
1. Blackening Solution
2. Sealant
you would dip the metal in the first plastic container than dip it in the second, job done!
then they realized they can make a whole lot more money by adding a bunch of stuff to the kit nobody needed, like safety goggles, rubber gloves, some crappy cleaning product, and by the way they replaced the sealant with clear lacquer in a rattle can
fine but does it work?
well in its full strength (hey I paid for it I will mix it or not mix it how I please, JK) in its full strength this is what it did in 1 minute of soaking
it turned a silver part darker silver, LOL, question is will this prevent rusting, and by the way I did spray it with my own clear in a rattle can
Old 02-25-2015, 05:46 PM   #819
greg64
greg64's Avatar
Re: Restoring Rusty
Hey Greg, that transmission looks a lot better painted, and now it won't become a rusty mess. On my 465, I used POR-15 black, which turned out fine. However, I subsequently bought their cast iron grey paint, and I've used that a few times with good results. Basically looks like the part is unpainted, except that it is.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 02-25-2015, 06:16 PM   #820
rusty76
rusty76's Avatar
Re: Restoring Rusty
I'm glad you are getting this thing back in order!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-25-2015, 06:28 PM   #821
canadian_diesel1964
Re: Restoring Rusty
man this is a sweet build!!
canadian_diesel1964 is offline   Reply With Quote
Old 02-25-2015, 07:38 PM   #822
LSX408
Re: Restoring Rusty
Loving this build! Awesome work!
1983 GMC SWB - 350, TH-400
2002 Camaro SS - 408 9sec street car
2000 Trans Am - H/C/I
2014 Chevy Z71
LSX408 is offline   Reply With Quote
Old 02-25-2015, 08:21 PM   #823
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
Say brotha Greg your inbox is full.
Old 02-25-2015, 08:41 PM   #824
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
friggen Groupies, JK
Old 02-25-2015, 08:43 PM   #825
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by greg64 View Post
... I subsequently bought their cast iron grey paint, and I've used that a few times with good results. Basically looks like the part is unpainted, except that it is.
is it the 15 oz spray can stuff? What they call Detail Paint? I didn't go for that cause I wanted their rust treatment product, but now I might.
