Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 11-07-2018, 01:34 AM   #826
Captainfab
60-66 Nut
Re: Power Steering Adapter Plates
I really know nothing about those generator/power steering pump combos. I would think it would work as long as it is working properly. I'll send you a PM with ordering and payment info.
Old 11-10-2018, 12:39 PM   #827
Fleet '66
Active Member
Fleet '66's Avatar
Hi Capt. It's time for me to redo the PS update on my 66 C-10. The PO made a rather crude attempt at it and I need to clean it up a bit. He probably didn't know about your bracket. I believe that all I will need is just the plate and hardware but you might send me info on the tube and flange as well.
Thanks,
Bob...
Fleet '66
'66 C-10 SWB 350 w/3 spd OD 4:11's - driver/project...future T-5 trans upgrade
'64 C-10 LWB BBW near future project - "The Wife's Ride"
'58 "Apache"Stepside BBW w/'75 K-10 4x4 conversion 331 w/350TH and NP 205 transfer 3:73's - occasional driver/ show
Fleet '66 is offline   Reply With Quote
Old 11-10-2018, 11:59 PM   #828
Captainfab
60-66 Nut
I'll send you a PM.......
Thanks,
Bob...
Old 11-11-2018, 12:42 PM   #829
Fleet '66
Active Member
Fleet '66's Avatar
Received your PM and replied with request for further info. Thanks.
Fleet '66
Old 11-12-2018, 12:21 PM   #830
Fleet '66
Active Member
Fleet '66's Avatar
PM received and payment sent via paypal. Thank you John.
Fleet '66
Old 11-13-2018, 12:15 AM   #831
Captainfab
60-66 Nut
Payment received, thanks
Old 11-17-2018, 08:30 PM   #832
Fleet '66
Active Member
Fleet '66's Avatar
Received adapter plate in the mail today. Looks fantastic..as expected!! Thanks.
Fleet '66
Old 11-18-2018, 12:33 AM   #833
Captainfab
60-66 Nut
Thanks for the purchase and the compliment
Old 01-13-2019, 09:44 PM   #834
mehoff400
Does the steering shaft adapter need to be welded to the steering shaft?
dont have a welder so want to make sure i have everything needed.
66 c10 patina 250 T-5
My truck
mehoff400 is offline   Reply With Quote
Old 01-13-2019, 11:41 PM   #835
Captainfab
60-66 Nut
No, the tube and flange does not have to be welded to the steering column shaft. It would be perfectly acceptable to drill thru both the tube and the shaft inside of it and install either a 1/4" or 5/16" grade 8 bolt.
Old 03-06-2019, 12:06 AM   #836
66_c10
Does anyone have the pattern/template to install the power steering box in relation to the old holes? It would be nice to double check my work before I drill the holes. I would really appreciate it
66_c10 is offline   Reply With Quote
Old 03-06-2019, 12:52 AM   #837
Captainfab
60-66 Nut
My steering box adapter plate comes with a template to position the plate in the correct location.
Old 03-06-2019, 01:24 AM   #838
66_c10
I know your plate is very nice just don't have the money right now. I already made a plate that places the box away from the frame and has the bolt hole layout of the box, just need to get it in the right position and drill my holes.
Old 03-06-2019, 10:36 AM   #839
66_c10
If I were to use the adapter plate will I run into any issues not being able to fully turn to the right, will the tire hit the steering box? Will I have any issue adjusting the alignment?
Old 03-07-2019, 12:21 AM   #840
Captainfab
60-66 Nut
Regardless whether you use my adapter plate, one of the others on the market or the one you make, the turn to the right will be less than the turn to the left. It is just the nature of the installation. This is easily corrected during an alignment. No the right tire will not hit the steering box unless you have a very wide wheel with a deep backspacing. This power steering conversion has been done successfully thousands of times.
Old 03-21-2019, 02:53 PM   #841
demian5
demian5's Avatar
Any install pictures on a 60-62? I'm having a tough time with the CPP kit and haven't committed to installing it yet. I have the box and shaft end, but I could go either way on the bracket.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-21-2019, 03:01 PM   #842
66_c10
Ok, thanks. I am going with my homemade bracket, just have to figure out where to position it and drill the holes so the pit-man arm is in the right place, its not the space shuttle right?
Old 03-22-2019, 12:01 AM   #843
Captainfab
60-66 Nut
I do have some installed pics of the '60-'62 kit that I make. My products are not just a copy of someone else's product. My steering box adapter plates are a bit different than every other one on the market. So the pics of mine installed will likely not work with another brand of steering box adapter plate.
Old 04-03-2019, 03:27 PM   #844
Budman56
Budman56's Avatar
Payment sent for 63-66 powder steering bracket not powder coated. Thank you again.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 04-03-2019, 11:02 PM   #845
Captainfab
60-66 Nut
Payment received.
Old 04-27-2019, 03:01 PM   #846
Vero67
I sent you a paypal payment for a 67 K10 adapter plate. Thank you John
Vero67 is offline   Reply With Quote
Old 04-27-2019, 11:40 PM   #847
Captainfab
60-66 Nut
I received a couple blank PM's and an email from you? I assume that the payment I received from someone for a steering box adapter plate for a '67 K10 was you. There was no info with the payment to connect the person's real name to your user name here.
Old 04-28-2019, 07:00 AM   #848
Vero67
Yes it was me, not sure why the pm's were empty.
Old 04-28-2019, 10:28 PM   #849
Vero67
I looked at the pm's. My replies are at the top of the PM. Do you need any more information?
Old 04-28-2019, 11:25 PM   #850
Captainfab
60-66 Nut
I went back and looked. Your replies are hidden in the midst of my PM's to you. I do not have time to reread all of every PM I receive to determine what is old and what is a new message.
I will weld up a steering box adapter plate and ship it to the address on PayPal.
