Old 11-16-2009, 07:15 PM   #826
bubba327
HOW long until spring??
bubba327's Avatar
Re: The 283 Rebuild Begins
http://67-72chevytrucks.com/vboard/s...d.php?t=324250
63-64 bowties had this link in january 09-- '63 turn signals
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 11-17-2009, 05:11 PM   #827
jason65
Registerd User
jason65's Avatar
Flashing break lights when they are not applied might be your boo switch being out of adjustment or busted. Please explain on t/s sticking on when brakes applied? Like hazzards or just one side? Just the back?
Trucks lookin good Mac.
jason65 is offline   Reply With Quote
Old 11-17-2009, 05:45 PM   #828
MacAttack
283 Drama Queen
MacAttack's Avatar
Thanks Jason, the rear stop/turn lights both flash, as soon as the ignition switch is turned on - even without engine not running. Put the brakes on - they stop flashing and you can't hear the "clicker" can going off under the dash.
Flashing lights only effect the back - not the front of the truck.
Driving, put a turn signal on, right or left and they operate fine, front and back - until you apply the brakes - then whichever side it's set to - the light sticks on and won't flash until you take your foot off the brake.
Understand - the tranny shop did the final hook-up on the wire loom (click in unit) coming down out of the steering column. Also understand I FAILED Basic Electrical shop in high school, TWICE! But the teacher was a real P*%#k.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 11-17-2009, 06:10 PM   #829
70 Suburban
Rods
Could be a few things... I know its been said. But start at your light grounds... They will feed back if they is not a good ground.
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 11-17-2009, 09:43 PM   #830
bubba327
bubba327's Avatar
http://www.americanstreetmasters.com/Wiring_101_16.jpg
this is a helpful site .. the colors stay consistent through the years. Do you have the hazard 4-way flasher?
Power starts at the fuse ,then to signal flasher then goes to the brake switch on the orange wire and leaves the brake switch on the white wire which goes to the connector and up the column to the turn signal switch. the 4 signal lights (front/rear turn /brake) all leave the turn signal switch on 4 different colored wires.
your flasher only flashes when it has a load to pass power to. It sounds to me like your turn signal switch or column wiring has been damaged. Or mis-connected
good luck-- Bubba
Old 11-18-2009, 12:43 PM   #831
MacAttack
283 Drama Queen
MacAttack's Avatar
Thanks Bubba - yes, the wiring was damaged and I bought a replacement unit that runs from the horn ring down to the first connector at the base of the steering column. Laid out next to the scraped one - they appeared identical. Something might be shorting out.
On the emergency flasher issue - my truck didn't come with them and I can hear the regular canister firing off, which makes both stop lights illuminate.
Mac.
Old 11-18-2009, 01:23 PM   #832
bubba327
bubba327's Avatar
Glad you found it. I put a newer Gm tilt column in my 64 and added the 4- way hazard lights. It only took a extra flasher and one wire using the newer turn signal switch which was in the column.
Old 11-25-2009, 01:23 PM   #833
MacAttack
283 Drama Queen
MacAttack's Avatar
Truck's Puking Oil.
Not bad - but on the brand new driveway - it's quite noticeable. A spot about 2 inches wide and 4 inches long. Noticed it when the kid put the truck in the garage yesterday. Haven't checked out the exact location, but its not tranny fluid or anything else and I'm taking it easy for the holiday - so I'll worry about it when I get the rig back from the electrical repair guy two Saturdays from now.
Typical.
More-than-likely the small I/D tubes I ran from the PCV valve from the original tube back by the distributor, up to the carburetor, aren't producing enough flow/suction to relieve the crank case fumes.
Based on the fact the spot is right in the center of where the truck was setting - it's probably a rear seal.
Oh joy.
Old 11-25-2009, 01:33 PM   #834
padresag
there was a change in the wiring to the lights in 65 or 66 in regards to the frt parking lights remaing on with the tail lights. prior years the park lights were not on with the taillight when running. perhaps when they fix your wiring there may have been some confusion.
just throwing that in for thought Mac
ron
padresag is offline   Reply With Quote
Old 11-25-2009, 01:34 PM   #835
MacAttack
283 Drama Queen
MacAttack's Avatar
Thanks Ron - every little bit helps.
Old 11-25-2009, 01:40 PM   #836
70 Suburban
Rods
Mine was a pan gasket on the front.. Hit the crossmemeber then made a spot right under the engine. I thought rear too.
Old 11-25-2009, 02:09 PM   #837
MacAttack
283 Drama Queen
MacAttack's Avatar
Hope so - maybe it was the rush job I did on the elcheapo gauge tubing off the fitting at the back of the block for the motor break-in. (Grasping at straws).
Old 11-30-2009, 11:29 AM   #838
MacAttack
283 Drama Queen
MacAttack's Avatar
Now it's not that I'm a Drama Queen or anything (yeah, right), but I think I found the source of the leak: Fitting off the back of the block that feeds the oil pressure gauge.
The last guys that worked on my rig - putting the gears in the differential, new drive-shafts, brakes etc - also did some wire clean-up in the engine compartment. They put one of those flexible plastic wire sheaths over the bundle on the driver's side, but didn't secure it properly.
I got a few minutes yesterday and fired the truck up to see if I could eyeball the source of the dripping and discovered, as I pulled the throttle rod back, this loom was riding up and down on the rod - pulling on the plastic oil line that was bundled in with the various wires.
Every time you'd step on the gas it would give this line a good yank. So I took a Velcro wire strap and tacked the whole mess to the firewall and re-tightened the tube's fitting. I'll go back and clean everything up, but there was a fair puddle of oil near this fitting at the top of the motor - near the distributor.
Oh the Humanity!
Dropped the truck off at the electrical repair guy's shop before work this morning - so we'll see if he can get my charging system working. A 64' Impala with a monster, late-model Corvette motor was there for a wiring restoration, so I may have found a decent vendor.
Mac.
Old 11-30-2009, 11:31 AM   #839
4dranch
Shloooooong bed member #2
4dranch's Avatar
Mac
Hope it solves your problem..
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 11-30-2009, 11:33 AM   #840
jason65
Registerd User
jason65's Avatar
Glad you found your leak Mac.
Old 11-30-2009, 11:52 AM   #841
daverod
SSN 706
daverod's Avatar
Mac found his leak.
daverod is offline   Reply With Quote
Old 11-30-2009, 12:05 PM   #842
shrunken66stroker
shrunken66stroker's Avatar
Originally Posted by daverod View Post
Mac found his leak.
He found his leak too. That's recycling at it's best.
shrunken66stroker is offline   Reply With Quote
Old 11-30-2009, 12:52 PM   #843
justcuz
justcuz's Avatar
This is why I am glad I have the ability (time and knowlege wise) of doing these projects myself.
I get so dissappointed when you pay someone good money to do a job. Then when you get it back you find problems. It got to the point that I just started doing everything myself.
So far I have tackled everything but rebuilding an automatic transmission and setting up a rear axle.
I was going to add radiator repair, but not even the radiator shops repair much anymore, just R and R.
justcuz is offline   Reply With Quote
Old 11-30-2009, 02:02 PM   #844
MacAttack
283 Drama Queen
MacAttack's Avatar
Originally Posted by 4dranch View Post
Mac
Thanks David – I’m just glad I didn’t have to change the smog plumbing.
Me too, Jason. Because of the leak’s position and me being such a gigantic mechanical whoosie, ready to throw myself down on the garage floor and cry, I was sure I had a D.O.A. rear seal. Guess I lucked out this time.
Mac found his leak.
OMG. You didn’t actually post that?!
It has been a while since we’ve had one that funny! Unbelievable.
Originally Posted by justcuz View Post
This is why I am glad I have the ability (time and knowledge wise) of doing these projects myself.
I get so disappointed when you pay someone good money to do a job. Then when you get it back you find problems. It got to the point that I just started doing everything myself.
Well, there it is.
And because I’ve got a back-up vehicle to get me to work, you’d think I’d just block out the time and learn to do everything myself.
The guy I dropped the truck off with is $98 an hour – with an hour minimum. In today’s economy – there are zero excuses not to at least try to do this stuff yourself and I’ll be looking at about four grand I didn’t really have to spend by the time this truck's finally done.
Impatience and listening to others (that clearly know little if anything about these vehicles) tell you how you should spend your dough is sometimes very silly.
$4,000 buys a Hell of a paint job.
Old 12-01-2009, 03:55 PM   #845
justcuz
justcuz's Avatar
Between Autozones online program, which costs nothing to register, and sevice and shop manuals you can pretty much diagnose and repair anything.
You can buy a ton of shop manuals one ebay for a couple hundred dollars.
These older trucks are pretty easy, wiring schematics are pretty simple and diagnosing stuff is simple since it is so easy to see everything.
The newer fuel injection stuff is what is causing me some heartburn now.
Old 12-01-2009, 03:58 PM   #846
MacAttack
283 Drama Queen
MacAttack's Avatar
Had no idea.
Old 12-03-2009, 04:26 PM   #847
MacAttack
283 Drama Queen
MacAttack's Avatar
Called the electrical repair guy a while ago - looks like I'm getting The Tan back tonight. Everything is supposedly corrected and a "tumbleweed of wires" and connectors pulled from under the dash. It's funny - out of the half-a-dozen old trucks I've ever owned, seems that "extra wire" has always been part of the purchase price.
Now obviously - I'm no electrician, but why do people do that?
(Now I can borrow my buddy's car trailer and haul my truck back to Alan's shop.)
Mac.
Old 12-03-2009, 05:00 PM   #848
4dranch
4dranch's Avatar
Congrats Mac.....
Hey swing by and grab my truck on your way to Alan's
David,
Daughters 66 truck:
Old 12-03-2009, 05:06 PM   #849
MacAttack
283 Drama Queen
MacAttack's Avatar
Will do, David.
Old 12-03-2009, 05:17 PM   #850
jason65
Registerd User
jason65's Avatar
Thats great Mac. So is it charging now?
Ok is on the way.
