Old 12-13-2017, 07:38 PM   #851
Dan in Pasadena
Dan in Pasadena's Avatar
Re: 1956 Chevy Pro-Street Build
Originally Posted by Black_Sheep View Post
This is the latch I used, they can be found used on '85-'92 VW Jettas, Golfs and other models. It is set up for a cable release FWIW.
http://www.yogisinc.com/index.cfm/pa...d/prd13796.htm
Keep in mind that the filler between the radiator and the grille is different on a '56 and '58 so installing one might be a little different. I cut out the oval shape in the filler panel and welded in the lower latch from underneath. The upper latch was bolted to the existing under hood latch plate, only minor shimming and trimming was necessary.
Sorry no other pics and with the truck blown apart I cant go take one for you.
Too bad there are no more pic’s, I’d REALLY like to understand what you did better. But off hand (and not to hijack ptc’s thread - sorry!) is there any reason why this VW hood lower latch couldn’t just be mounted with small ss bolts to the stock ‘55-‘57 filler panel? Yeah, it wouldn’t look as cool as yours that is welded in but would it work? Since it comes cad plated it wouldn’t look too bad. I ask because my filler panell is already final painted.
Also for you, others and ptc (maybe) I once found someone who used ordinary metal desk type locks on the leading edge of his hood to provide a secondary lock/protection against the hood flying open at speed. Up until I saw yours, I was planning to do this too but only after all final adjustments to the hood fitment because there’s little room or error. No cable release, but I can live with that if I can be certain my hood is secure. I’ll see if I can find the old pic and will post it here.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 12-13-2017, 10:47 PM   #852
mud.man.rj
mud.man.rj's Avatar
I didn't realize 12lbs of boost would create so much pressure, now I understand why it's hard to keep a hose in place.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 12-13-2017, 11:43 PM   #853
ptc
ptc's Avatar
Originally Posted by Dan in Pasadena View Post
Too bad there are no more pic’s, I’d REALLY like to understand what you did better. But off hand (and not to hijack ptc’s thread - sorry!) is there any reason why this VW hood lower latch couldn’t just be mounted with small ss bolts to the stock ‘55-‘57 filler panel? Yeah, it wouldn’t look as cool as yours that is welded in but would it work? Since it comes cad plated it wouldn’t look too bad. I ask because my filler angel is already final painted.
Dan - It could be done easily you just have to mount the top part first, then put some paint on the tip of it to mark where it will land in your latch support and center the mounting base there with the 4 screws. It doesnt have to be aligned perfectly like our stock mounts.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 12-18-2017, 12:04 PM   #854
ptc
ptc's Avatar
Ok guys well here it is.... for now...
https://www.facebook.com/paul.christ...4885428631793/
Took the old man for a ride down to the gas station just to give him a little thrill!!!! --- Not that he hasnt had a few in his 94 years of life so far....
He was pretty happy with what the "kid" put together!
Old 12-18-2017, 01:48 PM   #855
Scottish58chev
Looks and sounds great. Nice work
Scottish58chev is offline   Reply With Quote
Old 12-18-2017, 09:27 PM   #856
oldman3
oldman3's Avatar
Sweeeet...Jim
oldman3 is offline   Reply With Quote
Old 12-18-2017, 09:43 PM   #857
Advanced Design
Advanced Design's Avatar
You and your Dad's big grins are contagious! And the video sounded grin inducing too. Awesome!
Advanced Design is offline   Reply With Quote
Old 12-18-2017, 10:35 PM   #858
mud.man.rj
mud.man.rj's Avatar
Nice video, just a beauty. I like the "kid" part, always be the kid hey. Really nice to have your dad around still and take him out, pretty special.
Mudman.
5.0 4spd std.
7" lift w 35's.
Old 12-19-2017, 01:05 AM   #859
lower50's
lower50's's Avatar
Get her tuned up and remember tires are cheap fun
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 12-19-2017, 04:36 AM   #860
Nut Case
Nut Case's Avatar
ptc
great sound, but......oh yeah "needs more cow bell"
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 12-19-2017, 09:19 AM   #861
Kim57
Kim57's Avatar
Very nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 12-19-2017, 12:33 PM   #862
Dan in Pasadena
Good to know, thanks!
As long as someone on earth still thinks of you as a kid, you’re good to go!
Old 12-19-2017, 02:42 PM   #863
slammed57
slammed57's Avatar
wow, what cam and what mufflers are you running. sounds REAL good
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 12-19-2017, 06:09 PM   #864
ptc
ptc's Avatar
Thanks everybody appreciate the kind words - its still a little rough but its an old truck and thats it for now. The old man really had a good time, I had him out in the flat-bottom boat last year for new years, he is a sailboat guy so speedboating seems a little crazy to him. But he enjoyed it.
I try an answer some of your questions separately, but thanks ALL!
Old 12-19-2017, 06:17 PM   #865
ptc
ptc's Avatar
The cam and all the valve train design was done by Straub Engineering in TN, He spec'd out everything for the engine build top end. The cam is a custom cut hyd roller he makes for S/C engines.
Lift is .6885 INT and .6630 EXH - 1.7 ratio
Duration @.050" is 260 INT and 275 EXH
Separation is 112
Its a big lift cam!
Muffs are just some Dynojet bullet mufflers from Summit. I need to add more MUFF...
Old 12-21-2017, 12:06 PM   #866
slammed57
slammed57's Avatar
Separation is 112
Its a big lift cam!
Yea that is a big lift c , the cam I have now is almost identical, I was thinking about goin to a crancam xr288hr which is just a tad bit more lift and lobe separation . But yours do sure sounds good
Old 12-21-2017, 05:45 PM   #867
_Ogre
_Ogre's Avatar
saw your hood latch thread where you mentioned that you had put the 58-59 hood on the 57, very nice mod and done well
i could have used this back when i was a teenager and rolled my first 58
those front S-pillars fold like a bad poker hand when a tf truck goes on it's roof
shop air compressor timer
Old 12-21-2017, 05:48 PM   #868
joedoh
joedoh's Avatar
what a fortunate father and a thoughtful son! hope you guys have a wonderful holiday
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 12-21-2017, 07:11 PM   #869
ptc
ptc's Avatar
Yeah -you can see how the geometry of the roll bar forward bars are exactly opposite of what the GM engineers came up with for support!
Amazing what a difference a year or so can make in the look of an interior!!!!
Old 12-21-2017, 07:12 PM   #870
ptc
ptc's Avatar
Thank you Joe! --- To you and yours also - Merry Christmas!
Old 12-26-2017, 03:03 PM   #871
ptc
ptc's Avatar
Ok so i finally got around to fixing my brake pedal design problem and redid the whole thing... somewhat. I left the hydroboost inplace and all that part, but just deleted the cab floor pedal design I had come up with. Originally I wanted the pedal to be part of the cab so that if it was separated the pedal assembly would go with the cab and not the chassis. That didn't work so well due to assembly "issues".
Heres all my parts I had to play with in getting this all together
So now I took a brake pedal arm that was on the bracket and I cut it up to fit the frame and chassis where I wanted it on the other side of the steering column where the clutch would be. The pedal side is welded onto the shaft end and can be totally removed with everything around it in-place.
Using the "clutch" assembly idea I drilled and put two flange bearings into the frame rail on either side and ran a 1/2" shaft thru it.
The other end I re-used the same billet alum lever I previously machined that is keyed onto the shaft end and just re-drilled a new hole in it. I made a new rod to connect to the hydro plunger. It has male and female rod ends to make adjust easy.
The pedal on the interior side of the cab was made of flat steel and rounded and then I welded a 5" long 1/2"-13 bolt to the back of it. It screws into the pedal arm on the other side of the firewall.
Then I found these billet pedal covers to put on both the pedals to make them match.
Yippe Kay YEA!!!
Old 12-26-2017, 07:35 PM   #872
Kim57
Kim57's Avatar
Nice work.
Kim
My build thread
Old 01-02-2018, 04:06 PM   #873
ptc
ptc's Avatar
Been a long week of holidays and truck de-bugging.... had a couple issues spring up after doing the brake pedal remake, brakes didnt work at all afterwards! - great remake right?
Well after chasing my tail with the hydroboost thinking it was all messed up I found a leaking residual valve, this brake line fitting was not tighting down enough to stop the leak so I just had to remove it.
Bleed out both front brakes for awhile to get it all working again and its all good. Had to lengthen the brake pedal rod into the cab as it was too short.
Then took it on a little shakedown cruise and just had a little fun with it. This truck is insane..... it has so much 'unnecessary power' (is there such a thing?) that it is just crazy trying to keep the power down on the asphalt and keep it going straight down the road. It is crazy torqey and just wants to run wild when you stab that throttle down and it gets going fast REAL quick... Boost is immediate! - you nail it and 10-15 lbs right now on the gauge!. Its reading direct at the hat. I cant wait to see what its pulling on the chassis dyno. Ive never had this much power before on the street.
My speedo aint exactly working right, its just doing a bouncing thing but it is counting off miles, So i dont know how fast Im going, but it cranks up before you know whats happening.
I need to go on a little longer cruise, stay off the pedal and get everything dialed in. The speedo is an elect-digital and I think it has to be programmed? Need to do that, not sure if the fuel gauge is working correctly either... maybe it just really goes down that fast!
Ive got a few little leaky places I need to get figured out too. Just annoying little things.
Old 01-03-2018, 03:17 AM   #874
Roadkill58
Roadkill58's Avatar
Nice way to spend the new year!
Good to see you driving the truck. It looks good too.
I'm working at driving mine by spring.
Rust Never Sleeps
Roadkill's 58 Chevy Stepside build
Roadkill's 69 Custom C20
Roadkill58 is offline   Reply With Quote
Old 01-03-2018, 08:44 AM   #875
lower50's
lower50's's Avatar
Your truck sounds like it would be so much fun!! Glad your enjoying it. When it brakes loose driving down the road is it easy to control?
1951 MG TD
