Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 02-07-2022, 04:00 PM   #826
kev2809
low n' slo
kev2809's Avatar
Re: Project 67 DRGNWGN - 67 Burban!!
thanks for the pictures. I measured from that middle chunk where the hood closes (on the hood) and from there up to the skin and akin braces there is about 3" in most areas. my brackets are about 2 3/4 tall. so I'm going to be cutting it close! guess we'll see when I get the fenders ok and the hood back on
did you ever measure from the core support to the top of brackets with the spacers? wondering if they were close to what mine are..
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 02-07-2022, 04:32 PM   #827
3757chevy
3757chevy's Avatar
My spacer was 2 1/4 " is all. My radiator cap was the first thing to hit.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 02-07-2022, 04:44 PM   #828
kev2809
low n' slo
kev2809's Avatar
ouch I'm probably going to run into some issues then. from the core support to the top of the radiator is about 1.5" so I'm thinking if I do run into interference, I will have to make some new top brackets. these are kinda bulky anyways. I'm sure I can get back about an inch if I reshape them.
-_--_--_ _________
Old 02-07-2022, 07:06 PM   #829
pwdcougar
pwdcougar's Avatar
Originally Posted by 3757chevy View Post
A big block radiator is a little wider and thicker but No taller than small block or six cylinder radiator. It looks like you may have a square body radiator, I have used that size before with 69-72 style hood without clearance problems. but it wont clear 67-68 hoods. The top picture shows my spacers I used to make mine fit standing upright but the '67 hood would not close . In the second picture you can see I had plenty of room to tip the radiator back and mount at an angle allowing to shut the hood. I hope that helps.
Tilting the radiator is a great idea!
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 02-08-2022, 10:04 AM   #830
kev2809
low n' slo
kev2809's Avatar
well, I re thought this out and will be returning the big block radiator. last thing I wanna do is to cut into the hood.
ordered a cu369 which is listed for our trucks so hopefully it fits...including the an fittings I ordered for the trans lines. well see when it comes in
-_--_--_ _________
Old 02-08-2022, 02:08 PM   #831
3757chevy
3757chevy's Avatar
That was my best option even though I could not use my shroud anymore I had no cooling issues.
Sorry to create more work ,but I could see you may run into the same problem I had.
MIKE
Old 02-08-2022, 02:13 PM   #832
kev2809
low n' slo
kev2809's Avatar
nope..I absolutely appreciate it. I really hate doing things twice but hey, at least you saved me some problems down the road!
-_--_--_ _________
Old 02-08-2022, 02:21 PM   #833
3757chevy
3757chevy's Avatar
Glad I could help.
MIKE
Old 02-14-2022, 07:41 PM   #834
kev2809
low n' slo
kev2809's Avatar
this new radiator fit like a glove with the 4 core hold downs. just need an adapter for the bottom hose and its good to go...well, and also raise my fan shroud some too. it even comes painted black!
-_--_--_ _________
Old 02-14-2022, 09:41 PM   #835
LockDoc
The Older Generation
LockDoc's Avatar
Good deal! Things are coming together.
LockDoc
Leon
Old 02-15-2022, 01:38 AM   #836
3757chevy
3757chevy's Avatar
Thumbs up Re: Project 67 DRGNWGN - 67 Burban!!
Very Nice .
MIKE
Old 02-28-2022, 08:59 PM   #837
kev2809
low n' slo
kev2809's Avatar
shifted my attention back to the rear for now...trying to get some square tubing ordered for when i get the rear gas tank and floor together... and some sheet metal to get to mounting the front fender wells to the fenders.
so for now i just got the anti squat brackets in...i was seriously dreading this and putting it off. after trying to do with it a grinder and hand punch....i ordered an air hammer and it made it a breeze. chiseled the heads off and used the punch attatchment to drive it right out.
-_--_--_ _________
Old 02-28-2022, 09:02 PM   #838
kev2809
low n' slo
kev2809's Avatar
also got hitched and went on a cruise with the kiddos.....found this nice truck at the venue so i had to take a pic with it.
getting into more independent contracts with my dump truck business so working on the truck might come a little slower than it has been until that picks up
-_--_--_ _________
Old 02-28-2022, 09:42 PM   #839
LockDoc
LockDoc's Avatar
Hey, Congratulations!
Like me, you will just have to work on it when you can. A little here, a little there and you will be surprised how quick little projects get done.
LockDoc
Leon
Old 02-28-2022, 10:45 PM   #840
pwdcougar
pwdcougar's Avatar
Congrats!
Old 03-01-2022, 02:22 AM   #841
BAD1916
Congrats brother! Beautiful picture.
BAD1916 is offline   Reply With Quote
Old 03-03-2022, 02:44 PM   #842
kev2809
low n' slo
kev2809's Avatar
thanks yall!
doing little things for now...finally got the an -6 house and fittings on for the trans to radiator. think i will work on getting the fuel lines ran right now until i get the rear frame and axle cleaned up and painted. needing some help on getting the right fittings together.
-_--_--_ _________
Old 03-03-2022, 02:45 PM   #843
kev2809
low n' slo
kev2809's Avatar
so i have the 2 fuel rail fittings on the motor (return style). i will be running the stock filter. from my research the stock filter has 16mmx1.5 threads (correct me if im wrong). if im right i have the fittings in the cart ready to order. im guessing the hose route goes like this - big line on the fuel rail is the feed line, that goes to the filter on the frame, then to the big feed line on the sending unit. smaller line on the rail is the return, which runs all the way to the small line on the sending unit. my issue is this, i have no idea what size an -6 adapters i need for the sending unit. im attatching some and a part number to help...
-_--_--_ _________
Old 03-03-2022, 02:47 PM   #844
kev2809
low n' slo
kev2809's Avatar
this is the sending unit.. Dorman 692-056 which is listed for an 88 chevy truck (suburban). the big line on the left looks like it runs to the fuel tube that has the fuel cap. 2nd line (big line) is the feed line that runs to the fuel filter, then to big line on the fuel rail. 3rd line is the return line, small fuel line on the rail runs to this. 4th line on the end is just a vent hose?
-_--_--_ _________
Old 03-03-2022, 05:18 PM   #845
LockDoc
LockDoc's Avatar
I can't help on that. I have never used that style of unit. You may have to post the question over on the LSx Swaps forum....
LockDoc
Leon
Old 03-03-2022, 05:32 PM   #846
kev2809
low n' slo
kev2809's Avatar
ya i think your right. i just didnt want to keep posting dumb questions over there lol.
-_--_--_ _________
Old 03-03-2022, 07:12 PM   #847
HO455
Post Whore
HO455's Avatar
I believe that the last vent line should go to the fuel evap system in the OE application and through the charcoal canister it would vent the tank. This would be in a system with an unvented gas cap.
The large vent is used to vent the tank during fill up.
You may want to look at some later model Burbans and investigate how they vent their fuel tanks. Maybe you will be able to incorporate some of those components in your truck and enjoy the benefits of a unvented fuel cap.
Keep up the good work.
RIP Bob Parks.
Old 03-16-2022, 03:48 PM   #848
kev2809
low n' slo
kev2809's Avatar
got a little progress over the last week. got all my fuel fittings in and will be hopefully getting the fuel lines run this week if i get a chance. got the tank in and also cleaned up the frame and rear end. also ordered mostly everything to get the rear back in.... new bags, panhard bar, weld in shock mounts, and bag spacers. plan is to re weld the top mounts instead of cutting and lowering them. hopefully the bag spacer will work and give me some of my lift i was missing.
-_--_--_ _________
Old 03-16-2022, 06:30 PM   #849
BAD1916
Looking good. Hopefully those spacers work out for you.
Old 03-17-2022, 11:26 AM   #850
kev2809
low n' slo
kev2809's Avatar
quick question, putting my drums back on after cleaning up and painting. i noticed my drums dont have the window for the adjuster, its just solid piece. do i have the wrong drums or am i missing something? i rebuilt everything about 8 years ago but they have zero miles....and i didnt notice then.
-_--_--_ _________
