Old 10-01-2011, 11:26 PM   #851
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
Oh ya.......... forgot to mention i think i have bought a house with a 3 car shed/carport/barn thing. So i now (or soon) will have a good place to work on buddy. He is excited about all this. No more rain on his head (that is if it would ever rain here again) he says!
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 10-02-2011, 04:25 PM   #852
85burb
85burb's Avatar
For got to post a pic of the coolest burb other then mine i have ever seen......
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-05-2011, 08:38 PM   #853
85burb
85burb's Avatar
Well i got my burb back from rear end shop today.........I have failed myself. I told my brother 98 time befor he ordered his gear set to check the ratio..... So i should practice what i tell him sometime. As it turns out i hade 3.73 gears in my truck. The set i ordered are 410. The diff shop did not think to look at what set i had in it cause i got the parts my self. So it looks like i will be getting thr front done sooner then i had thought. FAIL!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-05-2011, 09:02 PM   #854
y5mgisi
Second Chance Program
y5mgisi's Avatar
Oops! Feel better with the new gears does it?
y5mgisi is offline   Reply With Quote
Old 10-05-2011, 09:08 PM   #855
85burb
85burb's Avatar
The guy that installed diff says to brive it nice for 2 heat cycles then get on it. I deffinitly feel a difference. The speedo is way off i think now. I bet i can do some really nice burnouts now, It did them really nice ones with the 373.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-05-2011, 11:28 PM   #856
85burb
85burb's Avatar
Here is a pic of the old worn out diff and gear. The fluid in it was a mix of 50/50 oil water. The last time i went threw water that deep was 3 years ago when i lived in colorado. The spider gears all had pits and chips and the thrust washers were also worn badly. The guy had to scrape rust off the inside of the housing and remove rust from wheel bearing area also. The gears were gm gears from 1985. I was told that the axles were from a 79 k20. They sure held up good no mater when they were made. I drove it prob over 10xxx miles with the fluid like that. The gears had a great ware pattern on them too. Just showes how tuff these old trucks are.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-06-2011, 12:49 AM   #857
MTCK
MTCK's Avatar
Ah the accidental upgrade, I love that! I bet those 4.10's will feel great with the way your rig is set up.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 10-06-2011, 05:36 PM   #858
85burb
85burb's Avatar
It deff feels different. I have on more heat cycle tell i will get on it. I am sure it will be faster. I am not sure if the gear change will help my speedo. Befor it said 55 and i was actually doing 65. That was with 373. Now it has 410 gear. Would that help my speedo or make it more off. I am thinking it would help right?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-06-2011, 05:52 PM   #859
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
should make it closer....?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-06-2011, 06:01 PM   #860
85burb
85burb's Avatar
That is what i was thinking. But i am not sure. Will have to bust the good ole gps out and see.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-06-2011, 06:01 PM   #861
y5mgisi
y5mgisi's Avatar
http://4lo.com/calc/geartable.htm
Old 10-07-2011, 09:11 PM   #862
85burb
85burb's Avatar
Well i took buddy for his first long drive with new rearend. My speedo is exactly the same as my gps. It is dead on at 35-65. Befor and after the gps and speedo disagree a tad. It also drives way better the befor. Has more power runs smoother around town due to rpm be a little higher. 65 mph is a little under 1900 rpm. I love the new set up. It spins both tires if i "power break" or stall test or what ever you call it. Deff have some wheel hop now. But overall it is perfict.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-07-2011, 09:16 PM   #863
MTCK
MTCK's Avatar
Launch pretty hard if you just mash it?
-Marcus
Project Plow Truck
Old 10-07-2011, 11:09 PM   #864
85burb
85burb's Avatar
Oh ya. Befor it would most of the time smoke a tire now i am worried about breaking a seat....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-09-2011, 09:29 PM   #865
85burb
85burb's Avatar
So the hole time i have had the new motor in the truck i have had a slight issue i have not messed with. Some times in or out of gear you can hear the fuel pump change it humm and then the motor bogs down to like 200 rpm. I am not sure if it did it with old motor but i dont think so. It will idle great then just bog down to 200 and come right back up to 750. It did it with efi and with carb. It has never died. I dont think it would be trans related cause it does it in gear and in N. Any ideas?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 10-10-2011, 07:34 PM   #866
68GMCCustom
wow that's a tough one...since you changed the fuel system completely. I'm guessing it has a different line and fuel filter then before too? If so...the only constant is your gas tank. Any chance of contamination?
Any chance the MSD is causing it?
Kurt -
Old 10-10-2011, 11:16 PM   #867
85burb
85burb's Avatar
It is a different filter but same line. I have one of those see threw glass filters infornt of my pump and it is clean. I dont think my tank is contaminated. It has seen many many many gallons of fuel threw it and gotten faily low a few times with no change. It is like something is draging the alt down or something. Cause if it were fuel i dont think it would have affected the carb right at the same time the fuel pump starts to get loud. Cause of the resurve in the bowl. I can tell you exactly how far i can go on a float bowl full of fuel. I used to for get to turn my fuel pump on some times after sitting at work waiting for the gate to be opened.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-11-2011, 11:44 PM   #868
68GMCCustom
you seen this build? LY6 in a '77 K30 3+3 4x4....using Street&Performance headers.
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
Kurt -
Old 11-12-2011, 12:51 AM   #869
85burb
85burb's Avatar
Yes i have seen his build. I found them headers a long time ago but cant see 600 on shorties. Thanks for the link tho.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-15-2011, 10:36 PM   #870
85burb
85burb's Avatar
I feel faint....Just spent 93,xxx dollers..... Bought a house, fridge, dryer, microwave, and carpet cleaner. But now i have a 3 car garadge type structure and no more downstairs or side neighbors. Have 1.127 acres of land also for future shop. VERY excited. Will get pics soon.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-15-2011, 10:39 PM   #871
bayou boy
bayou boy's Avatar
very nice ever need any a/c work holla
all i know is that its going to be orange
bayou boy is offline   Reply With Quote
Old 11-15-2011, 10:50 PM   #872
85burb
85burb's Avatar
Will do. Would love to help a board member.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-16-2011, 04:20 AM   #873
y5mgisi
y5mgisi's Avatar
Awesome man! Congrats!
Old 11-16-2011, 07:23 PM   #874
85burb
85burb's Avatar
Thanks cant wait to move in.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-17-2011, 12:10 AM   #875
MTCK
MTCK's Avatar
Congratulations that is a big milestone!
-Marcus
Project Plow Truck
