Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 06-06-2012, 11:18 AM   #851
scotts62
One day...
scotts62's Avatar
Re: My 93 Crewcab Build
Originally Posted by JohnC View Post
Are you sure you're talking about the same Scott we are?
Looks good man! Hopefully with the parts truck you can get that thing buttoned up!
im workin on it!
Originally Posted by 2chainz View Post
scott I need your help lol what do I need to do about my drive shaft? I have the suburban shaft and they said they could not make a drive shaft that long
smh
Sorry dude i forgot about measuring that for you. It will have to have a carrier bearing in it, i should have drive line in today so i can get it measured.
You can tell in the pic about where the carrier bearing is.
Here is some progress for ya
Scott
93 crew cab build
Project 62
Old 06-06-2012, 02:14 PM   #852
mcbassin
Still Learning
mcbassin's Avatar
Nice work Scott! Shorter is better....
mcbassin is offline   Reply With Quote
Old 06-06-2012, 08:16 PM   #853
scotts62
One day...
scotts62's Avatar
Thank you sir
That has to be my motto
Scott
93 crew cab build
Project 62
Old 06-06-2012, 10:46 PM   #854
2chainz
Great work scott looking good over there
2chainz is offline   Reply With Quote
Old 06-06-2012, 11:05 PM   #855
scotts62
One day...
scotts62's Avatar
Appreciate it, got frame just about sewed up and ill get the drive shaft in to measure it for ya.
Scott
93 crew cab build
Project 62
Old 06-10-2012, 11:06 AM   #856
2chainz
How we looking over their scott?lol any lead way
Old 06-10-2012, 11:55 AM   #857
scotts62
One day...
scotts62's Avatar
Got the frame buttoned up yesterday, i still need to put the lowering kit on the rear to level it out.
Scott
93 crew cab build
Project 62
Old 06-10-2012, 12:38 PM   #858
2chainz
So you already have your lowering kit? I finally got a 2 piece drive shaft out the scarp yard. For my truck it came out a extended cab long bed the big boy. It was bent but I have to have it shortened anyway so I will do I have to figure out what I am gonna do about a cross member they dont let you bring air tools out there smh
Old 06-10-2012, 12:46 PM   #859
scotts62
One day...
scotts62's Avatar
Yeah i have a 5-7 drop kit for it, front is on already.
Heck yeah, shouldnt be too bad once you break it loose. If i remember right it was a 16 and 18mm..
Scott
93 crew cab build
Project 62
Old 06-10-2012, 12:58 PM   #860
2chainz
I wanted to post some pictures but it still wont let me post
Old 06-10-2012, 02:22 PM   #861
scotts62
One day...
scotts62's Avatar
Try this out Clicky
Start a build thread yet?
Scott
93 crew cab build
Project 62
Old 06-10-2012, 03:56 PM   #862
2chainz
No I never made a thread
Old 06-16-2012, 10:17 AM   #863
scotts62
One day...
scotts62's Avatar
Frame done and rear lowering kit on
Rear is a couple inches lower than the front and not sure if the 1 ton frame up front is a bit different and making it sit higher or what.. going to raise the rear up a bit but it is close to sitting level.
Scott
93 crew cab build
Project 62
Old 06-16-2012, 10:21 AM   #864
2chainz
Nice looks good got my drive shaft back yesterday just need to make time now smh
Posted via Mobile Device your truck looks great cant wait to see it painted
Old 06-17-2012, 04:01 PM   #865
JohnC
JohnC's Avatar
Looks good man. Coming along nicely.
JohnC is offline   Reply With Quote
Old 06-17-2012, 04:22 PM   #866
mcbassin
Still Learning
mcbassin's Avatar
Wow Scott ! That looks great!
Old 06-18-2012, 07:09 PM   #867
scotts62
One day...
scotts62's Avatar
Thanks guys!
Scott
93 crew cab build
Project 62
Old 06-20-2012, 12:07 AM   #868
jwalk
What was I thinking?
jwalk's Avatar
Looking good Scott!!!
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 06-20-2012, 04:59 PM   #869
scotts62
One day...
scotts62's Avatar
Thanks Justin!
Scott
93 crew cab build
Project 62
Old 06-24-2012, 10:09 PM   #870
Vega_67C10
Vega_67C10's Avatar
Nice work Scott.
I Saw Elvis at 1000 Feet - John Force
Vega_67C10 is offline   Reply With Quote
Old 06-24-2012, 10:21 PM   #871
scotts62
One day...
scotts62's Avatar
Hope to get teh fuel tank in it and figure out why its higher on the passenger front (hoping a spring is not in the cup right)
Scott
93 crew cab build
Project 62
Old 06-25-2012, 08:34 PM   #872
scotts62
One day...
scotts62's Avatar
Got it in and measured and with it up and on stands it measured 92 1/2, i cant get under it to measure it how it is suppose to be
Did get the tank in it and started up again. It smoked the first time i started it a few weeks back and was beginning to worry me a bit but the tank in the frame had fresh fuel in it and it purred like a kitten for the 30 min i let it run and no problems. It is lower in the rear and im thinking about flipping the hangers to raise it a bit verses lowering the front more and not being able to haul anything..
Scott
93 crew cab build
Project 62
Old 08-07-2012, 08:49 PM   #873
scotts62
One day...
scotts62's Avatar
Well i flipped the hangers and raised it up a bit and now it looks a lot better. The rear of the frame was tweaked i guess from the wreck on the donor frame so i put it on the trailer and used the winch to pull it down then heated a part that was bad and pulled it back to shape
So ready to get it driving!
Before
After
Scott
93 crew cab build
Project 62
Old 08-07-2012, 09:06 PM   #874
2chainz
Old 08-07-2012, 09:06 PM   #875
2chainz
Nice scott
