12-16-2018, 12:15 AM | #851 |
Re: "Project Orangepeel" 52 A.D
Looks good son...Dad
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
12-16-2018, 12:53 AM | #852 |
Post Whore
Marc...those light mounts look great!!.....what if you welded a small tube for wiring where the red line is...sticking up inside the light housing and the other end into the stake pocket...
12-16-2018, 07:24 AM | #853 |
Looks good Mark!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
12-16-2018, 10:09 AM | #854 |
Thank's everyone!
Greg..I had planned on using brake tubing to run the wires through, its going to be 5/16 tube do to the size of the wire. So I'm not sure how it will look with that large of tube. I may just replace the wires they came with with a smaller insulated wire so it can go in a smaller tube. The other thing is I'm not sure if I want to have the tube on top of the radius,or the backside of the same radius. Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
12-16-2018, 05:25 PM | #855 |
Hello Mark. Mongocanfly idea will work. Maybe two tubes for two wires. Just a thought. Weld up like you would a patch panel then finish grinding. I like the way its going.
Earl
You have to have patiences or you'll be one. |
12-16-2018, 05:43 PM | #856 |
Post Whore
im sure whatever you come up:with itl be cool
12-16-2018, 05:57 PM | #857 |
Man, I love the creativity and execution in those tail light stands!
12-17-2018, 08:55 AM | #858 |
Earl Thank's, Yeah I've been kicking around that idea as well. Thank's for the input!
Mark
12-17-2018, 08:56 AM | #859 |
Thank's greg!
12-17-2018, 09:00 AM | #860 |
Thank's Doug, It was hard coming up with something (because of the drivers side) Do to the filler in the pocket,I can't just bolt something on.
I ended up welding studs to the pocket so it has acorn nuts on it. Mark
12-19-2018, 01:12 AM | #861 |
wow those taillight mounts came out great, I like them mounted higher like that, probably easier to see.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
12-19-2018, 08:46 AM | #862 |
Thank You.
I tried them at different levels to see how they looked, and landed on this. They are LED so should look really good when lit up. My first thought was to have them down on the pan above the bumper but figured it would be to hard to see for a higher vehicle. Mark
12-20-2018, 07:05 PM | #863 |
Good thought, that's why I put lights in my bed roll.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
12-21-2018, 08:40 AM | #864 |
As much as I liked them on the pan it just wasn't worth the risk.
12-24-2018, 02:17 PM | #865 |
I like the look of the mounts. I’m with you on where you mounted them. I like simple.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
12-24-2018, 06:40 PM | #866 |
Thanks Rusty!
12-26-2018, 08:58 PM | #867 |
Update:
So today I left a bit early from the shop to come home. A good friend of mine and me stripped the truck down so I can get the frame ready for paint. Looks so sad now!
12-26-2018, 10:18 PM | #868 |
funny how doing it right means putting them together then taking them apart again.
hope you had a great holiday!
12-27-2018, 08:37 AM | #869 |
Thanks, I did!
Hope you did as well.
12-27-2018, 06:20 PM | #870 |
Cool, put them together, take them apart, put them back together. My non car friends never understand how taking them apart is progress.
12-27-2018, 06:27 PM | #871 |
Yep, this is normal.
You build one car three times at least
12-28-2018, 08:43 AM | #872 |
I think I'm on #5 or #6 now!! LMAO all part of this Hobby we love so much.
01-05-2019, 11:43 PM | #873 |
A few shots of what I very got done.
01-06-2019, 12:00 AM | #874 |
super pretty man!
01-06-2019, 12:50 AM | #875 |
Looks good...Dad
