Old 08-29-2012, 03:11 PM   #851
smokedat
smokedat's Avatar
Re: LS1 into a 73 cheyenne
Thanks.., about the clearance my set up will work because i am running 18'' wheels in the front and its is lowered but not laying frame like on an air bag set up. Clearance issues will occur if you run a big wheel up front like say a 24"++ and you have an air bag laying frame, then the pockets will interfere.
I took a few pics of the current driving ride height and this gives me like 5-6" of travel so i have planty of room to spare
You have done an amazing job modifying these tubz to work around your 73-80 hood hinges.
I have one question.
Aren't your wheels going to have to be WAY inside the fenders for them to clear the "pocket" you added?
Looks like they will have to to be 3"-4" inside the fender.
Alex - Dirty AL "One Piece at a Time"
Follow me on Instagram alex.barr.ios
smokedat is offline   Reply With Quote
Old 08-29-2012, 03:12 PM   #852
smokedat
smokedat's Avatar
close up of the pockets in the open and close positions
Old 09-08-2012, 01:25 AM   #853
Gordonr1973
Home Built '87
Gordonr1973's Avatar
(Not counting the guys who posted in the weeks before his last post): It took 10 days for someone to say what a great job Alex's doing?? Tough crowd!!
Beautiful work!! I'm proud to be one of your biggest fans!
I'm wondering if there are any more updates??
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 09-08-2012, 01:28 AM   #854
y5mgisi
Second Chance Program
y5mgisi's Avatar
Probably everyone is left speechless! Every bit of this has been a work of art.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 09-08-2012, 11:22 AM   #855
kvn1011
Kvn1011
kvn1011's Avatar
kvn1011 is offline   Reply With Quote
Old 09-08-2012, 11:22 AM   #856
kvn1011
Kvn1011
kvn1011's Avatar
^^^^speechless
Old 09-08-2012, 12:03 PM   #857
mcbassin
Still Learning
mcbassin's Avatar
Awesome work as always Alex! Keep the updates coming
mcbassin is offline   Reply With Quote
Old 09-08-2012, 12:20 PM   #858
Gordonr1973
Home Built '87
Gordon
Old 09-08-2012, 09:20 PM   #859
smokedat
smokedat's Avatar
Thanks , good looking out Gordon
As far as updates I'm still finishing up the second tub. After that I need to weld in a pop up gas cap, to replace the original the pop up gas cap is pretty cool its off a motorcycle. It's what they use on custome motorcycle gas tanks . Il post pics of it later.
Old 09-09-2012, 12:37 PM   #860
smokedat
smokedat's Avatar
here is the gas cap. its a weld in pop up gas cap, the bung is steel and the cap is aluminum. These are a popular mod in the motorcycle scene.
Old 09-09-2012, 12:49 PM   #861
smokedat
smokedat's Avatar
i will be installing the gas cap in the same stock location passenger side because i already have that set up, i wanted to relocate it all together and place the gas cap in the bed floor towards the back near the tail gate but this would not work because i would need a fuel cell and the fuel cell would block the exhaust pipes exiting out through the location i plan on using, i will exit my pipes like the corvettes do out the back bumper area, im already having issues as is with the lowered suspension you cant go over the top of the axle but i figured out a way to accomplish this
Old 09-09-2012, 10:42 PM   #862
kvn1011
Kvn1011
kvn1011's Avatar
Thats a nice cap, so to open ,do you just unscrew it? Or do you have to push down and twist?
Old 09-09-2012, 11:34 PM   #863
smokedat
smokedat's Avatar
yes its a pop up gas cap, the idea is you push in then it pops out then you just unscrew it like a normal cap. the only limitations of this cap in order to work is that you need a rather flat surface to sit flush, you could probly make it work on a radius but it wouldn't look as good
Old 09-09-2012, 11:53 PM   #864
kvn1011
Kvn1011
kvn1011's Avatar
Ok cool, i may look into getting one later, thats pretty cool
Old 09-10-2012, 02:51 AM   #865
y5mgisi
y5mgisi's Avatar
That cap is pimp!
Old 09-12-2012, 11:25 AM   #866
truckzilla
truckzilla's Avatar
Just went through your build and man, what a great job you've done. Keep it up and I had to subscribe to see how it finishes up!
truckzilla is offline   Reply With Quote
Old 09-12-2012, 11:48 AM   #867
mcbassin
Still Learning
mcbassin's Avatar
lot of good ideas to steal from this build. dig the gas cap
Old 09-13-2012, 05:47 AM   #868
_NATHAN_
NICE!!!
_NATHAN_ is offline   Reply With Quote
Old 09-15-2012, 08:42 PM   #869
73gmc454
73gmc454's Avatar
I like all the progress, everything is lookin great !
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 09-18-2012, 07:06 PM   #870
smokedat
smokedat's Avatar
thanks everyone, for the encouraging and positive feedback
Originally Posted by y5mgisi View Post
That cap is pimp!
Originally Posted by _NATHAN_ View Post
NICE!!!
Old 09-18-2012, 07:26 PM   #871
smokedat
smokedat's Avatar
finally got around completing the tubs and the mounting area where it bolts from core support to tub, i cut out the old mount area left about a 1/2 trim then i laid a new piece of sheet metal following the tub contours cus it tapers then made 2 new holes rather than the 3, i think it looks like stock like if it was never moded, for the hardware i went with stainless button head bolts
Old 09-18-2012, 07:35 PM   #872
smokedat
smokedat's Avatar
before. The holes where off so i patch the tub and fabd a new mount, desided to bolt down with a lock nut rather than the blind nuts on top
Old 09-18-2012, 11:55 PM   #873
kvn1011
Kvn1011
kvn1011's Avatar
Damn, great attention to detail!!
Old 09-19-2012, 11:53 AM   #874
mcbassin
Still Learning
mcbassin's Avatar
Very nice work Alex! Getting close to paint time huh?
Old 09-19-2012, 07:45 PM   #875
smokedat
smokedat's Avatar
thanks Mike , yea its getting close as far as any other deviations such as ideas or new mods i think its done-complete so yeah close to paint
73c10, c10, cheyenne, ls1, swap
