Old 08-04-2012, 11:50 PM   #826
mcbassin
Still Learning
mcbassin's Avatar
Re: LS1 into a 73 cheyenne
Thanks for the Detailed explanation. I know it will take me a bunch of time when I get to that point. Keep up all the hard work, great job on the the tubs too!
mcbassin is offline   Reply With Quote
Old 08-04-2012, 11:55 PM   #827
smokedat
smokedat's Avatar
after i finish the tubs i am going to re-shot the entire truk with poly fill then hopefully paint. For any one in this step of their builds i recommend sing U-POL URETHANE High Build DTM PRIMER. its good product and really fair priced at $65 it can be used as a DTM or high build. The valspar DTM i used was like 3 times more
Alex - Dirty AL "One Piece at a Time"
Follow me on Instagram alex.barr.ios
smokedat is offline   Reply With Quote
Old 08-05-2012, 03:55 PM   #828
rocking chevy
rocking chevy's Avatar
wow. I just read the whole thread. you have a great attention to detail, and your pickup looks fantastic. Keep up the great work.
rocking chevy is offline   Reply With Quote
Old 08-06-2012, 08:35 PM   #829
smokedat
smokedat's Avatar
i got further along, i finished glassing the top and bottom of the pocket and finished the the low spots with short strand. The glass is what is holding the actual pocket i will finish sand it and complete the process with regular body filler. It is structurally sound i could pick up the tub by the pocket, like if it was made this way. I still need to graft the back section of the tub.
Old 08-06-2012, 08:37 PM   #830
smokedat
smokedat's Avatar
Gracias, rocking chevy for the kind words.
Old 08-07-2012, 04:10 AM   #831
Driver4r
Just went thrue this whole thread, and WOW. Alot of work has gone into this so far. Alot more then i would want to do yet.
Good job so far.
Driver4r is offline   Reply With Quote
Old 08-07-2012, 11:00 AM   #832
rocking chevy
No problem, its just the truth.
Old 08-07-2012, 11:09 AM   #833
mcbassin
Still Learning
mcbassin's Avatar
awesome work on the glass Alex!
Old 08-08-2012, 12:59 AM   #834
slammed427
slammed427's Avatar
Looks great man! Imma follow along to the end.
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 08-08-2012, 01:12 AM   #835
smokedat
smokedat's Avatar
Thanks Mike, il try and post more detail pics and explanation of the glassing process to help any one with questions.
by the way when are you planning on spraying some color on your Truck?
Old 08-08-2012, 01:16 AM   #836
smokedat
smokedat's Avatar
Thanks Slammed427, glad to have you on-board
Old 08-08-2012, 08:26 AM   #837
mcbassin
Still Learning
mcbassin's Avatar
I am going to try to shoot some color this fall but not sure exactly. I have been working more hours than you can imagine. I just don't have any time left for working on the project. I'm still planning and buying parts just not building....
looking forward to your write up.
Old 08-17-2012, 06:04 AM   #838
68 TT
Still plays with trucks
68 TT's Avatar
Great work on the gaps Alex.
The truck is looking fantastic. Keep it up.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-17-2012, 10:29 AM   #839
kainzien
kainzien's Avatar
Damn, nice build! I will definitely keep up with this one..
Chickenhouse chopshop
81 rcsb chevy bagged LS1/4l60E(under the knife)
94 ecswb L92 headed LQ9/ 4l80E(waiting to go under the knife)
78 rcsb chevy LQ4/4L80E
kainzien is offline   Reply With Quote
Old 08-20-2012, 08:34 PM   #840
smokedat
smokedat's Avatar
I hear ya, it seems theirs never enough time to do what you like best, but at least you have a job to continue buying parts lolol.
Im still with you get at me or PM when you get ready to paint.
Old 08-20-2012, 08:36 PM   #841
smokedat
smokedat's Avatar
thanks fellas
Old 08-20-2012, 08:39 PM   #842
smokedat
smokedat's Avatar
I got further along in the process the glass work is complete but i have to finish it with body filler then spray some high build as they had extensive work. Once i complete the tubz %100 i will do the write up.
Old 08-20-2012, 08:50 PM   #843
smokedat
smokedat's Avatar
back panel cut and ready to be grafted
Old 08-20-2012, 08:55 PM   #844
smokedat
smokedat's Avatar
here the bottom section has been complete, and there you have it fellas a moded out tub
Old 08-20-2012, 09:34 PM   #845
smokedat
smokedat's Avatar
I don't have any pics of the tub installed but I left a small gap of 1/8"+or- to avoid direct contact and rubbing off the clear and eventually the paint. I will use 3M one sided stick on tape to act as a gasket and sealer, once compressed you won't see the gap anyhow.
Old 08-26-2012, 05:17 PM   #846
smokedat
smokedat's Avatar
fresh off the gun paint still tacky one tub to go
Old 08-26-2012, 09:25 PM   #847
aggie91
I'm just glad to be here!
aggie91's Avatar
Looking good!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-27-2012, 12:53 AM   #848
luifer76
luifer76's Avatar
tubs look great bro nice job....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 08-27-2012, 08:44 AM   #849
mcbassin
Still Learning
mcbassin's Avatar
You never stop suprising me with your skills! Nice work Alex. Can't wait to see some paint on this ride.
Old 08-27-2012, 08:50 AM   #850
lolife99
67-72 parts collector,…
lolife99's Avatar
You have done an amazing job modifying these tubz to work around your 73-80 hood hinges.
I have one question.
Aren't your wheels going to have to be WAY inside the fenders for them to clear the "pocket" you added?
Looks like they will have to to be 3"-4" inside the fender.
Keith
Convert to disc brakes.
73c10, c10, cheyenne, ls1, swap
