Old 04-03-2014, 09:17 AM   #826
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
OK, more parts enroute....ordered new ARP flywheel & pressure plate bolts.
ARP Flywheel bolts 7/16" - 20 x 1" ARP-100-2801 $10.29 180,000psi
ARP Pressure plate bolts 3/8" -16 x 1" ARP 130-2201 $13.10 180,000psi
Need to double check the flywheels I have. Most are 10.5", but I believe I have one that will hold an 11" clutch also. If not, I'll ordered one from Summit. I know the bellhousing is part # 3815891 and it will except 10.5" or 11" clutch.
Other issue I'm sorting out is to use a stock starter or a high torque starter. I hear pros/cons for both. And I don't want to chew up a flywheel with a high torque starter either.......
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-03-2014, 01:54 PM   #827
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
With that clutch you should easily be able to do a 3rd gear burn out! LOL! Yep..I'll get you some pictures when I can..the 77 is on jacks right now..big ol 496 V8 blew up the spider gears in the axle...that was funny..until the amount of money it costed to buy the new parts...but..gave us an excuse to convert to a posi. lol By the way..What year is the hood bird on your 63 again?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-03-2014, 03:09 PM   #828
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
60-61 hood ornamnet. chevy has the long pointed nose and the gmc's are short and blunted
Old 04-03-2014, 07:57 PM   #829
bj383ss
bj383ss's Avatar
Re: 1963 C-10 in NC
I have a high torque starter on my Caprice. The two things I like about it is kicks the high CR 11.1 over with no problem. Second is it has different positions to make it fit better around headers. I would definitely recommend it if you big block is high compression.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 04-04-2014, 08:36 AM   #830
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Ive been looking into them...will decide this weekend.
Old 04-05-2014, 08:54 PM   #831
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
clutch kit and the new arp bolts arrived. went through my stash and found a good 168 tooth flywheel that'll take an 11" clutch. i'll take it down monday to get turned....it looks good, no broke/chipped teeth or cracks. so now just down to exhaust decisions
Old 04-07-2014, 08:10 AM   #832
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
A few pics of the flywheel and clutch. Spent most of the weekend working in the yard. We are in flow blown pine pollen season down here and any outdoor painting is on hold until the pine trees are done.
Will get the flywheel up to the machine shop tomorrow to have it turned. All bolts are in, so clutch assembly is complete.
Old 04-07-2014, 11:04 AM   #833
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Neat!
Old 04-07-2014, 11:07 AM   #834
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
yeah, glad all the parts for the conversion are done except, exhaust. my banks happy too.
Old 04-07-2014, 11:58 AM   #835
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Dropped the flywheel off at my machinists today. $35 and I'll have it back by lunch tomorrow. So more good news. Now just need to get some exhaust quotes to compare to the flowmaster universal 3" kit prices. And starter....still debating standard big block starter or hi torque starter.....
Old 04-09-2014, 11:22 AM   #836
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Big brown truck came yesterday....brought my new front/rear and rear diff brake lines. Had some made in stainless steel. Not much new to report.....been busy with yard/house projects....but back at it this weekend. Looks like April 25 is the tentative swap date...so stay tuned.
Old 04-09-2014, 12:54 PM   #837
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Another small job done. Just back from the machine shop....nothing like freshly turned metal!!!! This should make the new clutch happy. Just need to install the pilot bearing and bolt on the flywheel & clutch now.
Old 04-10-2014, 10:56 AM   #838
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Got the threads all retapped last night and the bolts in for the clutch housing. Pilot bearing removed and new one installed also, so clutch assembly is finally done. Just need to do final assembly and install. I'll get the clutch and bell housing installed this weekend so the only thing to add will be the trans. Getting closer and ready for the 25th to come around!!!
Old 04-12-2014, 06:48 AM   #839
bj383ss
bj383ss's Avatar
Re: 1963 C-10 in NC
So where did you get your brake lines from? And are they stock or for front disc conversion.
Bret
Old 04-12-2014, 07:07 PM   #840
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
The fronts are a kit from Brothers to be used wit a disk front end and the front/rear and rear linsI ad made up by a guy online that I've been using for awhile. He does excellant work and I'v never had a line not fit from him.
Old 04-12-2014, 07:41 PM   #841
TJ's Chevy
TJ's Chevy's Avatar
Re: 1963 C-10 in NC
Looking good!
Old 04-12-2014, 07:46 PM   #842
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Getting there....progress on the fleetside today, so maye some stepside work tomorrow.
Old 04-14-2014, 08:29 AM   #843
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Got the last of the fuel line assembled yesterday for the big block. Will get the clutch set up tonight and maybe the pulleys if I get time tonight. Still need to reset the engine to top dead center on #1 and adjust vacuum advance placement on the distributor. With the water bypass system in place it limits the distributor play. Got the carb and return spring bracket mocked up yesterday also. (even though carb will have to come back off to install). Temp sending unit installed too.
I plan to plumb in a fuel pressure gauge on the out flow of the filter. Will be easy to plumb in with some unions.
Finally got the process down to make the hoses without tearing up the anodized fittings while tightening them down.
Old 04-14-2014, 11:26 AM   #844
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Got the fitting ordered this morning for the fuel pressure gauge. This will only add about 1.5" to the line length and I can plumb it in after the fuel filter. This will give me fuel pressure reading out of the filter. Russell 670340 -6an male/female with 1/8npt port for the guage.
Also picked up an engine stand from harbor freight today.....1000lb stand on sale from $89.99 marked down to 45.99. Got some new grade 8 bolts to go with it also. I've got a cherry picker, but have needed a rotating stand for awhile. I have an engine cradle that rolls that's great, but doesn't rotate.
Old 04-14-2014, 08:36 PM   #845
bj383ss
bj383ss's Avatar
Re: 1963 C-10 in NC
Not sure if its the same on the big blocks but don't forget the short bolt behind the oil filter housing so you don't crack the oil filter housing when you mount it on the stand.
Bret
Old 04-14-2014, 10:49 PM   #846
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
the stands for the 348, and yeah it has the canister filter with the bolt behind it. i'd like to convert to a spin on style.
Old 04-14-2014, 11:14 PM   #847
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
got the fuel line on, didnt get time for the pullys. got distracted by removing the trans from the 348. i'll try and get the pulleys, alternator & brackets & fan on tomorrow if its not raining outside. need to get the flywheel & clutch mounted too.
Old 04-15-2014, 08:27 AM   #848
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
Pic from yesterday. I need to swap out the valve covers also for the finned edelbrocks.
Old 04-16-2014, 07:57 AM   #849
TheBlueBomber
TheBlueBomber's Avatar
Re: 1963 C-10 in NC
Have you gotten a chance to finish the other cover?
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 04-16-2014, 08:42 AM   #850
1963c-10
1963c-10's Avatar
Re: 1963 C-10 in NC
About 60% done....was looking at it last night when the rain blew through, but was just too tired from the last few weeks of work with no days off. Out of town on the camping trip frri-sun, so maybe when I get back sunday night I can get back on it.
