06-27-2014, 07:33 PM | #851 | |
Re: What did you do to your truck today? Chapter II
06-27-2014, 07:40 PM | #852 |
x2
1970 C10 Short Stepper with 71/72 front clip. |
06-27-2014, 09:18 PM | #853 |
Finished up the Vintage Air install enough to get the system charged. Still in shock that there is cold air in the truck.
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
06-27-2014, 09:33 PM | #854 |
Nice, I love my VA AC. I usually drive around with the AC on and the drivers window down unless I'm on the freeway. Even when it's 100 plus it's nice and comfortable.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
06-27-2014, 09:46 PM | #855 |
What brackets are you using for the ac compressor?
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
06-27-2014, 09:57 PM | #856 |
Bout time your getting that beast finished up. Looking great!!!
06-30-2014, 09:46 AM | #857 | |
Door Hinge Repair
I thought the door hinges didn't get replaceable bushings until 1973 , we used to stock those (OEM bronze not plastic) as well as the check springs . Who's the best vendor for this ? . TIA ,
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
06-30-2014, 10:35 AM | #858 |
07-01-2014, 01:39 AM | #859 |
I had to rebuild all the door hinges on my 70 Suburban. I bought the kits from Brothers in Corona. My pins were rusted to the hing so I had to drill them out. The new brass bushings were too big for the holes the plastic ones came out of. I used a drill a little smaller than the knurling on the bushing and they fit great. The pins were a little tight on the half that that the old pins were rusted into so I had to sand them a little. I used an old 3" long, 1/4" bolt that I cut the head off of, cut a slot in it about a 1/2" long, put some emery cloth in it, put it in my die grinder and sanded till the pins fit snug. The pins I got were a little long, so I just cut them to length. They work great. Took a couple hours to do all 6.
07-01-2014, 09:19 PM | #860 |
Installed a temporary temp gauge. I put it in one of the ebay buckets so it doesn't look too trashy. I mounted it under the heater controls and just above the shifter so it looks like a tranny temp gauge. Had to replace the shifter cable too. Runs like a top again.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
07-01-2014, 09:25 PM | #861 |
went from this
to this |
07-01-2014, 09:26 PM | #862 |
Since I just got my truck yesterday, I'm still assessing body rot and cleaning it out.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored 1978 Turbo Malibu - Owned since 1986 1987 Grand National Aerocoupe -1 of 1 1988 LeSabre T-Type - Supercharged |
07-01-2014, 10:21 PM | #863 |
I like your choice in trucks! I put the passenger side door on mine today.
07-01-2014, 10:26 PM | #864 |
RAT1968 '68 Cab/'71 Parts
So, does that make it a temp temp gauge?
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
07-01-2014, 10:41 PM | #865 |
07-02-2014, 12:09 AM | #866 |
You know...I don't know how much I added. I know they are 18" wide now but I don't know how wide they were stock. Took four stock ones, cut them up and made two wide ones. Kinda' like the money I spent building the truck...took a big pile of money, cut it up and...you know the rest.
07-02-2014, 12:19 AM | #867 | |
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
07-02-2014, 09:47 AM | #868 | |
----------------------------------------------------------- Erik My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626 1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647 RUST!? Thats just mother natures way of telling all of us.....MINE!!!! |
07-02-2014, 10:02 AM | #869 |
Yes it does. Been fighting the wiring gremlins and didn't want to chance overheating before I replace the harness. But it's too dang nice not to drive her.
07-02-2014, 10:05 AM | #870 |
Door Hinges
THANK YOU ! .
For what it's worth , I often make things hone to fit by using 1,000 grit or finer taped to an old drill bit , well oiled then spin it in the hole with a drill motor ~ works like a charm .
07-02-2014, 01:38 PM | #871 |
Brought this home a week ago: 70 CST, 396, posi, tach, buckets and cab roof lights!!!
Like I need another project..... |
07-02-2014, 01:55 PM | #872 |
I picked up my seats, headliner, and visors from the upholstery shop. Not ready to put them in yet, but I picked them up.
07-05-2014, 06:05 PM | #873 |
Finally got the cab and chassis back from the body shop, mechanic dropped in a 406 roller. surprisingly the hooker headers fit like a glove, he was very surprised for some reason. Just waiting on the carb and hook the new gas tank and hopefully GOOD to go.
07-05-2014, 06:42 PM | #874 |
The brown truck showed up the other day with goodies from Moser..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
07-05-2014, 07:37 PM | #875 |
Refurbed an old gas cap with a new rubber seal cuz I couldn't wait for my new one. Got the new one today and it fits nicely. Changed out a burned out a/c fan switch and fuel filler neck seal. All the parts were from GMC Paul's, nice fit and price.
I need a lower profile screw to hold in the ac switch in the bottom hole because it hits a little when trying to switch the fan to high. I soaked the rubber seal in hot soapy water and it popped on nicely in just a few minutes thanks to advice from the board.
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
