Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-28-2019, 11:26 PM   #851
Vero67
Re: Power Steering Adapter Plates
Great thank you
Vero67 is offline   Reply With Quote
Old 05-02-2019, 08:18 PM   #852
Vero67
I received the part today, looks great! Thank you for the fast shipping.
Old 06-19-2019, 11:26 PM   #853
l79m20
Need a power steering setup for a 1965 c10. Plate and items to shorten shaft. PM with info. Thanks.
l79m20 is offline   Reply With Quote
Old 06-19-2019, 11:32 PM   #854
Captainfab
60-66 Nut
PM sent
Old 06-20-2019, 06:52 AM   #855
Vero67
Thanks again, some information for 67 K10 owners. I used the original upper rear hole in the frame, then lined up my box and steering shaft. Scribed where the adaptor was, then marked and drilled the holes. Worked out great.
Old 06-26-2019, 12:40 AM   #856
l79m20
Received the parts today. They look great as usual. Thank you so much.
Old 06-26-2019, 11:21 PM   #857
Captainfab
60-66 Nut
Thank you for the compliment
Old 07-06-2019, 01:46 PM   #858
kmabe
I need a power steering adaptor plate let me know what I need to do thanks
kmabe is offline   Reply With Quote
Old 07-06-2019, 11:03 PM   #859
Captainfab
60-66 Nut
I will send you a PM with ordering and payment info.
Old 08-05-2019, 02:22 AM   #860
bigdisplay442
bigdisplay442's Avatar
I installed my gearbox and plate months ago but I'm just now hooking up the pitman arm and the center link. My pitman arm is too long for the 1978 PS gearbox I'm using. What did I miss in the instructions that I no longer have? Which pitman arm was I suppose to use? The center link won't clear the engine cradle.
Thanks.....
bigdisplay442 is offline   Reply With Quote
Old 08-05-2019, 11:16 PM   #861
Captainfab
60-66 Nut
You should be using the 1978 C10 pitman arm. Are you sure it is installed all the way onto the sector shaft? Did you install the adapter plate according to the instructions and use the supplied template?
Old 08-16-2019, 10:57 AM   #862
Awats
Hi Capt fab,will a power steering box from a 4x4 C10 fit my 66 burb with one of your brackets.Very few breakers here across the pond and shipping one over is very costly.
Awats is offline   Reply With Quote
Old 08-17-2019, 12:23 AM   #863
Captainfab
60-66 Nut
While the K series steering box will bolt up, the sector shaft is different and will not accept a C series pitman arm.
Old 10-17-2019, 09:34 PM   #864
grubsster
grubsster's Avatar
Hi Captain.
I am getting the parts together to do the power steering swap. I used 72 C10 spindles and steering column when I did my power brakes/automatic trans swap. I have an undated power steering box that is standard so I am assuming 70's. Can I use my current pitman arm on the power box? Also since I have the collapsible column, I assume I should be able to just mount the rag joint to the box. Please PM with payment info for the plate and hardware. Also any advice would be greatly appreciated. Thanks
grubsster is offline   Reply With Quote
Old 10-17-2019, 10:45 PM   #865
Captainfab
60-66 Nut
You must use the pitman arm that is for the particular power steering box that you are using. You can NOT use the pitman arm from your original manual steering box.
The rag joint always bolts directly to the steering box input shaft. That is unless for some reason you are eliminating the rag joint all together and using a universal joint.
Originally Posted by grubsster View Post
Hi Captain.
Old 11-08-2019, 12:46 AM   #866
T and S
T and S's Avatar
Captainfab I need an adapter plate for a power steering box for a 1966 C-10. Also, will a collapsible intermediate shaft work with the power steering box on a 66'. I know I will have to cut off and modify the steering shaft at the column. Please send me PM on ordering info. Thanks !!
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 11-08-2019, 12:49 AM   #867
Captainfab
60-66 Nut
Yes you can use a collapsible intermediate shaft. I will send you a PM with ordering info.
Old 11-08-2019, 07:45 PM   #868
T and S
T and S's Avatar
Payment and shipping info sent through paypal - Thanks !!
Old 11-08-2019, 11:40 PM   #869
Captainfab
60-66 Nut
Payment received. I will ship your order on Tuesday since Monday is Veterans Day.
Old 11-16-2019, 12:42 PM   #870
T and S
T and S's Avatar
Parts received - Thanks !
Old 11-17-2019, 12:16 AM   #871
Captainfab
60-66 Nut
Thank you for the purchase
Old 12-05-2019, 12:40 PM   #872
Patinatruck
Jon,
I need a an adapter to convert my 65 c10 to power please send me pm with details on how to order, thanks!
Patinatruck is offline   Reply With Quote
Old 12-05-2019, 11:15 PM   #873
Captainfab
60-66 Nut
I replied to the email you sent me this morning. Did you not receive it?
Originally Posted by Patinatruck View Post
Jon,
Old 12-26-2019, 10:59 PM   #874
Captainfab
60-66 Nut
Due to an increase in the cost of the laser cutting, I have had to increase the cost of the steering box adapter plates.
Old 01-02-2020, 12:19 PM   #875
Dieman63
PM sent
Dieman63 is offline   Reply With Quote
